04-01-2015, 07:50 PM | #1 |
Rock Stacker Join Date: Jul 2010 Location: Hickory
| Advice on buying a sub $400 air compressor
I would like to replace my old husky air compressor because it is too loud and constantly runs. The main use is blowing off the RC cars for cleaning and filling bike tires. Current unit is 2.75 hp 8 gal 135 max psi. Thanks, Peter |
04-01-2015, 08:05 PM | #2 |
I joined the Band! Join Date: Dec 2014 Location: Monroe
| Re: Advice on buying a sub $400 air compressor
IF you want to stay small I'd look for an older 20-30 gallon belt driven compressor. The quality brands run pretty quiet and put out some decent cfm. Could easily be found for less than $400.
04-01-2015, 08:15 PM | #3 |
Pebble Pounder Join Date: Jan 2015 Location: South Central PA
Belt drive is definitely the way to go. Much lower rpm therefore much lower noise. Check out harbor freight if you have one in the area. Pretty good prices and enough reliability for casual use. http://m.harborfreight.com/air-tools...sor-61489.html Sent from my iPhone using Tapatalk Last edited by jeff22; 04-01-2015 at 08:18 PM. |
04-01-2015, 08:56 PM | #4 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
home depot has some belt drives for bout 350.00....
04-01-2015, 09:10 PM | #5 |
RCC Addict Join Date: Oct 2012 Location: Norcal
Great compressor for the $ and quiet! http://www.amazon.com/Makita-MAC2400...air+compressor Been running solid for years and good CFM. I use it for nailing and spraying poly on wood working for the business. Last edited by Norton; 04-01-2015 at 09:13 PM. |
04-02-2015, 05:35 AM | #6 |
Belt drive ? I wouldn't have thought that it wasn't a good option, so I will give it some consideration. I had been looking at the Makita but feel that the tank might have been too small. is the Makita really that quiet?
04-02-2015, 06:17 AM | #7 |
I've never seen one of the small ones that puts out any decent air that isn't ungodly loud. Even the good ones don't up out that much. Just depends if you have the space/need for something bigger.
04-02-2015, 10:23 AM | #8 |
home depot has a belt drive that is on wheels, if you have a storage spot the you should not have any trouble....the one I'm looking at went up in price, but should handle anything we do here....plus it can handle taking lug nuts off your car with air gun.... Husky 30 gal. Ultra-Quiet Portable Electric Air Compressor-C301H - The Home Depot |
04-02-2015, 11:11 AM | #9 |
Don't forget about looking for a used one, I recently sold my Husky 5hp, 30 gallon compressor for $250. It worked flawlessly and looked good. There are some good used buys out there.
04-02-2015, 02:04 PM | #10 |
Pebble Pounder Join Date: Feb 2013 Location: Florida
I don't think it's the belt drive, so much as oil-less vs. oil-lubricated. The little oil-less compressors are much louder.
04-06-2015, 11:43 AM | #11 |
I don't think I've ever seen an oil lubricated compressor that wasn't belt drive. But basically what you want is low rpm. The noisy compressors run about 3k rpm quieter ones 1500-1700 rpm. Sent from my iPhone using Tapatalk |
04-06-2015, 11:49 AM | #12 |
Just found this. Not really enough cfm (airflow) for air tools but seems perfect for your application. Low rpm. Oil free. Almost seems too cheap to be true. I would buy this if I had room for another one. http://m.homedepot.com/p/California-...6310/202977399 Sent from my iPhone using Tapatalk |
04-11-2015, 09:45 PM | #13 | |
Quarry Creeper Join Date: May 2006 Location: san diego
| Re: Advice on buying a sub $400 air compressor Quote:
i had a 25 gallon oiled compressor and my buddy talked me into a a oil-free compressor (i wanted a larger tank so i got a 33gallon) but this thing is so noisy!!! I wish i stuck with oiled compressor unit! this is the one i got. Craftsman 33 Gallon Vertical Air Compressor: Portability from Sears if you are mainly using it for a r/c this one is 10 gallon oil lubed. 10-Gallon Oil-Lube Portable Air Compressor Kit: Blow at Sears | |
Advice on buying a sub $400 air compressor - Similar Threads | ||||
Air Compressor Question. | FLB | Tools, and Procedures | 21 | 01-12-2020 10:01 PM |
Air Compressor Suggestions? | Colby | Tools, and Procedures | 16 | 06-15-2013 08:54 AM |
air compressor for airbrush | brandontodd33 | Paint and Body | 2 | 06-02-2009 12:21 PM |
Need a special air compressor | monstertruck | Paint and Body | 13 | 08-16-2008 02:22 AM |
What air compressor? | robvbro81 | Paint and Body | 20 | 09-28-2007 02:24 PM |
