Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Client Build: Creeper Clone
Old 04-11-2014, 11:17 PM   #21
Default Re: Client Build: Creeper Clone
Originally Posted by donny8594 View Post
Since I will not be live testing this clone I have no input on whether parallel or pinched is better on the rocks.
you built it you need to run it hot before the customer gets it. just so the customer knows there are no week points.
The only run this one gets is on the stand or in the house. He's going to receive a scratch free perfectly clean rig. I've got my nearly identical rig to bash and look for problems with. If anything his rig is built to higher tolerances and with a more critical eye than mine.
But in general I agree with that principle...I just cannot put it into practice this time.
Here's a video of me mounting tires on the cut down rims using my world renown tire press lmao.
MountainStorm is offline   Reply With Quote
Old 04-12-2014, 07:37 AM   #22
you do good work man. i cant wait to see you get your hands on a scaler.
donny8594 is offline   Reply With Quote
Old 04-12-2014, 08:00 AM   #23
LMAO that's the deep end there...where madness lies in wait. Building a scale garage that has a scale garage that has a scale garage? I would need a microscope.
I do love scale vehicles of any type. Brings out the child in me instantly. Meaning I will definitely break it playing with it..
Thanks man.
Old 04-12-2014, 02:32 PM   #24
Thanks man.[/QUOTE]
build it, break it, blame the driver, blame the part, look at it on the bench for an hour. then make it better, both the driver and the rig. thats my favorite part of the hobby.
Old 04-12-2014, 11:10 PM   #25
By building almost every part and reconfiguring it over and over I have gained much more knowledge of what is possible than if I just got something and kept it the way I got it that's for sure.
I turned my attentions to the shell and got it cut and mounted. There were some compromises, but I am going to let it sit for a day before doing any more cutting.
Have a look.
Old 04-13-2014, 12:11 AM   #26
Old 04-13-2014, 02:28 PM   #27
Old 04-14-2014, 10:19 PM   #28
After letting the whole build stew for a day and a half as I handled various other projects over the weekend I put in a productive day and got the body cut to it's final shape, started on the waterproofing of the electronics and created a crash cab for the chassis if my client wants to try his hand at crawling bare back. The cab was a lot of work but I think it adds some character to the otherwise overly symmetrical look of the vehicle.
Old 04-15-2014, 05:27 AM   #29
Old 04-15-2014, 11:07 PM   #30
Default Almost Done!
Old 04-16-2014, 11:47 AM   #31
Default Phase One Completed
Everything is everything. It's alive. All systems go. Which makes me a happy camper.
Got a video uploading but here's some pictures in the meanwhile.
To catch up from the last update: waterproofing complete, battery attached with velcro, BEC attached with velcro, BEC programmed to 6VDC output via Castle Link, Red wire on ESC 3 pin pulled and insulated with heat shrink, BEC plugged into RX, to power the servos and RX, wiring lashed, new AHZ aluminnum servo horns installed, system test on stand.
Next up shell work and LED wiring madness.
Old 04-16-2014, 12:08 PM   #32
nice build bud. somebodys gonna be happy when that rig gets delivered.
what do you have in mind for the paint scheme?
Old 04-16-2014, 12:41 PM   #33
It's going to be pretty out there. Camo colors under M2D Camo Hydroprint with matte clear coat on top.
Old 04-16-2014, 12:43 PM   #34
you lost me after camo.
Old 04-16-2014, 01:12 PM   #35
Old 04-16-2014, 04:27 PM   #36
how r u waterproofing the esc?
iDC5 is offline   Reply With Quote
Old 04-17-2014, 05:28 AM   #37
It's already pretty well WPed from the factory. The important bits are sealed in a box under the heat sink. All I did was seal the exposed PCB and lead ends with super glue. Easy win. Works good too.
Old 04-19-2014, 07:01 PM   #38
Default Short Indoor Test
Thing is pretty sweet. Makes me want to get some new motors and diffs for mine.
Old 04-21-2014, 12:54 PM   #39
Default Solder Monkey
I am confuzedled. The red and amber LEDs have the positive lead on the big part inside...which is opposite of what I am expecting. The white ones are positive on the small bit. Which is normal. I wonder why?
Still in the prepping stage. Soldered 33 ohm 1 watt flame proof resistors on the postive leg of the white bulbs and 22 ohms on the rest so they will run within spec tapping into the 6VDC output of the BEC. Using a Y cable and an extension to make a start to the loom.
Everything has to be loomed parallel so no simple way to make it happen...lots of solder connections etc. And I am not risking the shell to a slip of the iron or a splat of solder so I gotta get all the lengths just right and do it up on the bench.
Fun fun fun.
Pics later...
Old 04-21-2014, 10:24 PM   #40
Default Too much fun
And so it begins...
Client Build: Creeper Clone - Similar Threads
My semi scale "DD Clone" build thread camaroguy327 Venom Creeper 15 01-09-2013 07:59 PM
venom creeper build.....crusher's creeper crusher Venom Creeper 43 07-10-2012 05:12 AM
Need email client help JohnRobHolmes Chit Chat 6 10-24-2011 07:19 PM
Creeper Build nckwnchstr Venom Creeper 23 03-23-2011 03:47 PM
Clone Sammy Build scuzzy51 1.9 Scale Rigs 51 11-14-2010 12:24 AM
