Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Alex's SuDu 2.2s.
Old 03-22-2013, 06:41 AM   #21
Default Re: Alex's SuDu 2.2s.
Originally Posted by Lukescb7 View Post
Looks great. Love the front axle plate. I would buy one for sure.
Thanks
Please this thread is not a feeler.
Originally Posted by Olle P View Post
Won't the shock absorbers mounted that far out from the centre get in the way for the wheels when you turn?
(But then again, add enough caster angle and they won't...)
I don't see major issue coming with the tires on. Only clearance issue I might have is between the rod end and the c hub adapter. But that can be easily fixed.
I cutted some al cross braces for the chassis.
To do list
-Cut the revised cf motor plate.
-Knock off as much weight as I can from my HR idle gear.
-Mount the C hub adapter when I get them
-Make some steering link
AlexG is offline   Reply With Quote
Old 03-22-2013, 06:53 AM   #22
I'm just curious, can you flip the lower rear links, so that the bend is closer to the axle?
Tgreer is offline   Reply With Quote
Old 03-22-2013, 07:04 AM   #23
Yeah I could, but that will leave the shaft exposed.
Sometimes to much clearance in the link can hurt the progression.
Old 03-22-2013, 08:58 AM   #24
WAM
Looks like you have barely any shock shaft shining thru those limiters. Is it as limited as it looks?
(Looking at post #18 on the jig)
WAM is offline   Reply With Quote
Old 03-22-2013, 09:34 AM   #25
Originally Posted by AlexG View Post
Thanks
Yup, not a feeler. Just saying its looks to be a very well made piece.
Great build. Cant wait to see some videos and action shots of it.
Lukescb7 is offline   Reply With Quote
Old 03-22-2013, 10:30 AM   #26
Yeah my shock definately need some attention, but that's not as drastic as it look. Travel seem to be OK but I'll like a little bit more.
No problem man, just wanted to get it clarified at least once in the thread
The front plate will do for now but later I'll try do a plate with the servo and the batt under to get everything as low as possible.
Old 03-25-2013, 04:10 PM   #27
Most work on the trans is done so I putted it on the scale.
The trans is weightin 47g with HR gear and with my motor 198g. I started at 215g with a "stock" 15t crawlmaster medium fill. The weight lost is coming from the motor, the motor plate and the trans shaft. The HR gear are heavier than stock.
Also I milled the skid to mount the trans 2mm lower. I think I can remove 2 more mm, we'll see.
I'll try to get pic later.
Old 03-25-2013, 04:45 PM   #28
Got some new wheels made for this truck to test.
Old 03-25-2013, 07:37 PM   #29
Any pics of the motor plate?
Old 03-26-2013, 04:15 AM   #30
Here's a shot of the motor plate, I removed more material from the skid, my motor is sitting dang near the chassis. 3mm lower than stock is safer for proper gear mesh adjustement.
Old 03-26-2013, 07:52 AM   #31
That is awesome. Love all the carbon work on this rig. you made the rims also? This is motivating me to finish my losi build.
Old 03-26-2013, 08:35 AM   #32
Thanks man yes the wheels are home made, I made them to replace the first one in the post. One wheel had a crack and these rims are the first I made, since then I updated slightly my dimensions so they in the trash.
Old 03-26-2013, 12:37 PM   #33
Wheels and tires done.
I removed some material from my hubs on all 4.
So here's the weight
Front tires.
TAG Mach 12 3pcs wheels, 225 slw axial hub, shaved rover's and DD 5.0 soft
Rear tires.
Flipped TAG Mach 12 wheels, 225 slw losi hub, shaved rover's and sedona foam.
Lastly I added a cf braces to stiffen the chassis. I can't believe how much this simple mod can help
Old 03-26-2013, 02:07 PM   #34
Excellent move with the chassis stiffener!
That tranny is just awsome! Is there any room for the middle gear to move up and allow the motor to sit even closer to the tranny?
Old 03-26-2013, 02:51 PM   #35
I was thinking about moving the motor but never got around to do it, now you got me thinking.
I'll play a bit with the cad and see if I can move stuff around and send the files to Pete.
Old 03-26-2013, 03:53 PM   #36
WAM
Lastly I added a cf braces to stiffen the chassis. I can't believe how much this simple mod can help.
That's interesting, but you are still using lexan side plates which are pretty wimpy. Once you change to a stiffer material like CF or aluminum, I wonder if the diagonal brace will still make a noticeable difference.
Not a feeler (), but do you or your buddies have plans to produce some of your nifty CF plates etc?
Old 03-26-2013, 04:12 PM   #37
The braces is there for the polycarb chassis because it's def too flexy.
I know I'll switch to cf later but I'll like to try this one first and would like a flex-less chassis.
The light tranny component will be part of the TAG arsenal for the losi comunity . Not the front plate and the shark fin.
Old 03-28-2013, 03:50 PM   #38
Well it seems that I have enough parts to build a set of scx10 shock. I think I'll put them on, they re mix and match shock but I'll have the little extra travel I'm looking for.
Old 04-02-2013, 08:25 PM   #39
Rig looks Good. really like your thinking, a lot of really cool pieces.
Jared_M is offline   Reply With Quote
Old 04-06-2013, 02:59 PM   #40
Thanks man I really appreciate
Got the v2 motor plate finished, thanks for the input Thommy!
As I mooved the idle gear bracket higher I decided to give the other skid a try.
It just feels better not having the motor hanging so much and the driveshafts don't bind so I think that's the way to go
Alex's SuDu 2.2s. - Similar Threads
SuDu One - 2.2s / Sportsman chassis Tomy Axial AX-10 Scorpion 256 09-08-2015 06:51 AM
Alex's berg take I AlexG EnRoute Berg 195 06-07-2014 07:09 AM
NCD SuDu one crawler douwe Videos! 2 11-28-2012 02:36 PM
Alex's Axial whitty Axial AX-10 Scorpion 6 08-07-2008 02:57 AM
