![]() | #121 |
Rock Stacker Join Date: Dec 2009 Location: Canada ,Nova Scotia
I was wondering if you can use the axial front axle with the servo moved to the side and batt on the front axle? Will there be enough room for articulation or will it hit the chassis when flexing?
![]() | #122 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
with the suspension fully compressed the servo sits between two frame rails. if you move the servo to the side and mount the batt next to it, they will probably interfere with the chassis as the suspension articulates.
![]() | #123 |
Newbie Join Date: Mar 2009 Location: charlottesville
My wreckluse will be here 1/12/10 cant wait to build it . Im using LNC axles and trans for my build.
![]() | #124 | |
Newbie Join Date: Jan 2010 Location: Huntsville
| ![]() Quote:
Does it keep the 3 Link set up in the front which accounts for the 15 mm shorter link up top in the front? I used the four link adapters that came with my SCX 10 in the rear, and the stock 3 Link set up in the front. I have only minor rubbing (about 1 to 2 mm) of my servo horn on the frame during full compression. We all know that you seldom experience a true full compression though, so it's not an issue. Do you have any pics of your universal mounts and the upper links front and rear? I'm interesting in going with Axial made links and your universal plates if I like them. | |
![]() | #125 |
Newbie Join Date: May 2010 Location: Atlanta
could i run crawler king axles??
![]() | #126 |
Newbie Join Date: Jun 2010 Location: Sutherlin
so if i have the ax-10 rtc kit i could get the wreckluse chassis and all my stuff would bolt on and it would be ready to go?
![]() | #127 | |
Quarry Creeper Join Date: Dec 2009 Location: At your moms,she says hi!
| ![]() Quote:
You should be able to use everything exceot for your links those come with the plastic links.The links will be way to long,and the links are pretty weak to begin with.I would upgrade and buy the axial metal links and ball ends. | |
![]() | #128 |
Rock Slayer ![]() Join Date: Jul 2008 Location: Fox Valley WI
8-32 all-thread with Jato rod ends sleeved with tubing works great also ![]() It's a heavy chassis so the extra strength of the above setup helps make it almost bullet proof. Last edited by TrailDawg362; 06-23-2010 at 10:35 PM. |
![]() | #129 |
Pebble Pounder Join Date: Sep 2006 Location: Myrtle Creek
i just got 1 of these in a trade. only thing it didn't come with a skid plate. can i order 1 separate?
![]() | #130 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
ive got two of these things now. both brushless with frame mounted steering servos, axial drivetrain and 2.2 tires. very capable rigs if stretched abit and with big offset rims they r pretty stable. i run gmade wheel wideners and these things r mean looking. will try and post pics as soon as i figure out how. and they are super durable!!!!!!!!!! ![]() |
![]() | #131 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
when will these be in stock again? and at what price?,,,the site says $199 is "limited" thanx |
![]() | #132 |
Rock Crawler ![]() Join Date: Apr 2008 Location: Boise, Idaho
X2 on when back in stock?? I would like to order one. Thanks
![]() | #133 |
Any chance I can get some new body panels? Mine are getting really beat up! Price and order info would be great!
![]() | #134 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
buy far the worst trany i have owned.The r2 is loud and striped be for my stock ax 10.ax 10 is the way to go 4.50 for the geer set and you are back on your way
![]() | #135 |
Quarry Creeper Join Date: Jun 2009 Location: Visalia, CA
Info on that stock date would be great. I got on the website contact and requested a reply last week. Just hoping they restock soon. Finished the axial based crawler,now I want in on the scale side. Any info would be great. Thanks.
![]() | #136 |
Pebble Pounder Join Date: Apr 2010 Location: Peoria,AZ
could i use a set of wheely king axles on this chassis?
![]() | #137 |
Pebble Pounder Join Date: May 2010 Location: canada
when will these be back in stock??
![]() | #138 |
I joined the Band! Join Date: Dec 2008 Location: West Virginia
PM sent honchoscaler, I have one for sale right now. ~John |
![]() | #139 |
Pebble Pounder Join Date: Jan 2010 Location: Murrieta
Would lolve to get my hands on one... Would anyone be interested in Traded for a axial scx10 rtr for the kit??? only been ran 3 times...
![]() | #140 |
Rock Stacker Join Date: Sep 2010 Location: streetsboro
IV bin trying to buy a wreckluse chassis but they. Wont email me back or answer the phone how do I get a hold of them
