02-28-2011, 02:35 AM | #21 |
Quarry Creeper Join Date: Aug 2010 Location: Brisbane Australia
How much wider does this make the front from hex to hex if possible and any clue as to what the gear ratio is in those 3 racing fronts? Am thinking using this in the front with a wider axle and bigger shocks for the rear.
02-28-2011, 09:48 AM | #22 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
man this is looking awesome. what wheels are you using? |
02-28-2011, 10:57 AM | #23 | |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Thanks to everyone for the positive coments. Quote:
Thanks, Integy alloy 8 hole wheels with the 0 ofset hubs, they are pin mount btw. Last edited by chino63; 02-28-2011 at 11:00 AM. | |
02-28-2011, 12:17 PM | #24 |
03-01-2011, 11:53 PM | #25 |
After reading through a ton of threads, I decided to take some cues from miniwheelers 4-link setup. This in my opinion seems to be the best functioning 4-link for the CC-01 chassis. A couple things I wanted were performance and that nothing got hung up on the rocks. I used the same ideas that he came up with but in a slightly different configuration. First off I needed lower link mounts that created a smooth transition from link to axle without anything hanging below the tube. I like how Jim's mounts keyed into the original lower link clearance slot on the axle so I went with that on mine as well. I used 18g steel for the bracket C and some fab tabs from RCP Crawlers as well as a gusset on the bottom to strengthen the tabs. Next was the upper mount. I brazed some nuts to the ends of the truss which retains the lower link brackets and added a 3rd support for addtional strength. Again, I used a couple of fab tabs with a plate gusset to attach the upper links. And here it is all mounted up. Here you can see the plate that supports the lower links at the chasis, should be way strong. It might be too tall. I might put some smaller tires on it to help with the CG (2 3/4" under the rails). Gotta run it first though. |
03-02-2011, 12:10 AM | #26 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
damn clean 4-link set up! like the use of the nut-serts in the upper chassis plate too |
03-05-2011, 07:59 PM | #27 |
Rock Crawler Join Date: Nov 2005 Location: dallas
Just keeps getting better |
03-05-2011, 08:01 PM | #28 |
Made a little more progress, just a few things left to do and it's play time. I wanted a smooth flatter undercarriage which required a 2 piece driveline due to the extended wheelbase. Not a fan of a really long driveshaft to kill my breakover. I used a hilift driveshaft for the front half and ran it through a carrier bearing . Then I used a short Junfac CVD driveshaft for the rear portion. Using some 22 gage steel, I made a skid plate for it that would protect the entire front half of the driveshaft as well as add support to the carrier bearing bracket. I will replace all the buttonheads on the bottom with countersunk hardware during final reassembly. As you can see in this picture, nothing to get hung up on and the driveshaft is well protected. I also made a front bumper for it that is more functional than aesthetically pleasing. I wanted to make sure it won't get caught up on the rocks and stop me cold during a comp. A fairlead will be installed on the middle piece. Servo winch on this thing for reliability and super slow line speed. A little paint to help hide the ugliness. A few more pics of it 90% complete. Not digging the orange but too late now. I also made a battery holder to keep my Lipo's where they belong. |
03-05-2011, 10:23 PM | #29 |
Holy crap Dean that thing is mad!! This has to be one of the best working CCO1 ever Now your making me rethink the direction i went with mine |
03-05-2011, 10:50 PM | #30 |
man i wanna copy this thing so bad!!!!! i like the orange, imho i would put an orange stripe around the edge of the wheels. |
03-05-2011, 11:08 PM | #31 |
| MRW bead locks |
03-06-2011, 05:01 PM | #32 | |
BTW, class 2 is calling you. Have at it, copy away! | |
03-08-2011, 06:38 AM | #33 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
WOW looks amazing good jobb
03-08-2011, 07:56 AM | #34 |
Rock Crawler Join Date: Jul 2008 Location: Williamston
I have been pondering this for too long now. Very nice work! Now, I know what to do! Thanks for the great idea! Todders |
03-08-2011, 08:24 AM | #35 |
RCC Addict Join Date: Feb 2006 Location: Bellflower, CA
Your making want to get my CC-01 out and do a quick rebuild. Thanks alot! One of the cleanest CC-01's out there. Wait...it is the cleanest!
03-08-2011, 03:00 PM | #36 |
RCC Addict Join Date: Mar 2009 Location: hawaii
awsome work man!! im lookin to get one of these for my daughter, i keep changing my mind back and forth if i really wanna get this kit and your convincing me to get it lol! your work is top knotch!! cant wait to see how it performs |
03-11-2011, 10:27 PM | #37 |
Pebble Pounder Join Date: May 2008 Location: El Monte
custom portals. custom skid plate. eventually custom everything. build by none other that the O.G. himself. FTW! |
03-15-2011, 02:54 PM | #38 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Damn Chino, you weren't kidding, that little thing is bad ass, hopefully I get to see it tomorrow. |
03-16-2011, 12:25 PM | #39 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
This build has made me get my CC01 off the shelve and modify it for the better,thanks, |
03-19-2011, 06:25 PM | #40 |
Quarry Creeper Join Date: Jan 2009 Location: Pacific Northwest
Is it me? Or are the photos gone? Id really like to see this rig!
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/tamiya-xc-cc01/302167-high-clearance-cc-01-power-portal.html | ||||
Tamiyagekken - Toon onderwerp - Portaal assen op XC? | This thread | Refback | 02-16-2013 02:23 PM | |
Access Denied | This thread | Refback | 10-07-2011 02:21 AM | |
Access Denied | This thread | Refback | 10-07-2011 02:13 AM |
