Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Dual ESC questions
Old 12-06-2019, 02:09 PM   #1
Default Dual ESC questions
So, I'm looking for a dual esc setup for my bully. I have a DX5 rugged, savox 2290, and have yet to pick motors.
I'm imagining a dual BR mini is still the best choice? I have gotten used to the adjustable braking on my Mamba X, and the adjustable brake ramp for steep descents, and I'm wondering if the BR mini braking is as smooth? I seem to remember my last MOA (from 5 years ago) doing an endo any time I let off the throttle on a steep downhill.
Would 2 mamba micro Xs be viable? I have read that they only use 2 FETs on brushed setups, and am worried that I'd burn them out pretty quickly...
Has anyone tried the new Carisma esc? the descent control looks like a cool feature...
Thanks!
Turtlejon is offline   Reply With Quote
Old 12-10-2019, 08:07 AM   #2
Default Re: Dual ESC questions
I’ve a Holmes dual br mini on my rig and the start up and braking are precise & ultra smooth! Really nice esc!
1st pass tommy is offline   Reply With Quote
Old 12-12-2019, 09:55 AM   #3
Great! Thanks! Is the braking ever too strong, like you’re rolling down a steep spot and it endos?
Old 12-17-2019, 05:49 PM   #4
I just today took out all stock bully electronics if your interested, all there except motors, Esc, bec, dig unit, switch, I even have original tx/rx
Chip9399 is offline   Reply With Quote
Old 12-17-2019, 11:49 PM   #5
Thanks!
I was looking in the castle link software the other day and apparently the sidewinder micro 2 got the 2.02 update. Meaning they should have better downhill control and delayed drag brake then the Holmes dual BR mini. Similar to the mamba x micro but uncased, less heat dissipation.
I do not own one though.
How many FETs does the mini BR have for brushed?
Old 12-19-2019, 02:06 PM   #6
I figured I'd chime in with my useless 2 cents... What is the end game use for this MOA?
I have 3. One with 4ws, Hobbywing 880 esc, and pistol transmitter. One with the stock rc4wd dig unit, Hobbywing 1080, and pistol transmitter. And one with dual Hobbywing 1080s and a cheap Flysky dual stick transmitter. I'm just a basher so no comps for me but after just a couple outings, the dual esc MOA with dual stick transmitter has hands down the most control. I have it set up for "differential throttle". Which let's me have either overdrive or full dig on either axle on the fly. It's a pretty sweet set up and would recommend it over the others all day, everyday. No question in my mind why the serious comp guys run dual esc/dual stick set ups.
Having said that, sorry to high jack your thread! Carry on!
Minoa is offline   Reply With Quote
Old 12-28-2019, 06:40 AM   #7
I just put in Holmes hobbies dual br-mini w cc bec, Holmes 35t torquemaster pro motors, I use a airtronics my-4, this thing is awesome, dig, burn and with dial you can over or under drive front or read axle anytime, This setup is my suggestion, works great.
Dual ESC questions - Similar Threads
4PLS questions on dual ESC Please Help!!!!!!! shawnwigley550 Electronics 0 03-20-2014 08:52 AM
dual motor esc questions mudd_slinger Electronics 16 04-07-2012 11:33 AM
Dual ESC questions????? MitchellY Electronics 10 08-08-2011 11:57 PM
Dual ESC questions. ComingApart Newbie General 9 02-07-2010 01:43 PM
Dual Sidewinder ESC setup Questions (Nomadio React) brettjord Electronics 4 06-02-2009 05:47 AM
