12-14-2019, 06:50 PM | #21 |
Pebble Pounder Join Date: Sep 2018 Location: Canada
| Re: Best tire for snow crawling?
I think I'm going to pull out my 1/12 Exc barrage and throw some large 2.2 tires on there. Its probably half the weight of my tf2 so that will help with floating. Also I'm picking up some gmade R1 portals for cheap ill throw on it |
12-16-2019, 06:55 AM | #22 |
ive been running bfg all terains the lugs are shallow and the snow dosent seem to stick to them as much as my more agressive tires alowing them to do there job also the redcat gen8 stock tires with no foams did realy well in the snow maybe hit the tires with some wd40 before going out crawling to keep the snow from sticking to the tires the best over all has been the clodbuster with some cheap team assiated 3.8 buggie wheels 6.5x3 that thing is unstopable in the snow also i know its kinda a dirty word but the yeti xl is one hell of a snow basher for in fact thats the main reason im keeping it lol gen8 foamless https://youtu.be/6Wj9au9VquU the bfgs https://youtu.be/jseoP5B-eIk Last edited by ferp420; 12-16-2019 at 07:01 AM. |
12-16-2019, 07:06 PM | #23 | |
| Re: Best tire for snow crawling? Quote:
Got some Pitbull rock beast XOR 2.2 tires on the way, the website claims to be 5.25-5.5" tall and 2.25-2.5" wide depending on the rim width. I feel this tire will be killer in the snow considering the width of these bad boys. Probably won't see them till after the new years considering how busy this time is for postal service. | |
12-16-2019, 07:57 PM | #24 | |
Rock Crawler Join Date: Jan 2019 Location: Calgary
The tire itself has no traction, the snow stuck to it and sticking to the snow on the ground does. | |
12-16-2019, 08:04 PM | #25 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
In his first post he says 6+ inches of snow. No tire is going to move his truck through that, especially a 1.9. You need these: https://www.imex-model.com/product/I...9.html?cid=131 Or these: https://store.rc4wd.com/Mud-Slingers...res_p_752.html https://store.rc4wd.com/Rock-Crusher...res_p_753.html Last edited by Thorsteenster; 12-16-2019 at 08:10 PM. |
12-16-2019, 09:22 PM | #26 | |
Those tires are MONSTERS, defiantly couldn't fit those on my RC's. | |
12-18-2019, 07:57 AM | #27 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
If I was buying a tire just for snow, I'd probably do a Pitbull XOR tire. You're going to want a wide tire for flotation and deep lugs for grip, with a wide tread spacing for tire cleaning. I think the XOR clicks all of those boxes. I've got some 2.2 XORs on my Yeti. Maybe I'll take it for a rip this weekend and see what happens. We just got another 6" of snow last night. |
12-18-2019, 01:58 PM | #28 |
RCC Addict Join Date: Jun 2016 Location: Germany
I use Sand Pows 2.8 on my little monster to have fun in the snow |
12-18-2019, 02:16 PM | #29 | |
12-18-2019, 02:26 PM | #30 |
| Re: Best tire for snow crawling? |
12-18-2019, 02:44 PM | #31 |
Quarry Creeper Join Date: Jan 2009 Location: WA state
Cut RC4WD Mud slingers with thin soft foam and on wide Redcat E-10 wheels worked well for me. These are the 2.2s, which aren't much bigger than 1.9xls. On a side note 2.8 Proline TSLs work pretty well |
12-20-2019, 06:36 PM | #32 |
| Re: Best tire for snow crawling? I’ll second the nod to the Deep Woods. Had mine out this week in the snow. Ran Hyrax and them back to back. The Deep Woods ate the Hyrax lunch in the snow. That said, they have a rounder, narrower profile, so they don’t so much float as dig. They do unload well too. 6” is getting pretty deep for 1.9’s though.
12-21-2019, 08:41 AM | #33 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
Deep Woods ..no foam ..unbeatable!! |
12-21-2019, 12:17 PM | #34 | |
the front right wheel stops spinning at 2:54 cause the cv broke | |
12-21-2019, 03:41 PM | #35 | |
Is that correct? | |
12-21-2019, 04:31 PM | #36 | |
If it was like a 1-2ft base I don't believe it would be possible to snap a axle shaft or cv since you would most likely high center before you get enough traction to break anything. Cool video to! | |
12-21-2019, 05:01 PM | #37 | |
If there were no other obstructions holding the vehicle back and it had maximum traction, itd be moving, not sitting still spinning. Traction in, or on the snow was NOT the cause of this snapped cv, 1,000%, there wasn't any. Last edited by Xx Losungen xX; 12-21-2019 at 05:14 PM. | |
12-25-2019, 12:15 PM | #38 |
Got some fresh tires in this week! These puppy's are 2.4" wide and 5.25" tall and they are next to Baja claws that are 1.7" wide and 4.75" tall. Should have lots of grip now. Last edited by Toyotarc; 12-25-2019 at 12:31 PM. Reason: Image sizing |
01-05-2020, 02:54 PM | #39 | |
Later on the powder was a little deeper and both sets of tires performed more equally. They both slid more. Both provided impressive grip and acceleration. | |
01-05-2020, 06:53 PM | #40 | |
Best tire for snow crawling? - Similar Threads | ||||
snow tire suggestion | glockrocket17 | Traxxas Crawlers | 23 | 05-11-2013 01:01 AM |
Snow tire chains | sally1800 | General Scale Talk | 16 | 02-07-2011 09:09 AM |
Snow Tire | Lemonlegs28 | Newbie General | 4 | 01-20-2011 02:37 PM |
3.75 snow tire? | the_ghetto_rig | Tamiya XC/CC01 | 16 | 10-13-2009 05:02 PM |
what is a good 1.9 tire for snow | losiminicrawler | Tires and Wheels | 16 | 10-06-2009 07:01 PM |
