08-26-2009, 04:00 PM | #61 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
what did you use to strip the crome on your chyennes?
08-26-2009, 04:17 PM | #62 |
08-26-2009, 05:29 PM | #63 | |
RCC Addict Join Date: Jun 2004 Location: Little Rock, AR
But at Disney, yes they should be great. Of course, you could run bricks as wheels and still get traction at Disney. | |
08-26-2009, 05:51 PM | #64 | |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
I will have to dissagree with you on the flat rock statement.Moab is all flat and my Super Soft Plowbows had no issues.And the same goes for Tyler's SS meatgrinders. | |
08-26-2009, 08:23 PM | #65 | |
I probably had the wrong foam setup on the plowboys. I think I have a setup now that suits my driving style. | |
08-26-2009, 08:39 PM | #66 | |
If I had to guess it would be the compound difference between your plowboys and mine.But what works for you is all that matters. | |
08-26-2009, 09:50 PM | #67 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
TXRCRCA had our State final in Llano, TX and it was all smooth granite type rock which produced a flat surface. I ran Soft compound Plowboys and they crawled everything I tried except one small techinical gate section. That one area had more to do with the small ledge and improper four link set up on my Super than the tires. What compound were your Plowboys? |
08-27-2009, 06:46 AM | #68 | |
08-27-2009, 06:56 AM | #69 | |
Soft is the softest compound avaliable to the general public, that is the same compound as the cougar.The medium soft that you had is a big difference from the soft.I would say Cougars and Axial Lizards would be a good comparision between the two. The team drivers were able to get them in Super Soft wich is even stickier but they will not sell them because of how fast they wear and they have to trash a bunch of tires right out of the mold because the compound is so hard to work with from what I understand. | |
08-27-2009, 08:51 AM | #70 | |
X2 on the difference between Medium Soft and Soft compound. I was told the same thing when I asked Panther about the Super Soft compound. I can only imagine how soft Super soft is and how fast they must wear out. My Soft compound plowboys on my super show the wear of 30 battery packs but I have only ran 15 or so on them. Super soft must wear at like 3:1. | |
09-15-2009, 08:26 PM | #71 |
| Had to do it.
When I saw the new Panther Leopards, first thing I thought about was making some for my super. Well here they are. I narrowed up some Pro-Line Wabash wheels to 1.8" and bought 6 leopards and 4 moabs. That leopard rubber compound is crazy, They were sticking together without glue. It's been raining like crazy and won't stop, so no testing other than carpet and wall climbs. Foam is custom mixture, and it's adjustable . About 7.2" by 2" wide and 11oz wheel/foam/tire each. I'll need to adjust the shock limiters. Due to the bigger tires, I need more flexy. Ground clearance is greatly improved. Time will tell if they are worth a damn. Last edited by Szczerba; 09-15-2009 at 08:59 PM. |
09-15-2009, 08:34 PM | #72 |
Those look good Huge I can't wait to see them in person at Disney.
09-15-2009, 09:08 PM | #73 |
Rock Crawler Join Date: Aug 2008 Location: Tucson
Your quite skilled. This has turned out to be one of my favorite threads. Thanks. Oh yea, quick question. I used your drill and grinder method for tapering my links. Did you do it by eye or did you have some sort of mark to get them all even?
09-15-2009, 09:09 PM | #74 |
Hateraide Join Date: Dec 2008 Location: Mission BC
SSSSSSSIiiiiiiiiiick tires great job dude |
09-15-2009, 09:14 PM | #75 | ||
I marked the links all at like 3/4'' or something. cant remember the distance. Just scored it with a razor blade. Thanks. Have too see if they'll work. They're pretty tall. | ||
09-16-2009, 04:07 PM | #76 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
Good job, they look great and i bet there going to impress you on the rocks. I know what your sayn about the rain 7 days straight here.I just heard on the news some part of AK has had 9inchs of rain What size hexs are your wheels??
09-16-2009, 04:16 PM | #77 |
Thanks. Yep, the upper level low is just spinning right on top of us here in SW AR. Rain for days. TTR cvd's 12mm, then using a 12mm-23mm 1/2" adapter/widener. So wheels are 23mm,. They are just some cheap pro-line wabash revo wheels i narrowed down to 1.8" |
09-16-2009, 05:12 PM | #78 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
Shane and I had the same thought when we saw theses tires, I have my 6 here but haven't got them made yet. I saw Shane this last weekend and I looking forward to seeing them run. Good job Shane. |
09-29-2009, 10:35 AM | #79 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
shane.... im getn a super!!! may need ya to make me a set of super comp claws. be in touch w ya! |
09-29-2009, 10:51 AM | #80 |
Nice... Super sized comp claws would be cool. Just let me know. I am getting good with the moab sidewall and 2.2 half tops. If that is what you want. Have to think of a super-sized name for them. My prototype "foams" seem to be working good with the pizza cutter type tires/wheels. Last edited by Szczerba; 09-29-2009 at 10:55 AM. |
