03-09-2009, 09:16 PM | #1 |
| Shane's Comp NN Super Build
Got a clod off the board cheap. Then proceeded to dump time and money in. 17" wb with 14" width Tekin Fx-R, castle BEC, Integy 35t motors, 8tooth pinions, electric dig with the HH manly switches and HS-55 Futaba S9157 Servo Nomadio React Metal lockers, Thundertech CVD's, Hand Bros. BTA steering, Traxxas Big bores with limiters and soft springs HPI Body (After two colors, it gets complicated for me with paint) Narrow XTM Thorns (Thanks AKRCC), Now Desert Dogs My shot at plowboys (waiting on NWTT #8 Rockhammer Hybrid Squat Foams) My shot at 1/2 Delrin links(~$1.50 ft) with 8/32 thread and Revo Rod ends and tamiya mounts. Check out my method for tapering the ends . Took me a few minutes to figure it out. I'll replace the plastic clod axle parts if and when they break with aluminum. Last edited by Szczerba; 08-05-2009 at 11:41 AM. |
03-09-2009, 09:20 PM | #2 |
Quarry Creeper Join Date: Nov 2008 Location: The Darkside is strong with this one!
| Sweet Build
Very nice start. Good trick on tapering the links. I will bestarting a super build next week after some of the parts get here. Keep up the good work.
03-09-2009, 09:32 PM | #3 |
Quarry Creeper Join Date: Oct 2008 Location: Southern Illinois
Looking great, everytime I see one of these Nice super builds it makes me want one!
03-10-2009, 07:52 AM | #4 | |
I know what you mean. I finally got pushed over the edge . | |
03-10-2009, 09:38 AM | #5 |
Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
nice build! i didnt know there was a local place to buy delrin from but the place on the card is 5 minutes away from my house! thanks for the info |
03-10-2009, 10:18 AM | #6 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
sweet! glad to see another super! after i get my mini comp rig done, ill be startin a super as well! "long live the beasts!!" |
03-10-2009, 11:58 AM | #7 |
Quarry Creeper Join Date: Nov 2008 Location: morristown
nice super
03-10-2009, 03:41 PM | #8 |
whee do you get the tabs to mount the shocks onto the link? i went to norva plastics after seeing this thread and picked up a crapload of delrin. they are really nice guys over there! apparently there is like 3 companies that uses them to make their skid plates,,,but the guy couldnt give me any names
03-10-2009, 05:49 PM | #9 | |
Quarry Creeper Join Date: May 2005 Location: Crossville,TN
http://www.ckrccrawlers.com/shop/ind...oducts_id=1242 They work great. Carl | |
03-10-2009, 06:14 PM | #10 |
Pebble Pounder Join Date: Nov 2008 Location: Virginia Beach
Glad to see some new supers being built. Great start also !!!! Long Live the SUPERS !!!!!
03-10-2009, 06:14 PM | #11 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
Let me know how the foams work.
03-11-2009, 12:55 PM | #12 |
good job on the super! great job on the links too! except the right side of the third one from the bottom I plan on building a super one of these days... |
03-11-2009, 12:57 PM | #13 | |
That was the first one I did with a dremel. Then I thought up of the Drill and grinder method. | |
03-14-2009, 01:50 AM | #14 |
Newbie Join Date: Feb 2009 Location: Norcal, Davis
Cool build...Did you epoxy or bolt on those shock mounts to the delrin links? Cheers, DC |
03-14-2009, 09:30 PM | #15 |
Flattened out a small area for the mount to sit and I drilled and tapped two 3mm holes for each mount and used two 3mm screws per. I knew the two screws would probably hold but i went ahead and added a small amount of gorilla glue. Just wanted the insurance on this big rig. |
03-15-2009, 07:55 AM | #16 |
varcor.org Join Date: Aug 2005 Location: 757
hey shane, did norva cut the delrin to the lengths you needed?
03-15-2009, 08:17 AM | #17 |
"hey shane, did norva cut the delrin to the lengths you needed?" No, I just got eight 1 foot lengths off their ebay auction. Just search 1/2" delrin. They do custom lengths as well, from their auction page information. Also, you can get it in white or black. Bought 4 sets of NWTT 8# Rockhammer Hybrid Squat Foams- 4.75" dia. x 2.625" wide for the plowboy's. I took two full foams and cut one down to size to fit inside the tire. Once I got them and put them up against the tires i was concerned about the width. I automatically wanted to add more foam on the sidewalls. Well, I didn't have more foam laying around so I just took the left-overs and put them on the outside of the rears only. The weight of each rear tire is 1 lb. Two fronts are 14oz for each, (no additional weight added by me) These foams react ssssllllooooooowwww... I was at Disney, OK this past weekend and the tire/foam setup worked pretty good even in the rain. I was just free wheeling around. I have limited experience with super foam/tire setup but it seemed to work. The dense inner foam keeps the tires from rolling over, I think the tire being lower profile helps with this as well. I am going to run this setup for a while until I think I the need to change something, like more foam or stick on weight in the front. Last pictures are with all the weight of the truck on the one rear tire. Edit: Did the same thing with the foams to the front as well. Last edited by Szczerba; 03-22-2009 at 08:20 PM. |
03-22-2009, 08:34 PM | #18 |
| Couple Videos |
03-26-2009, 01:11 PM | #19 |
RCC Addict Join Date: May 2008 Location: On the rocks
Hey! Theres my wheels! You lucky dog! Crawler looks great. Im liking the body as well. |
03-26-2009, 01:17 PM | #20 |
Yeah, the wheels work great. Thanks for the deal. I use the cheapest super glue (tip from someone on the board) and the tires come right off. Good right now since I am working on the foam setup. Seems to be working good. I wanted to do a different body. Its sitting as low as possible on the NN chassis. Not too good for rollovers but i like the look and this rig doesn't rollover it climbs everything! |
