09-27-2018, 08:00 PM | #1 |
Newbie Join Date: Jul 2018 Location: Saginaw
| Lowering
Has any ever trimmed there springs to get a lower ride height. Im almost done with my build and it seem very tall even with the short barrel springs. Thank you
09-28-2018, 06:21 AM | #2 |
| Re: Lowering
Yup. Cut about 3/4" out of the stock springs. Just snipped it off, and bent the end to flatten it a bit so it sits in the perch. Then painted blue for a Fabtech suspension look. It's about 1/2" shorter than the option barrel spring. Alternately, you can limit the shock internally to lower the ride height. Just use the softest springs you can since they'll be compressed a bit. Not a bad way to go since it can be easily reversed. |
Lowering - Similar Threads | ||||
Lowering Kit | V3500 | Axial Wraith | 12 | 02-28-2013 05:21 PM |
Lowering the Wraith | cyrusd | Axial Wraith | 3 | 12-12-2011 12:59 PM |
Lowering mrc | Cole Moore | Losi Mini-Rock Crawler | 10 | 09-21-2010 05:54 PM |
Lowering my ax 10 | xxinterboyxx | Axial AX-10 Scorpion | 10 | 02-15-2009 07:58 PM |
Lowering ax 10 | AXE 10 | Axial AX-10 Scorpion | 12 | 01-08-2009 06:35 PM |
