Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Loading
Thread: 1.9 Toyota 4Runner Scaler
Old 07-10-2008, 03:29 AM   #1
Default 1.9 Toyota 4Runner Scaler
Started a new body for my 1.9 Scaler
I wanted something Different Rare and unique.
Have always liked the 4runner and there aren't many on here due to the fact that all the Kyosho Bodies are owned by Mike!
so cant find one Build one
Here's the plan? Will be adding a Roofrack with scale bits when teh body is done.
Truck Spec
Modifeid Hi-lift Chassis
Rc4wd Rock Crushers
Rc4wd R2 with Disconnect Tranny for switchable 2wd-4wd.
Hpi Stock Car rims
Full Four linked with Stabiliser Bars on Both axles.
Lrp Speedo
Here's some progress shots.
Lots of filling and sanding ahead!
More to come stay tuned and comments and sudgestions are more than welcome.
neil
Dready is offline   Reply With Quote
Old 07-10-2008, 08:33 AM   #2
whats the back window out of or did you build it to, nice build going to look killer
twistedsmily is offline   Reply With Quote
Old 07-10-2008, 08:37 AM   #3
Quote:
Thats the Louvre Panel off a Bruiser Back Window.
Old 07-10-2008, 09:07 AM   #4
Location: a place where everything looks the same. oh and no rocks.
did you cut up the bruiser part? the thing that site in the bed behind the cab??
live2crawl is offline   Reply With Quote
Old 07-10-2008, 09:08 AM   #5
Quote:
Yep cut it up!
I'm Bad
Old 07-10-2008, 09:27 AM   #6
Quote:
Originally Posted by Dready View Post
Yep cut it up!
I'm Bad
Ooooh Dready the Tamiyas gods are sooo gunna condem you to an after life of pain and suffering . I'm toying wiht the idea of doing a similar truck to tow my other Hilux. Mine will be 4 door though.
Looks good so far by the way.
Tupers is offline   Reply With Quote
Old 07-10-2008, 09:35 AM   #7
Nah i'll take my chances:-P It was begging to be cut up.
Will look better like this once i'm done, Can never understand why tamiya added the sleeper bit in the first place.
To be really honest it was in fantastic nick!
Got it of Cad cheers Bud
Old 07-10-2008, 09:42 AM   #8
Cant wait to see the finish product
MAX climber is offline   Reply With Quote
Old 07-10-2008, 09:53 AM   #9
ooh, thats what I was planning on building next!
Are you going to shave the fenders and redo them square like the 4runners?
pantablo is offline   Reply With Quote
Old 07-10-2008, 10:43 AM   #10
Sinking with the ship
1BadJeepBruiser's Avatar
Looks like your off to a good start, however it will kinda be more like a trekker then a 4runner
I had a similar body but it got damaged in shipping on the way to me and I spent countless hours repairing it only to not be satisfied with the results so i sold it...
Old 07-10-2008, 10:50 AM   #11
if you fill in the recess under the top edge of the bed and change the wheel well openings to more squarish you'd be much closer to the later gen 4runner. I was planning on doing both.
You'll should also modify the grille too
Old 07-10-2008, 10:55 AM   #12
Is it me or is the bed too long as well. Looks like a bit could be sectioned out. I could be wrong, but by adding the 4Runner top to it makes it look like a truck with a topper and not the intended?!
O.C.D. is offline   Reply With Quote
Old 07-10-2008, 11:03 AM   #13
There was actually a suv model of that body style toyota pickup. I forgot what it was called but I'll try to find some pics.
It was an after market add on and there were only like 1200 made.
Edit: duh, the trekker
http://www.toyotaoffroad.com/Article...er/Trekker.htm
engineerjoe is offline   Reply With Quote
Old 07-10-2008, 11:23 AM   #14
I found that picture of the Red trekker whilst doing a search, Not keen on the oval rear windows hence i thought i'd go for the four runner.
Old 07-10-2008, 11:24 AM   #15
Am going to Try and do the arches just haven't got my head around it yet
And also infill the rear lines if that makes sense.
Old 07-10-2008, 11:26 AM   #16
Quote:
I think the bed is about the right length give or take a couple of mill!
am going to do the fenders and grill so it should look pretty 4runner ish when i'm done.
Will certainly look unique which is what i'm after.
Old 07-10-2008, 11:28 AM   #17
Mike if it comes out half as good as this green one i will be more than happy.
Thanks for taking the time to post up the pics they will be very handy as reference.
Old 07-10-2008, 11:41 AM   #18
in theory the arches should be pretty easy to do. shave off the round ones, then glue up a squarish one that bulges out a bit in the center. then shape it with sanding paper or a small file. that was my plan anyway...
Old 07-10-2008, 12:09 PM   #19
Got to be brave to slice them off! Will see how i get on with the top first, if it all goes wrong i can still turn it back into a pickup with not alot of effort.
How where you going to tackle the Grill and Tailgate?
Old 07-10-2008, 12:22 PM   #20
NIK
looks like a good start
NIK is offline   Reply With Quote
You may not edit your posts
