05-21-2018, 10:25 PM | #241 |
Rock Stacker Join Date: Jan 2017 Location: Athens, Greece
| Re: Duratrax 1.9/2.2 Scale Tires
Here are my DeeppWoods 2.2 on my "shafty". Shaved sidewalls, clipped lugs and sipped... |
05-22-2018, 03:08 AM | #242 |
Pebble Pounder Join Date: Jun 2015 Location: Netherlands
| Re: Duratrax 1.9/2.2 Scale Tires |
05-22-2018, 04:13 AM | #243 |
^^^ First time I've seen those 3d-printed window slats mounted up on the Tactical TRX-4 body - looks a million times better than before! Wheel/tire combo adds to the uniqueness... |
05-27-2018, 06:06 PM | #244 |
Quarry Creeper Join Date: Dec 2012 Location: okc
So had some Tower hobby coupons and got a set of deepwoods c3 tires pre glued on their wheels. not as impressed with them as I am with the showdown cr. the deepwoods feels just a little softer. it also didn't clean itself as well as the showdown. also traction was just a little less on the deep woods. this was all just first impression so will do some more runs on both before I decide which one I like best.
08-10-2018, 09:35 PM | #245 |
Rock Stacker Join Date: Dec 2013 Location: Omaha
So, I ordered a set of 2.2 deep woods. I really liked the reviews and price. Although, I have a problem with them. For those of you that mounted them on bead locks. Was the bead shaped right on the inside? I’ve noticed the outside is just like my stock axial tires, but the inside is not molded the same. It’s too thick and doesn’t have the correct step molded into it to fit the inner bead lock ring. Was this an issue for anyone else? The axial tires are perfect and sit nice and tight. Before ever bolting down.
08-18-2018, 01:26 PM | #246 |
08-19-2018, 11:32 AM | #247 |
Quarry Creeper Join Date: Nov 2013 Location: Omaha
I am very impressed with these tires on clay dirt woods trailing and limestone. Sent from my SM-G930V using Tapatalk |
09-12-2018, 12:46 AM | #248 |
Newbie Join Date: Aug 2018 Location: Sorel, Quebec, Canada
Got 2 sets of 1.9 Deep Woods premounted. One set is my main on my TRX-4. Great traction but I sometimes feel like they're a bit too soft and twisty. 2nd set was for my Barrage. Were nice but I wanted it a bit more sitted on ground, so I went with a set of Hyrax in G8 mounted on Impulse beadlocs with those brass weights to fit in. Was perfect. 2nd set is now my main on the SCX10-2 I purchased some weeks ago. All in all, pretty satisfied for the price I paid. But they'll eventually end up in spare sets as I'll buy other tires to try. |
01-16-2019, 08:30 AM | #249 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
Does anyone run the 1.9 scaler tires? I'm curious and I love the look of them
01-18-2019, 09:10 AM | #250 |
Rock Crawler Join Date: May 2012 Location: Central PA
I just mounted up some new Showdowns to try out. Used SSD wheels and CI Lil Nova 4.25 soft inserts comp cut for the front and soft standard cut for the rears. Didn't get to try them yet but they feel excellent and I think they look pretty cool overall. The price was excellent so thought I would give them a try plus I like the aggressive look. Going to try them out on my Carisma Coyote. |
01-27-2019, 10:44 PM | #251 |
First time out with my new Carisma Coyote today along with the first time out on my new Duratrax Showdowns. I have to say they worked great and for a cheaper tire I have zero complaints on the overall performance of the tire. The tires along with the CI LIttle Nova 4.25 foams was and excellent combo. It was 40 degrees out today with the a little ice in spots along with a few wetter areas with a little mud. The truck went pretty much anywhere I wanted it to go. Had no problems crawling up rocks, logs and anything else I tried to go over. I been on this trail before with my Ascender with Rock Beast XL tires and my Carisma with the Showdowns went thru all the same places with no problems. Overall the new Showdowns where on point all day long. Last edited by wyd; 01-27-2019 at 10:49 PM. |
01-28-2019, 08:31 AM | #252 |
RCC Addict Join Date: Nov 2010 Location: England
Liking the look of those Showdowns. I like the Deep Woods, but got some Gmade MT1904 on Gmade alloy wheels on a used Ascender. I actually like them more than the Deep Woods. The 1904's have a squarer shape to them, whereas the Deep Woods are more rounded. This seems to help grip better in the leafy, rooty dirt I drive in. Not sure what foams are in the 1904's. I need to get some more foams for them sometime to compare better. |
01-28-2019, 09:59 AM | #253 |
RCC Addict Join Date: May 2015 Location: Price Twp.
I have two set of these tires and have run them intermittently for a year now. I say intermittently because I actually switch out my tires depending on the conditions I am running on, but they have seen significant use. I am running the Deepwoods in 1.9, mounted and 2.2 unmounted versions. These are NOT good tires by any stretch of the imaginations. Sure, they look good, but that have some serious flaws. Unlike most tires I have uses, these flaws get worse with good foams, not better. The construction of the tires lacks any internal stiffness. By that I mean when they do hook up the lugs actually fold back and release the rock they were hooked on. Plus the tire is so thin that they will they will stretch and roll sidehilling even with good foams. If you are looking for less expensive tires to bash around with, trail, or stomp in the woods these tires are passable, maybe even pretty decent. If you plan on using these for any type of rock crawling, or a heavily powered rig you might want to give them a hard pass. |
02-11-2019, 02:56 PM | #254 |
Just a follow up to my other posts. Took my Coyote out for the 2nd time on the my new Showdowns. It was 30 degrees out and the trails where 90% dry with some water crossings if you wanted to go in the water but at 30 degrees out I opted to stay out. The tires once again worked great. We had 6 of us out trailing and the guys where all impressed by how these tires where working. Had a few places that only my Coyote was able to make which I was surprised as we have 2 TRX4's and a Axial with portals and non of them could make it. In all fairness the Showdowns where a more aggressive tire than what they had but we where on totally dry area. If I would of know these would of worked this well I could of saved a lot of money and not bought all the other tires I have as they work as good as my really expensive tires if not better. I'm not into Comps so don't care that they are 4.74" sized tires as I just care that they work great with the CI Lil Nova 4.25 inserts I put in the tire with the SSD steel wheels. Last edited by wyd; 02-11-2019 at 03:02 PM. |
02-11-2019, 04:00 PM | #255 | |
| Re: Duratrax 1.9/2.2 Scale Tires Quote:
I almost feel like the Deep Woods would do better if you shaved down the height of the lugs. Last edited by soze; 02-11-2019 at 04:03 PM. | |
03-19-2019, 10:27 PM | #256 |
Rock Stacker Join Date: Feb 2019 Location: Los Angeles
Actually got some really good performance out of my 1.9 Deep Woods from swampy streams and wet rock to grippy desert-style rock crawls in Vasquez Rocks here in socal. I think they look sick too, but I found that after just 8 or 9 packs through the truck they started looking really rough and became even saggier. The text on the side rubs off and looks janky since it's not raised and is just silkscreened onto the flat sidewall. Since I had a new set of 2 in the box as spares I ended up ordering another pair and am going to swap fresh ones on and go again until I think they look janky again. The foams also disintegrated due to some really extreme crawls I was doing I guess. Is this due to moisture as well or was I just twisting the tires too much? I know the stock foams aren't great but they worked decently when they're fresh and new. I figure the foams last just about as long as I can put up with how ugly the tires get so I'll run these for another 8-10 packs and go with some Super Swampers or BFGoodrich scale tires on the next revamp. This particularly thrashed tire/foam was off the rear where most of the twisting was happening on extreme grades: Last edited by jessedacri; 03-19-2019 at 10:31 PM. |
03-24-2019, 05:00 PM | #257 |
Newbie Join Date: Jun 2018 Location: Bracebridge
Can the while lettering be removed? Not a fan of the white letters. |
03-24-2019, 06:17 PM | #258 |
Yep, it wipes right off with a little acetone (nail polish remover) on a rag.
03-24-2019, 06:21 PM | #259 |
Try some decent Crawler Innovations foams before you give up on them.
03-24-2019, 07:20 PM | #260 |
Duratrax 1.9/2.2 Scale Tires - Similar Threads | ||||
New scale wheels and tires from Duratrax | TwistedXT | Tires and Wheels | 11 | 07-17-2010 02:20 AM |
Axial Scx10 and Duratrax Scale Run | ebbet | Scale Videos! | 3 | 01-28-2010 09:01 PM |
Duratrax Warhead tires | mulchman | Tires and Wheels | 1 | 03-01-2007 03:29 PM |
