01-26-2015, 09:09 AM | #21 |
Pebble Pounder Join Date: Feb 2013 Location: Florida
| Re: Brazing torch suggestions
My .02... I tried every way to cheap out on a torch... the small handheld refillable butane torches (not hot enough), MAPP gas, and MAPP/Oxy rigs from the home improvement stores. (I still have the MAPP and the MAPP/Oxy setups if anyone wants to make an offer.) While the MAPP base ones get plenty hot enough for brazing my main issue was control. The flame from each of these is huge compared to what you need for brazing RC stuff. It's virtually impossible to braze two close proximity joints without melting the one you just finished. I suspect the same is true for Oxy Acetelene rigs designed for plumbers. I finally gave up and shelled out for the Smith. No regrets at all, it will let even a newby braze like a pro. |
01-26-2015, 11:09 AM | #22 |
Quarry Creeper Join Date: Dec 2013 Location: Atlanta
is this a good set-up to start with? would it be able to braze a frame together? Amazon.com: The Little Torch with 5 Tips In a Box- Acetylene: Home Improvement |
01-26-2015, 01:06 PM | #23 | |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: Brazing torch suggestions Quote:
01-26-2015, 01:37 PM | #24 |
| Re: Brazing torch suggestions |
01-26-2015, 04:10 PM | #25 |
01-26-2015, 04:58 PM | #26 |
| Re: Brazing torch suggestions The bottles you can either rent or buy. Same for regulators. Better to buy the regulators either from local welding shop or online.
01-26-2015, 05:24 PM | #27 |
01-26-2015, 05:52 PM | #28 | |
01-26-2015, 07:47 PM | #29 |
RCC Addict Join Date: Jan 2009 Location: Bend
You guys need to check your local CL for a used setup. I've been on the hunt for a torch setup for months now and also finally came to the conclusion that eventually I'm going to end up wanting more. More heat, more heat control, and, and, and... Long story short, I found a newer portable oxy/acetylene setup somebody had for doing refrigeration/HVAC work for $125 used and complete. It came with a bunch of spare brazing/soldering tips, brand new hoses, spare regulators, and even came with a spare set of older tanks. Not sure if I can have them filled or not yet due to their age, but will look into it. For the money spent though, I'm tickled.
01-26-2015, 07:50 PM | #30 | |
01-26-2015, 09:33 PM | #31 | |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
01-26-2015, 09:36 PM | #32 |
Started looking and only found 2 that were close to what I was looking for. The rest were $250-300 and that's a bit out of my price range. Hopefully there'll be more in a week or two.
01-28-2015, 07:21 PM | #33 | ||
Its not the best, but for limited hobby use, ie: non daily use 5 days a week. You will be fine, that set up will also work with the mini torches as they have the same threads as the full size hoses. Disclaimer, it is harbor frieght stuff, not the top o the line, regulators may not be as precise, hoses not as durable and possibly stiffer than some, etc... but its cheap and if you decide brazing, gas welding or cutting isnt for you.... you are not out a lot of cash, sell it for cheap on CL and move on or upgrade if the shoe fits. Last edited by hotwheels000; 01-28-2015 at 07:35 PM. | ||
01-28-2015, 07:46 PM | #34 | |
01-29-2015, 12:51 AM | #35 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
I've also been in the market for a smith torch and been searching around quite a bit for the best deal. So far I've missed out on 2 locally on CL that were smoking deals, prob why they sold so fast. Other wise it's been amazòn or direct for the complete kit. You can find just the torch and hose for cheap multiple places, espicially from aliaexpress but you'll still need regulators and I'm not sure I'd trust buying those from there. The one you posted from ebay is a fullsize setup, the actual torch handle w the 90° tip is almost 12" long and I believe it's over 15" with the smaller width tips. Working on 1:1 parts it's no problem but on or rc scale it may be a bit of a cluster trying to maneuver it around. Just me 2 cents but I'd steer clear of a fullsize and keep looking for a good deal on a used one. -Dan |
01-29-2015, 11:03 AM | #36 |
Yeah, I'm going to keep looking to see what there is. There just wasn't much on CL right now.
Brazing torch suggestions - Similar Threads | ||||
Brazing torch | adamargue | Tools, and Procedures | 5 | 02-05-2011 09:11 PM |
brazing with a propane torch?? | honchoscaler | Tools, and Procedures | 8 | 08-04-2010 01:02 PM |
Brazing,Micro-torch or Normal size torch? | xyzoose | Tools, and Procedures | 4 | 03-04-2010 09:47 PM |
Brazing Torch Question | Nate08 | Tools, and Procedures | 6 | 11-07-2009 08:02 AM |
Brazing - Torch suggestions | Trikster | Tools, and Procedures | 4 | 09-07-2006 09:56 PM |
