09-24-2012, 10:45 AM | #21 |
| Re: Welding Brake-Line My point was that if it didn't work we wouldn't be using it, not that it was the best available option. |
09-24-2012, 11:01 AM | #22 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
Silver solder and a small mapp gas tank with a torch tip work? I tried that with propane and just couldn't get it hot enough.
09-24-2012, 01:27 PM | #23 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
Just a thought - Has anyone used the flux and solder that you use to join copper pipes for soldering/brazing brake line on RC? Wonder if that would work; it's cheap.
09-24-2012, 01:28 PM | #24 |
Yeah MAPP is much hotter than propane.
09-24-2012, 01:43 PM | #25 | |
| Re: Welding Brake-Line Quote:
I've actually been using a 15% rod w/ a MAPP tank to use as a filler layer, some of my braze joints aren't always aesthetically pleasing although they are plenty strong. The lower melting point of the 15% rod doesn't affect the bronze joint. Last edited by BigSki; 09-24-2012 at 01:46 PM. | |
09-25-2012, 08:08 PM | #26 |
Quarry Creeper Join Date: Jan 2009 Location: B-E-A-utiful Vancouver Island
.023 wire with a little bit of a longer "stick out" should help keep the heat down on the mig..... with that said silver solder is deff a great way to go .... i have both an preffer the silver over the mig Oh also. Your shield gas should be a mix of argon and co2.... Straight argon is used for aluminum... Might be the source of your problem Last edited by Rockridge; 09-25-2012 at 08:25 PM. |
09-25-2012, 10:23 PM | #27 | |
Newbie Join Date: Aug 2012 Location: grande prairie
09-26-2012, 03:23 PM | #28 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
Be sure to wire-wheel the coating off the brakeline first- it's very toxic when it burns. Use .023, C02/Argon mix, and a welder with infinite voltage and wire control. (Such as the 110volt Miller and some Lincoln machines.)
Welding Brake-Line - Similar Threads | ||||
brake line | oscodawave | Newbie General | 15 | 10-09-2010 11:58 PM |
Brake line! | warfile | Tools, and Procedures | 34 | 08-26-2009 03:48 AM |
Mig welding Brake line | Ryan33 | Tools, and Procedures | 11 | 02-07-2009 11:09 PM |
brake line ? | nodnarb81 | Tools, and Procedures | 2 | 01-30-2008 10:47 AM |
welding brake line | skrewdriver | Tools, and Procedures | 9 | 04-25-2006 01:48 PM |
