03-29-2012, 07:16 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
| sealing a tire
ive sealed tires with tears on the before,but never with hole. i have some vented losi comp claws and i want to seal them back up. does anyone have any tips or special tricks to seal tires up because i cant find anything.
03-29-2012, 07:40 PM | #2 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: sealing a tire
What did you search? Why do you need them sealed again?
03-29-2012, 07:41 PM | #3 |
| Re: sealing a tire
i serached how to seal rc car tires and it just came up with patching holes in wheels. i bought them from a guy on here and they had holes in them and i want to seal them so they are waterproof
03-29-2012, 07:43 PM | #4 |
| Re: sealing a tire
Have you tried searching any other terms? Maybe using the advanced search option? And what type of rig will they be run on?
03-29-2012, 07:49 PM | #5 |
| Re: sealing a tire
im running them on my ax10. i wonder if ther's a way to put a plug in them like a real tire
03-29-2012, 07:52 PM | #6 |
| Re: sealing a tire
Ok but what TYPE of rig? TTC, scaler, sportman, pro, etc.
03-29-2012, 07:57 PM | #7 |
| Re: sealing a tire
it's a sprtsman i guess
03-29-2012, 08:08 PM | #8 |
| Re: sealing a tire
Depending on the size of the hole you may be able to patch it with some CA glue. But if it's bigger I don't know. Personally I'd leave them, any water will drain out anyway.
03-29-2012, 08:10 PM | #9 |
| Re: sealing a tire
well. its a comp crawler but i use it for just crawling around outside. the holes are about 3mm
03-29-2012, 08:56 PM | #10 |
I wanna be Dave Join Date: May 2006 Location: akron
| Re: sealing a tire
If you have a spare tire you can just use a hole punch to make a 3mm Plug.. then just glue in with some IC2000..
03-30-2012, 12:52 AM | #11 |
Quarry Creeper Join Date: Jan 2011 Location: murrieta
I'd cut a piece off of an old tire (larger than the hole) and glue it onto the hole from the inside of the tire. Simple and easy.
03-30-2012, 01:19 AM | #12 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
| Re: sealing a tire
I used Shoo Goo. I wouldnt leave them be though. That junks your foams pretty quick. And makes them smell god awful. That may not be a big deal if you keep them in the garage but I keep mine in my man cave. I can't have 5-6 trucks in there with each tire smelling like an old wet sock. Last edited by Brainstain; 03-30-2012 at 01:21 AM. |
03-30-2012, 09:00 AM | #13 |
Rock Stacker Join Date: Jan 2012 Location: Fuquay Varina
| Re: sealing a tire
+ 1 on the Shoo Goo. I did this and have had no leaks or problems. I have also used a combo of both Shoo Goo and electrical tape.
sealing a tire - Similar Threads | ||||
Sealing up a bec? | Savage03 | Electronics | 12 | 03-29-2012 11:56 AM |
Sealing HPI/Axial diffs | KuJo | General Crawlers | 10 | 02-15-2011 11:20 PM |
Pin Tire with Comp Tire Sidewall - How To Write up | Kraqa | Tires and Wheels | 16 | 08-27-2010 11:55 PM |
Sealing up a mopped? | headhunter555 | Electronics | 0 | 03-05-2009 02:17 PM |
Sealing a Carbon Chasis | Cycleeric | General Crawlers | 6 | 11-25-2008 09:18 PM |
