Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers
Thread: Big Crown Style...
Old 05-06-2015, 05:51 PM   #1
Default Big Crown Style...
This "little" guy, is last on the list of my comp rigs.. Figured, I'd do it right!
A little parts pics..
Electronics..
Ohhhh yyyyeeeeeaaaahhhhhh!!!
Time to switch to axle's.. Or axle...
I'm building as family/work/time allows.. With the deadline of having it in the rocks, for ECC.. Which I'm leaving for in 8 days!
Back at it..
winnerone23 is offline   Reply With Quote
Old 05-06-2015, 05:52 PM   #2
Default Re: Big Crown Style...
Parts list..
Dlux...
Supah chassis w/narrowed aluminum skid, links, ti link sliders..
2x front replacement cases an axle parts.
delrin V2 knucks..
front knuck weights..
servo strengthener (for the front)
Electronics...
HH 13t 520 puller's
HH BRSL's
CC bec's
Hitec 7980's(with Dlux servo strengthener on the front)
Airtronics MT-4s and rx
Wheels and tires...
Hpi wheels
Trencher/HB khaos 8"
CI supah foams
Thanks to Hittman, Samu, and Manu.. Lol..
I believe Manu made the setup, which Samu ended up with, and I brought home from World's and traded Hittman for before I shipped him Samu's Supah!
All brand-new still!
Old 05-06-2015, 06:31 PM   #3
I think you need longer rear links.
MountainStorm is offline   Reply With Quote
Old 05-06-2015, 07:18 PM   #4
MODERATOR™
EeePee's Avatar
That's pretty ugly looking, what is it?
EeePee is offline   Reply With Quote
Old 05-06-2015, 07:20 PM   #5
"Ugly" is the New Sexy, Dlux chassis!
Old 05-06-2015, 07:41 PM   #6
Nice! New super builds means more activity here! This is some good stuff too.
Curcal is offline   Reply With Quote
Old 05-06-2015, 07:58 PM   #7
5th D Owner/Driver
cboggs's Avatar
Ive been waiting for you to start a super! Good parts for sure.
cboggs is offline   Reply With Quote
Old 05-07-2015, 06:57 AM   #8
Wanna get? Gotta want.
Erik D_lux's Avatar
Yeah buddy! Youre going to love this car!
I wish I would have kept that skid for myself....
What are you thinking for radio settings? Seems like it would be sweet to have the rear steer setup on the lever that you usually use for proportioning. Seems like that would really mess with your head though too. IMO, smooth, non incremental steering is huge.
Erik D_lux is offline   Reply With Quote
Old 05-07-2015, 07:32 AM   #9
It's mine, you can't have it! ;)
The skid worked out great.. I threw in a 2mm axial aluminum spacer's at the skid/chassis..
Yes, I believe the rear steer will be in the lever.
After talking to a few ppl, watching Samu, and having my 4ws trail rig setup on the lever. I feel the general consensus is, proper rear steer is more important/usable then motor mixing..
Old 05-07-2015, 07:55 AM   #10
Erik D_lux's Avatar
Agreed. Rarely if ever do I mix/proportion in a comp, only in fun crawling.
I think its going to make the super harder to learn though... Its hard for me to transition back and forth from cars. After driving my super, I will try and rear steer my 2.2P class car for 1-2 packs.
Old 05-07-2015, 08:58 AM   #11
I hear what your sayin..
Like this past weekend.. Ran 1x course of 2.2s, 2.2p, an trail/scale.. Then built another course of each.. (My tx cycled thru rx's more in one day then it has in a year! Repeatedly.. Lol..)
My TF2 has the 2 siped tranny on the lever..
Scx had 4ws on the lever..
I didn't try to dig/burn my TF2 or try to shift gears on the pro rig, at all.. So hopefully I can follow suit between the super and the pro..
Old 05-07-2015, 09:24 AM   #12
FINALLY a topic of THE beast! Now there's only Hittman's supah topic missing still.
I seriously suggest to put the rear steer to the lever.
Nothing comes even close to be more epic feeling than getting used to the lever rear steer. You can bring the rig basically however you like on the course. I enjoy driving the super like that. Hardly use the dig, unless I have to. It will take some time to learn to switch the rigs, but it'll fade off eventually.
Great to see, that you picked up some kickass parts for it. Looking forward to see how you do with it.
Zarizi Tech is offline   Reply With Quote
Old 05-07-2015, 11:25 AM   #13
Driving super is crazy fun! The rear steer totally changes the way dig works. The proportional is still really nice so don't forget about it entirely.
Old 05-07-2015, 12:56 PM   #14
Thanks Samu.. I'm pretty stoked about it! The true test will come after I get some drive time on it..
Hopefully a fair well at the NENC, which will leaf up to the true test, in Vegas!
Curcal.. I'm not sure how I can fluently do steering and proportional..
Maybe I'll have to get with Purp and see if I can't put in a self centering joystick for proportional.
Or steering on the joystick and motor's back on the lever..
Time will tell...
Old 05-07-2015, 04:02 PM   #15
Sounds like a case for the twin sticks..... hehehehehe
Old 05-09-2015, 01:15 PM   #16
How are you guys setting up your servo positioning?
I'm going with what I know, and started mounting it level/plumb, with the front gear case..
Also.. Same thing with the link/shock mounts...
Old 05-09-2015, 03:08 PM   #17
Predrill and tap link mounts off of the car top and bottom 180* ish from each other
Assemble every think together mock up use set screws to keep things from moving while you adjust wheel base square and case angle. Remove either your top or bottom link mount set screws drill and tap tubes. My self i use m3x6mm button heads for the tops. Of my link mounts. Install those screws. Then do all the bottoms (heres where i use set screws) .
then set castor use set screw in the alternative screw hole (if using ax10) drill and tap tubes . I use 3mx6mm here too both sides
I hope that helps
Old 05-09-2015, 03:10 PM   #18
After all that then i did the servos ... i eyeball set them to level. The important part here i found was clearance of that big huge gear for the strengthener.
Old 05-09-2015, 07:13 PM   #19
Thanks for the info Curcal..
I'm following what your saying. So, say your rear case is angled to in the air, you still set your servo level with the ground? (I can dig it)..
Now I just have to find the max wheel base info and get to setting stuff up.
I keep bouncing back and forth on threads and see that I'm kinda boned with my setup!
I have centered case's and super 300's.. Which makes me think I'm going to be narrow and lack steering.. :( or wide hex's needed..
I guess, in the long run, I'll have to get 2x LONG side tube's and 2x full sets of the Dlux'd out ofna shaft's.
I'll have/get a good amount of time for building tomm..
Old 05-09-2015, 07:27 PM   #20
Wheel base has to be between 16in min. and 18in max.
Big Crown Style... - Similar Threads
**Dont Buy Crown Parts** winner 1:1 Full Size Vehicles 4 08-12-2014 10:34 AM
May 26th - Run what you brung style comp - Big Dog RC, Stoneboro, PA Tin Soldier Pennsylvania 8 05-27-2012 07:59 PM
MSD Nats 2011 Artwork - Big Montana Style FreqEsKinz Competitions 8 05-03-2011 11:10 PM
**NEW From Reign - The Servo Crown (TM)** PinchFlat Chassis and Suspension 3 07-17-2008 12:11 AM
Diff crown removal try_xj XTM Crawler 3 03-15-2005 02:36 PM
