Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Loading
Thread: Project: Fusion-X
Old 02-18-2008, 07:11 PM   #141
BEEFY!!! I like it...
smcurry83 is offline   Reply With Quote
Old 02-18-2008, 07:35 PM   #142
Thanx for the comments guys.
The nest step is to get all the electronics in and drive it around, make panels, some primer on the frame, a complete interior, and a bunch of detail work.
Mikey007 is offline   Reply With Quote
Old 02-18-2008, 08:15 PM   #143
bling bling. 4 wheel disc brakes
Old 02-18-2008, 10:29 PM   #144
that is so cool. Nice work. Want to sell it? hahaha
Let me guess "take a number".
Jester666 is offline   Reply With Quote
Old 02-18-2008, 11:33 PM   #145
[HOONIGAN]
Wrecker's Avatar
Nice!
I mocked up those tires on my PSC Bruiser and they looked WAY too big. They don't look too bad on your's though.
Wrecker is offline   Reply With Quote
Old 02-19-2008, 06:51 AM   #146
~THE SCALE SHOP~
is that sharpie making the one ring a "trail ready" design?
why the assembly? whens the frame getting some color?
STANG KILLA SS is offline   Reply With Quote
Old 02-19-2008, 05:08 PM   #147
Quote:
Originally Posted by wrecker View Post
Nice!
I thought the same when I first got them! Put them on and they aren't too bad.
Yeah I was just fooling around, to see if it would look the part. What do you think?? That took me 30 seconds. If I do go with it, I'm going to make a stencil.
I'm going to put all the electrics in and run it around, and I haven't decided if I'm going to make tabs for the body panels to bolt on or use some other technique. Ideas?
Thanx alot jester. At this time I can't sell it but if I do I'll put you on the list.
Mike
Old 02-19-2008, 06:02 PM   #148
~THE SCALE SHOP~
ive always like a well done bolt on setup
but a hidden mounting system is always cool too.
Old 02-19-2008, 11:46 PM   #149
That is kick ace!!!!!!!
Old 02-20-2008, 12:35 AM   #150
[HOONIGAN]
Wrecker's Avatar
I do like the bolt on panels, but a hidden system would look a lot cleaner imo. I just did 3mm nuts on my chassis and bolted all of the panels on with 3mm button heads. The 3mm stuff is a little big though, maybe some 2mm nuts and bolts might look better.
Old 02-20-2008, 06:46 AM   #151
~THE SCALE SHOP~
agreed, 2mm or 2-56.
Old 02-23-2008, 04:55 PM   #152
That rig is looking awesome!!! I know it doesnt matter much due to it being a scale rig, but do you have any idea of the finished weight?
76lcforty is offline   Reply With Quote
Old 02-23-2008, 05:05 PM   #153
I love the way the tires look. Nice.
Old 02-23-2008, 09:17 PM   #154
I'm still undecided, but it is looking like a combination between a hidden system and some micro fasteners.
Quote:
I'm still unsure of the finished weight, but the chassis itself weights a little over 3 lbs.
Quote:
Thanx! I think they are great for the build.
Old 02-23-2008, 10:48 PM   #155
Moderator
RXcrawler's Avatar
Man this is the coolest build ever!!! I make sure Dan sees the newest up dates.
RXcrawler is offline   Reply With Quote
Old 02-25-2008, 01:18 PM   #156
Damn nice build. Whats the wheel base? And can you post a picture from the side with the rock crusher on?
Thanks
TheNewbie is offline   Reply With Quote
Old 02-25-2008, 05:16 PM   #157
Quote:
Thank-you!
Quote:
Thanks
Thank-you, the wheelbase is at 13 3/16"! Will get a pic from the side in a bit.
Old 02-25-2008, 06:41 PM   #158
How did you bend the front grill tube like that?
Old 02-25-2008, 06:59 PM   #159
I bent the bigger round bends with a brakeline tubing bender, and the smaller radius bends by hand with a pair of vice grips. I also built a bending jig for different radii (sp) out of square tubing and various sizes of bolts.
Pic for the newb:
Still have to rework the rear section of the body panel to flow better with the curve of the tire.
Old 02-26-2008, 06:29 PM   #160
looking good!
I don't know if i missed it or not, but what is your wheelbase set at?
XSRCdesign is offline   Reply With Quote
You may not edit your posts
