Go Back   RCCrawler Forums > Vendors > RCP Crawlers
Thread: Wreckluse Feedback, Support & FAQ
Old 04-02-2012, 10:31 PM   #201
Default Re: Wreckluse Feedback, Support & FAQ
Has anyone gotten said CAD file? If not, I'll try and make one from the plastic panels I have, then post pics of what happens when I feed it into the "machine"
hehe. techshop lets idiots play with things we shouldn't.
hscrugby is offline   Reply With Quote
Old 04-10-2012, 11:22 AM   #202
Rock Slayer
TrailDawg362's Avatar
Are the original Wreckluse decal sheets available for purchase? I'm looking for 2 sets if ya got 'em. Post up or PM me with a price and info.
Thanks,
Troy.
TrailDawg362 is offline   Reply With Quote
Old 07-02-2012, 03:59 AM   #203
could all the running gear from a gmade R1 bolt onto one of these chassis?
aussie_rob is offline   Reply With Quote
Old 07-02-2012, 07:15 AM   #204
RCP CRAWLERS
ZoSo's Avatar
I haven't tried that drivetrain
ZoSo is offline   Reply With Quote
Old 07-03-2012, 02:08 AM   #205
im looking at upgrading but kinda stuck as to what direction to go. wreckluse chassis with my R1 diffs and running gear or a axial wraith???
Old 07-05-2012, 12:31 PM   #206
Get a Wreckluse and run wraith axles. That's what I have. Works great!
Chi Town is offline   Reply With Quote
Old 07-13-2012, 06:01 AM   #207
I'm looking for a Wreckluse chassis...but i'm wondering if my hardcase Sky lipos 3S 5000mah would fit in the chassis...that's a big factor if I need to buy more batteries...
Thanks!
rebuilder is offline   Reply With Quote
Old 07-13-2012, 07:56 AM   #208
RCP CRAWLERS
ZoSo's Avatar
checkout this thread.....I mount my battery in the same spot
Wreckluse
here's a 4000...... I don't think the 5000 hardcase will fit
http://i743.photobucket.com/albums/x...ckluse/two.jpg
Old 07-14-2012, 12:28 AM   #209
Im looking at rebuilding my Wreckluse. I need a hood and decal sheet. Where could I get one?
Big Worm is offline   Reply With Quote
Old 07-14-2012, 07:06 AM   #210
RCP CRAWLERS
ZoSo's Avatar
the HPI jeep rubicon body will work
If I have any extra hoods I'll post them on the site
I'll add the decal sheet to the website this weekend
Old 07-14-2012, 09:50 AM   #211
Wreckluse
That pic is from my rig...and I have a 4800 hard case that fits there also...tight , but it fits
Nice to see the photo getting around....
Postclanker is offline   Reply With Quote
Old 07-14-2012, 09:53 AM   #212
Sure wish you would make new panels.....
Old 07-14-2012, 09:52 PM   #213
Thanks man, also. I run a 5000 2s hardcase and it fits.
Old 07-14-2012, 10:11 PM   #214
Here is a pic of mine how it sits.
Now I just need a new hood and decal sheet and its getting a nice wrap from the local decal shop.
Old 07-15-2012, 12:20 AM   #215
RCP CRAWLERS
ZoSo's Avatar
looks great....I'm taking my Wreckluse for a walk tomorrow ...up near Big Bear in SoCal
I'll take some video ...it's a new spot
Old 07-15-2012, 12:15 PM   #216
Also if you could post up the lenght of the links in inches eye to eye so I can make my own. Id like to get my servo from hitting the chassis.
Old 07-16-2012, 03:50 PM   #217
RCP CRAWLERS
ZoSo's Avatar
I used Traxxas*Front*Turnbuckles...
for the bottom links and rear upper......3.78" or 96 mm
and I used Traxxas*Turnbuckle*Camber...
for the front upper links.......3.44" or 87.4 mm
I used these plates up front *RCP*Ax10/TLT*Aluminum...
don't remember why but I doubled them up and used RCP*Crawlers*Lower...
attached to the bottom...so the upper front link mount is at it's lowest point
I used STRC*Machined*Alum.... in the rear and mounted the links
to the bottom of the plate...bolts straignt up
how the link attachs to the axle can vary dimensions
but these JATO links are adjustable so I can the move the servo
just enought to miss the cross bar on the chassis
Old 10-09-2012, 03:59 PM   #218
After a few falls, my hod is slowly starting to fall appart... anyone tried something else other than the HPI jeep hood? Timberwolf? i'm trying to figure ou something without the winch in the front, so I can install my own working winch...
Old 10-09-2012, 06:17 PM   #219
RCP CRAWLERS
ZoSo's Avatar
I've seen the bronco and an old chevy
Old 10-29-2012, 01:42 AM   #220
Some mods I did to a used project I picked up. It was someones first crawler and sheesh the paint job was a mess. Crawler was stripped and in the process of being rebuilt. Chassis mods were tig welded (not brazed) w/ 3/16 round rod.
Build Thread
Used wreckluse Revamped
Some pics
spiderxx is offline   Reply With Quote
You may edit your posts
