03-18-2014, 08:01 AM | #1 |
Rock Crawler Join Date: Feb 2011 Location: Williston
| metric tap and die set- where to buy?
I am looking for a small metric tap and die set everything between 1 or 1.5 to 3mm. specifically I am looking for 2 and 3mm any help on the best place for a fairly inexpensive set of them? thanks! L.R. |
03-18-2014, 10:45 AM | #2 |
RCC Addict Join Date: May 2011 Location: at home
| Re: metric tap and die set- where to buy?
try Micro Fasteners not a set but they do have the individual dies (and taps) from 2mm up to 4mm by .5 increments they are my source for metric hardware the sets I see in ebay do not have the 2mm and do you want the bigger sizes that come in sets anyways? Last edited by cabron; 03-18-2014 at 03:02 PM. |
03-18-2014, 10:54 AM | #3 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
I bought both 10 pc sets from home depot brand name Irwin/hanson I think....I got std from 6-32 and up, metric in 3 4 5 7 8 mm tap and dies....bout 25 bucks each....
03-18-2014, 11:11 AM | #4 |
RCC Addict Join Date: Nov 2006 Location: burlington
| Re: metric tap and die set- where to buy? |
03-18-2014, 01:26 PM | #5 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Harbor frieght has a comprehensive kit for around 40.00 . I have been using it for years. I believe it goes down to 2mm up to 5/8 or so . Metric and standard,havnt broke a tap/die yet. Alum, stainless, spring steel.....no problems.
03-18-2014, 01:41 PM | #6 |
Quarry Creeper Join Date: Dec 2012 Location: Seattle
I purchased the smaller sized kit off amazon (Irwin brand) and bought the rest of the 3mm and up from Sears..(craftsman, lifetime warranty) Sent from my iPhone using Tacos |
03-18-2014, 01:53 PM | #7 | |
Quarry Creeper Join Date: Mar 2009 Location: Central WA
| Re: metric tap and die set- where to buy? Quote:
Try a local wholesale hardware place Fastenal. I bet you can find them there individually and pretty inexpensive too | |
03-19-2014, 05:14 PM | #8 |
I really don't like sets when it comes to taps. I purchase mine individually, usually from McMaster or MSC. Sets will give you a broad range, but realistically how many do you really need? It looks like you're only looking for 2-3 sizes, so why spend money on taps you won't use. Buying quality taps individually is more expensive, but in the sizes you are talking about, you want good quality. |
03-19-2014, 07:06 PM | #9 |
why I bought what I did ....
03-19-2014, 07:25 PM | #10 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
I'll second CHUD, one thing you never skimp on is taps and dies. If you go cheap you get crappy threads, burred, soft, uneven etc etc. By quality individuals and you will be much happier in the long run. Especially for smaller threads like the ones you want to do you need to go quality. Operating a machine shop has taught me tons and tons about tooling and this was one of the first things I changed up. The original tooling that was being used wasn't the best, even though we work 99% in aluminum you still need quality tools. --Dan Last edited by sickcivic95; 03-19-2014 at 07:45 PM. |
03-28-2014, 03:56 PM | #11 |
Rock Crawler Join Date: Sep 2010 Location: Little Rock, AR
i get my 3mm 4mm 4-40 6-32 8-32 and other small taps off the snap-on truck, i usually get two of each and they are the best taps ive used in the smaller sizes. i have wore out a lot of 3mm and 4-40 taps in the last 12 years. i can honestly say they are well worth the $2-3 each they cost me.
03-28-2014, 08:13 PM | #12 |
Look for the 'Greenfield' name- very high quality stuff.
03-28-2014, 08:19 PM | #13 |
Rock Crawler Join Date: Nov 2013 Location: In the country
MSC.com Sent from my LG-E980 using Tapatalk |
03-29-2014, 11:57 AM | #14 |
Pebble Pounder Join Date: Dec 2008 Location: kingsland
try Micro-mark.com
03-29-2014, 01:30 PM | #15 | |
MODERATOR Join Date: Oct 2010 Location: RC Land
Drill bits, taps, dies, saw blades, grinding discs, files, etc... are considered consumable and they will not make good on them if they break or dull. The tap & die handle holder and the plastic case itself are the only parts of that set covered under Sears lifetime warranty. . | |
03-29-2014, 02:07 PM | #16 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
Had good success with irwin taps from ace hardware. Get mine in about 3 days for 3.99 ea.
03-29-2014, 05:05 PM | #17 |
using a good wax stick or oil while you are taping and proper technic gives long life more then anything....grind away through a hole or rod without and SNAP ....
metric tap and die set- where to buy? - Similar Threads | ||||
Where to buy M3 tap? | BubbaEinstein | Tools, and Procedures | 19 | 01-07-2013 09:33 PM |
decent to good tap and die set??? | donhd04 | Tools, and Procedures | 23 | 07-05-2012 12:54 AM |
Suggestions for a Tap and Die set | TJ_Shunk | Tools, and Procedures | 16 | 02-25-2010 08:37 PM |
Tap and Die set... | Synister_Intent | Tools, and Procedures | 12 | 11-06-2009 09:34 AM |
Tap and Die kit????? | John Deere | Tools, and Procedures | 15 | 09-18-2006 08:32 PM |
