Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Lets see your handmade tools!
Old 02-09-2013, 11:53 PM   #1
Default Lets see your handmade tools!
What specialty tools have you made? Post pics!
1tonscout is offline   Reply With Quote
Old 02-10-2013, 12:26 AM   #2
Default Re: Lets see your handmade tools!
Here's my homemade bender
First i made a die
Then I made a follower
I rounded up some hardware
Tapped some holes
got all the parts layed out
eveything set and ready
Then I did some test bends
Once I was happy with the bends I cut some threads
Then my threading die gave up on me and started messing up the threads. just ordered another 3mm die and my next attempt will be with plain steel rod
Old 02-10-2013, 10:16 AM   #3
I made a stand for my 1:1 scale jd2 model 32 bender
Some screw jacks, fly cutter and hammer I made in high school machine shop
digital readout brackets I made for my harbor freight 3in1 machine
Old 02-16-2013, 09:57 AM   #4
Here's some angle plates I've been working on this week.
Now I've got to drill and tap some holes in it. Then its out to get case hardened and I'll finish grind it in a week or two. When ever I get some more free time.
Goatsniper is offline   Reply With Quote
Old 02-16-2013, 03:15 PM   #5
I modded up this tool a while back, still holding up
Kobalt mod
1.5mm 2.0mm 2.5mm
flat head
4- diff phillips head screw drivers
prusik333 is offline   Reply With Quote
Old 02-18-2013, 03:47 PM   #6
I needed an 8lb...or so brass hammer, this is what I made with a knurled stainless steel handle.
Pita is offline   Reply With Quote
Old 02-18-2013, 05:16 PM   #7
Got one drilled and tapped today.
Old 02-18-2013, 07:41 PM   #8
Damn man that IS a lot of freakin work....nothin but time.
Old 02-18-2013, 08:44 PM   #9
And you got to wonder WHY ....????
Postclanker is offline   Reply With Quote
Old 02-18-2013, 08:59 PM   #10
AJ.
I'll take one!
AJ. is offline   Reply With Quote
Old 02-19-2013, 05:28 AM   #11
I dont get it..."Wonder Why"??
Clamping anything into that Mill more securely is a must.
Old 02-19-2013, 08:38 AM   #12
I'm in between jobs at work right now so I've got some time to play....granted it didn't need that many holes in it but they are there incase I need them.
Old 02-19-2013, 10:38 AM   #13
Hell yeah !! You should be able to clamp down anything you can possibly think of. In machining and fabrication I dont believe in the word "Overkill"...its not in my vocabulary. With those plates the possibilities are endless. Nice Work Man !!
Old 02-21-2013, 09:33 AM   #14
Thanks alot Pita...got them rough ground. Now off to get case hardened.
Old 02-21-2013, 01:12 PM   #15
I know most people cannot appreciate the amount of work that is sitting there.
Dude those plates are BADASS !!! I love seeing work that shows dedication and talet.. Nicely Done Sir
Old 02-21-2013, 09:17 PM   #16
Thanks...I've got about 26ish hrs in them now. Probably 1 or 2 more hrs left and they'll done!
Old 03-09-2013, 10:33 PM   #17
Swiss cheese anyone?
crawlerlover is offline   Reply With Quote
Old 03-13-2013, 10:14 AM   #18
2013 2.2P Nat. Champion
SkaldidDog's Avatar
Driver handles and a beadlock wheel compression jig are just a few...
SkaldidDog is offline   Reply With Quote
Old 03-13-2013, 12:56 PM   #19
Now thats some thinkin right there !! You should sell them suckers
Old 03-17-2013, 11:05 AM   #20
nothing fancy but i needed a bender so i built this..
^^drilled a couple holes and put the round stock through and welded it from the underside so there was no welds on the top to get in the way..also welded another plate 90* from the other one so i could clamp it into a vise
AX10wannabe is offline   Reply With Quote
Lets see your handmade tools! - Similar Threads
Handmade CJ7 first run novianto Scale Videos! 9 01-15-2013 10:55 PM
Losi Micro Crawler handmade. Alex_Core Losi Micro-Rock Crawler 45 07-11-2012 08:28 PM
A handmade axe opek Chit Chat 9 04-24-2012 04:30 PM
