06-17-2006, 05:52 PM | #21 |
Pebble Pounder Join Date: Feb 2005 Location: Flagstaff
Any progress? I am thinking about building a shafty stick and need some ideas!:-P
06-17-2006, 08:55 PM | #22 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
I made alot of progress on the front axle today. I got everything mounted just like I wanted. It's packaged very tight, it took alot of brainstorming to figure where everything had to go. I need to head to the LHS to get some longer screws but everything else should be set. This truck will be complete by this coming weekend, I have a comp to attend. I'll start mocking up the fiberglass chassis tomorrow. |
06-17-2006, 11:17 PM | #23 |
Well it's very interesting for sure.
06-18-2006, 05:55 PM | #24 |
Pebble Pounder Join Date: Aug 2005 Location: San Francisco
Wait so your going to have one motor for each axle? Well like run2jeepn said its going to be very interesting
06-18-2006, 07:05 PM | #25 |
Nope, lots of drive shafts Need to work on that rear upper rod end/servo mount then I can start on the frame rails. |
06-18-2006, 07:11 PM | #26 |
Pretty interesting.
06-18-2006, 07:23 PM | #27 |
Rock Crawler Join Date: Sep 2005 Location: wyckoff, NJ
it makes my head hurt but i like it!
06-18-2006, 07:30 PM | #28 |
Rock Crawler Join Date: Mar 2006 Location: Benson,NC
06-18-2006, 08:41 PM | #29 |
It looks like you're real close to the max deflection on those driveshafts (especially the front). Think you'll have a problem with binding? I wonder if a flex cable would work instead, the kind used in RC boats? Use that in the center/rear section. Might even have less friction than all those U-joints. I like it so far. |
06-18-2006, 08:44 PM | #30 | |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
06-18-2006, 08:48 PM | #31 |
Well, that'd make it really interesting |
06-18-2006, 09:19 PM | #32 |
It looks like and Inch Worm...Cool...
06-19-2006, 02:08 AM | #33 |
I've got the chassis plates all cut out, both axles finished. I just have to make the crossmembers and end pieces. I've picked up a Chevy Blazer body might be to wide though, stick chassis designs get all the flex from one swing of the axle. Something different though, I'm trying my best to build up something out of the norm. I have used mostly all fiberglass and composite plastics. Which is very odd for me as I have never built something with plastics. Pics later Gonna have killer belly clearance though around the 5'' range, without the side effects of a high mounted trans. Last edited by Mnster; 06-19-2006 at 02:12 AM. |
06-19-2006, 06:10 AM | #34 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
i'm not too sure where you are going with that big ball joint, but if you're going stick, it looks like youmay have some clearance issues with it's height. it doesn't look tall enough to clear the gearbox, and keep the spine in a straight line....
06-19-2006, 08:17 AM | #35 | |
06-19-2006, 12:11 PM | #36 |
No stick, chassis plates but the suspension should work the same. |
06-20-2006, 12:08 AM | #37 |
06-20-2006, 01:10 AM | #38 |
Rock Crawler Join Date: Sep 2005 Location: IDK
Are you going to put the bta steering on the rear axle also that would we real nice. i like the project realy bad BAd *** BAsh stick style sort of |
06-20-2006, 02:34 AM | #39 |
| I have the small problem of the front drive shaft swinging into the nut the front link is mounted with. I could solve it with a flat head screw though. |
06-20-2006, 03:57 AM | #40 |
i liked it better without the links but to bad that they are neccesery
