04-24-2005, 04:19 PM | #141 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
04-24-2005, 06:29 PM | #142 |
Quarry Creeper Join Date: Oct 2004 Location: l.C.
hey bender any luck with those photos? i am going to be honest with you. i am going to use your idea and make a set of servo mounts like yours. hope this is ok... i really like your setup |
04-24-2005, 06:59 PM | #143 | |
Use any idea you want, I'm not the first one to do the steering behind the axle. | |
04-24-2005, 09:34 PM | #144 | |
Funny because they're covered in about 3 inches of dust. | |
04-29-2005, 09:49 PM | #145 | |
04-29-2005, 10:03 PM | #146 |
I had to flip the knuckles upside down for the tierod to clear the servo horn. If you use a smaller diameter tierod it won't sit so close, my tierod is 3/8" diameter. Also at full compression of the suspension in that front corner, the upper link almost touches the top of the servo. It's a tight fit without bending links for clearence. It's hard to see in the pics, but here's a few more....... |
04-29-2005, 10:52 PM | #147 |
Rock Crawler Join Date: Dec 2004 Location: Land of the Free, because of the Brave
| I gotta tell 'ya man, I get a kick every time I see this thread pop up under "new posts." When you hover over it, it reads "Hey all, I'm new to this site, just thought I'd show a few pics of my TXT" Seems like a lifetime ago. I do dig the rig though. I've got another shafty in my head as well. I just wish I could decide on axles. It's probably gonna be either a humongous tuber with x-factor axles and the new jumbo swamp kongs, or a large "scale" crawler with txt axles. I'm still undecided. I just wish Gmade would release their new axles so I could quit waiting... |
04-29-2005, 10:56 PM | #148 | |
04-30-2005, 07:53 AM | #149 |
bender, thanks man. the pictures are perfect. that is just what i needed. your rig looks great... |
04-30-2005, 06:43 PM | #150 |
bender, are you running the rear setup behind the axle too? or do you think it would get "hung up" to much?
04-30-2005, 08:08 PM | #151 | |
05-02-2005, 12:33 AM | #152 |
| Finally rotated the tranny!!
I started messing around with rotating tranny yesterday, the mounts are temporary until I can machine something a little beefier. Some pics..... |
05-02-2005, 09:23 AM | #153 |
Rock Stacker Join Date: Jan 2005 Location: Saint Louis MO
Looking good. I see you are running a dual rate spring now also. I was running somthing like that for a while and liked it. Now I am experimenting with drop travel. Have you run the truck yet with the rotated tranny? When will we get to see the eye candy of the custom machined shinny bits? |
05-02-2005, 10:25 AM | #154 | |
I have been running the dual spring set-up on the right rear for a few months now and it works great!! Keep us updated on your new suspension design. I crawled with it yesterday for a little while and rotating the tranny made a big difference!! Once I get some better bracing machined, I'll post some pics. | |
05-02-2005, 04:14 PM | #155 |
RCC Addict Join Date: Apr 2004 Location: 5280
Damn bender, looking good. I gotta see how the rotated tranny works out on Thrusday. Hopefully here after the next two weeks are over, I can get some good time in messing with mine.
05-02-2005, 05:50 PM | #156 |
Pebble Pounder Join Date: Apr 2004 Location: Aurora
Hey Bender how did you attach the tranny to the frame with it being clocked at that angle? Looking good!
05-03-2005, 02:40 AM | #157 | |
I fabbed a couple brackets out of some 1/16" alum scraps I had laying around. First pic, bracket mounts to stock hole on side of tranny and to the chassis plate. The second pic, I drilled a stock crossmember and bracket ties that to one of the shaft ends in tranny. New mount will attach to both shafts. They are just for mock-up and testing, until I get it exactly where I want it. Then once it's dialed in I'll machine some beefier/better looking mounts and I'll probably add 1 more mount to it once it's dialed. I'm trying to get the bottom of the tranny high enough in the chassis so I can machine a flat delrin skid for the underside of the chassis. Here's a couple more pics...... | |
05-03-2005, 08:41 AM | #158 |
Quarry Creeper Join Date: Mar 2005 Location: The Dark Side
| Tipping the trans
I've been trying to lay my trans on it's side but the mounts are tricky because they're not at 90 deg angles. I can't wait to see your finished mounts. Also, your rig ROCKS!!!!!!. I've sucessfully used many of your innovations on my Jugg. Thanks for All the Help and Tips!!!!!!! |
05-03-2005, 01:10 PM | #159 |
Looks super nice there Bender. I cant wait to check it out in person, since your pics just never seem to do the truck and your work justice!!
05-14-2005, 12:11 PM | #160 |
Newbie Join Date: May 2005 Location: Aussie in Sin City
| Bender
Awesome truck dude!!!! very inovative, I am going to use some of your ideas in my own rig i am just a newbie at rock crawling but have been involved in racing off and on road both here in the US and in Australia for many years I have had the TXT1 for nearly a year but havent had much time to use it I was also thinking about clocking the tranny so i can fit a flat skidplate. It"s just an idea but Im thinking of ditching the stock tranny and replacing it with a Traxxas tranny, the same as they do with the TLT's The reasons behind this idea are as follows; Smaller, will be able to rotate inside the chassis and align the driveshafts more directly to the diffs without such extreme angles as there are with the stock tranny being clocked I can still mount up a GD600 reduction unit As I said just an idea but I would be interested on your thoughts about this modification Thanks in advance Bunyip |
