03-30-2007, 11:24 AM | #41 | |
RCC Addict Join Date: Jan 2007 Location: San Jose
thanks for your help..... | |
03-30-2007, 12:00 PM | #42 | |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Found the rig I was talking about here: Bulu 2 Laydown frame Last edited by LIKES2CRAWL; 03-30-2007 at 12:03 PM. | |
03-30-2007, 12:15 PM | #43 | |
what is the benifit of mounting the motor this way? Doesn't it reduce torque twist, or does it send the power of motor to left rear...? thanks dude | |
03-30-2007, 12:23 PM | #44 |
Well with it being mounted and ran that way it kinda counter balances, there is still some TT but now the motor is haning out on that side and the weight of the motor kinda helps balance it out. I don't know personaly, I havn't ran my rig like that for a while. I have my rig setup with the "REVERSE COWGIRL" method that I borrowed the idea from DUIdirk.
04-02-2007, 01:48 AM | #45 |
Thanks Likes 2.....how do you like the reverse cowgirl....? Have you noticed changes? |
04-02-2007, 01:57 AM | #46 |
| It's nice, could be a little lower in gearing but kinda hard to do, so right now I'm around 40:1 gear ratio so it's got fair wheelspeed and descent low-end. The brushless helps alot too though. |
04-03-2007, 02:03 AM | #47 | |
Cool stuff......How do you figure out your gear ratio.....? I am running pede tranny with tlt axle and everything is stock... Also, 55t motor with 12t pinion and 84 spur... Could you tell me what ratio I have.....? thanks for the help | |
04-03-2007, 02:50 AM | #48 | |
2.72 for Pede trany 2.66 for TLT axles | |
04-04-2007, 06:29 PM | #49 |
Thanks likes2crawl......! So, in the world of ratios for crawlers.........How is that ratio? thanks for the help! |
04-04-2007, 06:41 PM | #50 |
That depends on what you want to do. If you are running six subc cells, that is a decent ratio for crawling. On my daughter's comp SW2 rig, she has a pede tranny, with 14/84 running on 8 2/3A cells, with a 55 handwound motor. With the throttle profile in her mamba max, it creepycrawls, but still retains a little wheelspeed when needed.
04-04-2007, 06:56 PM | #51 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
41.96 is mine, Stampede trans 55t lathe TLT axles 15/87 |
04-05-2007, 01:30 AM | #52 |
| Like Tanis says with the right amount of juice on 6 cells it's decent add 1 or 2 more cells and you got good control with nice punch for wheel speed. |
04-05-2007, 11:02 PM | #53 |
Thanks for the input.... |
04-06-2007, 04:09 PM | #54 |
Rock Crawler Join Date: Apr 2006 Location: pasco,Wa
04-06-2007, 07:25 PM | #55 |
Yeah, but on 8subc cells, I noticed you still have plenty of wheelspeed to get the front end to slide when the dig is engaged. Either mine has too much traction on the rear tires, or I don't have enough wheelspeed. I'm upgrading to the Novak Crawler system real soon. Hijack mode off. Back to TT.:-P |
04-08-2007, 11:37 PM | #56 |
Pebble Pounder Join Date: Sep 2006 Location: Spokane
Interesting article. Thanks again Rockmike and Tanis for the info you gave me at the comp. Did some drilling and changed the angle of my upper links, now my T/T is at a minimum and the crawler seems to do alot better. Hope to crawl with you guys again soon.
04-09-2007, 09:17 AM | #57 |
good deal glad to hear it,keep that chassis as light as you can this always helps matters.I was in e-burg this weekend found some killer crawlin,managed to break 2 drivlines.I blew out both rear shock seals,and my t.t. came back with a vengence.Now i know my dual stage pistons are deffinatly helping the t.t. cause without that oil in there it was a differant truck.
04-09-2007, 11:59 AM | #58 | |
04-09-2007, 02:12 PM | #59 |
| weel what hapened was it broke were i turned off the splines for my dig setup so there a little weak there.Then i just did a trail fix on it and it worked for a while,then failed again.I met my daughter up there for easter breakfast.
04-09-2007, 03:50 PM | #60 |
Alright Mike, spill the beans as to where this spot is. I haven't had a chance to check out E-burg yet, but I expect there is good rock up there. |
