05-13-2010, 08:58 AM | #41 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
Glad to see you guys got the mongoose systems up and running. I'm curious how these will work out for you. Wheelspeed is fun haha.
05-13-2010, 10:58 AM | #42 |
Quarry Creeper Join Date: Apr 2010 Location: Idaho
How is the servo mount holding up with the new servos? And did you get your high steer knuckles from ckrc installed and everything hooked up. I Just made another steering servo mount to try on my custom build. But I wont be able to put in a higher torque servo with it until I get my Castle BEC. We have the first prototype servo mount still in our mostly stock RS10 with a RC4wd Servo and it is holding up great but it seems like you put your rig through a little bit more abuse than we do Looking forward to some new photos and all your opinions now that everything is up and running. |
05-13-2010, 12:01 PM | #43 |
Quarry Creeper Join Date: Apr 2010 Location: lake havasu city
that servo tray is holding up really well with the new servo's so far only got a couple batt cycles through it so far. we will see where it goes, its looking good though. no i havent got the high steer knuckles on yet i spent about 4 or 5 hours yesterday putting together the mongoose setup and wanted to play so i got a bit distracted after that lol. high steer is going together today. thanx for all the input everyone its making this build alot funner lol. also should have some video up this weekend of me at my home course and maybe some local spots i crawl at. i will take some pics of what it all looks like now... about 10 lbs of wire... that should paint the pic lmao. |
05-13-2010, 12:04 PM | #44 |
05-13-2010, 02:10 PM | #45 |
so i got the high steer on and found that i did have to bend my own link for the cross link between the 2 steering knuckles no biggy though. heres some pics of what its looking like now. and with the mongoose motors theres no need to make room for the motors by custom bending links yaaaaay... |
05-13-2010, 03:59 PM | #46 | |
Newbie Join Date: Feb 2010 Location: martinez
This is actually exactly right. the way you had your links setup before is more than likely what broke the part. having both your upper and lower links running parrallel gives no stregth laterally. (side to side) the triangulation is the only thing keeping your axle from walking side to side under your rig. idealy you should have no less than 35-40 deg triangulation on your upper links. double triangulation (for a crawler) would be better. | |
05-13-2010, 04:49 PM | #47 | |
Pebble Pounder Join Date: Jan 2010 Location: Emmett, ID
Good job on that build. Looking forward to the videos. We have a practice crawl tonight so we should have some more pics on the website. | |
05-13-2010, 04:56 PM | #48 |
Pebble Pounder Join Date: May 2010 Location: Central Coast
Are those brushless? They look smaller than the stock motor.
05-13-2010, 05:12 PM | #49 |
yes they are brushless and yes they are a bit smaller then the stock ones but they pack one hell of a punch lol. i will put up a video tonight of the "WHEEL SPEED" omg its scary lol. |
05-13-2010, 05:14 PM | #50 |
I just don't like the thermal shutdown thing I've been reading about.
05-13-2010, 05:20 PM | #51 | |
05-13-2010, 05:24 PM | #52 |
also if it was to break from side load it would have most likely broke from the thinner part where it is mounted to the diff. not the middle of the link mounting holes.
05-13-2010, 08:54 PM | #53 |
heres a little sample of whats to come... i like to call this "WHEEL SPEED TEST" LOL. http://s82.photobucket.com/albums/j2...0513001932.flv |
05-13-2010, 11:24 PM | #54 |
Rock Stacker Join Date: Feb 2010 Location: orange county
that was awesome. i think wheel speed might be an understatement. cant wait to see more
05-13-2010, 11:29 PM | #55 |
That is quite a bit of wheel speed!!! We ran a rig with the exact same narrow kit, bat wing eliminators and servo mount you have just without the mongoose set up and put it through a few hard drops and a couple hard rolls tonight at our local comp and it placed second in 10 rigs with 3 bullys, 2 losi night crawlers, 3 ax10's and 2 customs but overall it did extremely well and we are very proud of it especially since it is giving redcat an awesome rep. We have yet to break any of our own parts though, so I would have to assume that the extensions weakened the blocks and caused them to fracture and after that point they were no longer able to take any strain and will continue to break no matter what hole you place the links in. But the new wing eliminator blocks we are going to send you are not brittle at all and instead will be more of a soft material capable of a lot more abuse without breaking cracking or bending hopefully. We are interested to get your feedback after you get them. |
05-13-2010, 11:39 PM | #56 | |
but anyway i guess theres some guys out here trying to get some comps set up so hopefully soon i will be able to run against some other rigs and see how this setup compares. although i still need to put some wheel weights on and get a set of rovers to see if i cant get some better traction without loosing that tire height. i just dont think the hammers are going to cut it out here theres just too many axle grabbers to try to fight around all the time. | |
05-13-2010, 11:40 PM | #57 |
Dude that thing has some pep. Hows the braking on steep grades?
05-13-2010, 11:44 PM | #58 |
oh i just spent a couple hours cleaning up the wiring and kinda organizing the component wiring and got a couple pics of my parallel wire harness i built for the mongoose setup. that thing was a PAIN to make but it looks pretty dang good. im exhausted so i will upload the pics in the morning lol.
05-13-2010, 11:48 PM | #59 |
| its eehhh ok i guess it holds for the most part but as the batt volts drops so does the holding power. in the vid you can see it holding the back tires off the ground about 1 inch and thats about a 60% incline
05-14-2010, 12:23 AM | #60 |
| the thermal shut down really is not that bad and its actually a really good thing to have because it keeps you from melting down your motors and if they get hot enough to trip the thermal circuit theres something wrong with your gearing anyways or you are just getting it in to a bind too much and shouldnt be pushing it that hard anyway. personally i am loving this mongoose setup more and more its just taking a bit to get use to controlling the throttle. wheel speed can be a car killer...
