Go Back   RCCrawler Forums > Vendors > RCP Crawlers
Thread: Wreckluse Feedback, Support & FAQ
Old 10-29-2012, 07:08 AM   #221
Default Re: Wreckluse Feedback, Support & FAQ
Hey ZoSo...why don't you guys sell replacement panels and hoods ????
Postclanker is offline   Reply With Quote
Old 10-29-2012, 10:34 AM   #222
What he said X10....especially hoods!
Lobonyc is offline   Reply With Quote
Old 10-29-2012, 10:54 AM   #223
RCP CRAWLERS
ZoSo's Avatar
I think I have a few hoods left ....
I'll check to see how many extras I have
...... I'll put them on the site this week.
ZoSo is offline   Reply With Quote
Old 10-29-2012, 12:28 PM   #224
outstanding....
Old 10-30-2012, 12:57 PM   #225
RCP CRAWLERS
ZoSo's Avatar
Replacement Hoods are on the website
http://rcpcrawlers.com/product.php?p...7&cat=6&page=1
Old 10-30-2012, 06:30 PM   #226
thanks for that ZoSo...just ordered two....
Old 11-03-2012, 12:38 PM   #227
Thanks from me as well!
Old 11-08-2012, 09:48 PM   #228
Got the hood in today, Tip Top shape.
Thanks A MILLION!!!
Alex
Old 12-23-2012, 01:26 AM   #229
Just purchased the wreckluse on RCP Cralwers. I wanted to go with a 1.9 Setup and I followed the recommended link sizes. I purchased 35mm Axial Post for front uppers and 50mm all around. When trying to mock up the front wraith axle, it appears that the 35mm front uppers are not even close to being able to mount.
I was thinking it may be the axle and took my scx10 axle off from the honcho and tried to mock that axle up and the front uppers are still short...What am I doing wrong here? I can make my own links, but would like to know if I did something wrong before I go and make a set.
I appreciate all the help I can get. thanks and Merry X-mas
Originally Posted by pigeonfarmboy View Post
Just wanted to start this thread for you guys that have any questions or comments about your new chassis.
Frequently Asked Questions:
Q: What kind of axles can I use for the Wreckluse?
A: The most common axles used will be the Tamiya TLT, Axial AX-10, and RC4WD D40 axles.
Q: What transmission should I use?
A: The skid plate is drilled for an Axial AX-10 transmission.
Q: What length links do I use for my Wreckluse?
A: Depends if you're using 1.9 or 2.2 Tires/Wheels. Keep in mind there is no "Wrong" or "Right" length since it's subjective. Here's what we've found to be the best using our Universal Servo/Link Mounts: (Lengths are the measurement of the link itself not eye-to-eye of the rod ends)
-1.9"
Front Upper - 35mm
Front Lower - 50mm
Rear Upper - 50mm
Rear Lower - 50mm
-2.2"
Front Upper - 55mm
Front Lower - 70mm
Rear Upper - 70mm
Rear Lower - 70mm
Q: What are the dimensions of the chassis?
A: Length: 17" (15" without the stinger)
Width: 7"
Height: 6.25"
Q: Is the Wreckluse made of Tubing or Solid Rod?
A: It is welded solid rod.
Q: How heavy is the bare chassis?
A: Just about 2 pounds.
Q: Is there any kind of replacement policy if I happen to break a weld on the chassis?
A: Yes, please strip all parts off your chassis and send it to us, we'll send you a replacement.
Q: Are spare body panels available?
A: Once the initial demand has been filled we will have extra panels for sale.
Q: Will hoods from different bodies fit?
A: Most of the hoods are not wide enough to fit correctly. We plan to make at least one more different style.
Guam_RC is offline   Reply With Quote
Old 12-23-2012, 04:31 AM   #230
I know what you mean, i've had the same problem....it depends of which 4 links bracket you are using...if you use the one from a SCX10, the upper links will need to be longer than the lower. If you use the AX10 bracket, the upper links will have to be shorter than the lower ones.
rebuilder is offline   Reply With Quote
Old 12-23-2012, 05:07 AM   #231
Thanks for the input. Ive been looking at all the wreckluse threads here and figured it may be a truss issue with the links not cooperating. I wonder what truss's the builders that run the recommended links use? Do you have a build thread of your wreckluse? Also, if anyone one can shine some light, it would greatly be appreciated.
Old 12-23-2012, 08:24 AM   #232
RCP CRAWLERS
ZoSo's Avatar
here's my build
I used the traxxas adjustable links
and RCP upper link mounts front and rear
RCP Wreckluse
Old 12-23-2012, 05:49 PM   #233
Thanks for the info!
Originally Posted by ZoSo View Post
here's my build
RCP Wreckluse
Old 12-23-2012, 06:26 PM   #234
Zoso,
Is this the upper link mounts you used?
RCP*Ax10/TLT*Aluminum*Servo...
here's my build
RCP Wreckluse
Old 12-25-2012, 10:47 AM   #235
RCP CRAWLERS
ZoSo's Avatar
those are the ones
Old 12-25-2012, 03:45 PM   #236
Does anyone have any recommended links for the following:
1)Axial SCX10 Axles with the stock 4-Link Truss included with the rig (for 1.9 & 2.2)
2)Axial AR60 OCP Axles (for 1.9 & 2.2)
Old 01-16-2013, 08:28 AM   #237
Hello,
has anyone tried shock absorbers Honcho on Wreckluse tuber frame?
I think go well as the frame tubes is heavier and the movement on the rocks should be still most real
If you have pictures of wreckluse with these shocks?
That shocks damper you use? And with what measure from eye to eye?
Harlok67 is offline   Reply With Quote
Old 01-21-2013, 11:25 AM   #238
RCP CRAWLERS
ZoSo's Avatar
I haven't tried the AR60 axles ....yet
Originally Posted by Harlok67 View Post
Hello,
I've been using 4" traxxas big bore shocks
but the honcho shock will work fine
Old 01-26-2013, 09:18 AM   #239
WOW fast shipping guys , ordered a replacement hood on Wednesday and its here today , Thanks guys !!!!!!
paleblue46 is offline   Reply With Quote
Old 02-06-2013, 12:18 AM   #240
What motors you guys running?
natskiboy is offline   Reply With Quote
You may edit your posts
