08-29-2018, 09:41 AM | #1 |
Rock Stacker Join Date: Jun 2009 Location: Central New Jersey
| Recommended upgrades while building
Hello everyone! I’m back into RC after about 8 years and picked up a CC01 and CR01 to start out! Before I start building my CC01, I’m wondering what you all consider that most important upgrades to make while building for the first time! Thanks! Jon! Sent from my iPhone using Tapatalk |
08-29-2018, 01:46 PM | #2 |
Rock Crawler Join Date: Mar 2015 Location: Waltham
| Re: Recommended upgrades while building
A set of bearings and simply not installing the front bumper would be a good start. If you're planning on trailing with it you'll likely want to lock the front diff. A cheap 35T or higher motor can be beneficial to slow the truck down bit. It's geared for speed more than torque. Beyond that, the steering (both slop and throw) will be the next areas you'll likely want to address. No one answer there. Have a look through the forum and see what has worked for folks. Good luck! |
08-29-2018, 01:59 PM | #3 | |
| Re: Recommended upgrades while building Quote:
Thanks for the tips! I’ll start doing some research! Sent from my iPhone using Tapatalk | |
08-29-2018, 02:14 PM | #4 |
I started off with a CC01 and I think looking back the best mod was locking the diffs but that had a double edged effect in making it much easier to strip the tiny, tiny splines on the axles. Tires would also be a good upgrade but make sure to check sizing as you wont be able to fit anything other than tiny tires (depending on the body). Steering linkage needs upgrading for sure, a few companies make them and I believe the GPM kit tends to come loose very easily and folks have had better luck with the Yeah Racing kit Beyond that I would say dont mod too much or expect any miracles, if you find yourself wanting a lot more from the performance I would have to recommend stepping up to a 1.9 rig from on of the many manufacturer's. I personally dumped a bit too much into a CC01 only to find myself breaking it frequently and not getting huge improvements I wanted. It was a great introduction but I've since moved on to axial, Gmade and Vaterra offerings which take to modding much better. I think I've grown to prefer a lightly modded CC01 |
08-29-2018, 04:15 PM | #5 | |
I realize that it’s not the best truck on the market. I got a great deal on it and said what the hell! What you’ve recommended is perfect. I’ve heard about the steering issues and will probably pick up that Yeah Racing kit before I build! Thanks! Sent from my iPhone using Tapatalk | |
08-30-2018, 07:16 AM | #6 |
I agree with pretty much everything here. I can't believe I forgot to recommend tires! I had the GPM steering kit installed. It worked well for a bit, but loosened up. I then JB Welded the top connection. That helped a bit, but the bottom still loosened up. I just swapped over to the Yeah Racing kit, but haven't had a chance to run it yet. There's definitely more engagement area between the parts of the primary steering shaft. That's encouraging. |
Recommended upgrades while building - Similar Threads | ||||
Recommended Mods and Upgrades for Barrage BTD | Mongol Pete | Newbie General | 11 | 12-11-2017 03:30 PM |
Recommended Upgrades??? | orangebloodtex | Newbie General | 7 | 12-17-2010 11:31 AM |
Recommended Upgrades for the CR-01 Land Cruiser?? | 1SweetRide | Tamiya CR-01 | 7 | 06-06-2010 02:54 AM |
recommended upgrades | warDialer | Venom Creeper | 8 | 07-19-2009 05:18 PM |
recommended upgrades for basher AX10 | Canz Crawler | Newbie General | 8 | 01-25-2008 09:41 AM |
