01-20-2017, 08:43 AM | #1 |
Newbie Join Date: Dec 2016 Location: Rutherford
| Portable air compressor
I recently moved and couldn't take my 100-150 gallon air compressor with me. I really only need one to blow off my rc's and maybe fill my car tires. whats a good cheap one and maybe even a battery/rechargeable?
01-20-2017, 10:14 AM | #2 |
| Re: Portable air compressor
I was recently shopping for a small take along compressor too. The problem with a blow gun is they use a lot of CFM so as soon as you pull the trigger the pressure drops fast. Filling tires is much easier because it's low volume unless you're running 37s on 15s. The small pancake types can't keep up. It takes them 5 minutes to pressurize and 3 seconds to drop to nothing. I'm still looking myself. I'd love to hear what others have to say too.
01-20-2017, 10:51 AM | #3 |
RCC Addict Join Date: Aug 2008 Location: Paulina
I have a Husky 8gal oil free tank from Home Depot that does pretty well. It may be larger than you want for portable but it does pressurize fairly quick and 8gal is a decent volume. Husky 8 Gal. Portable Oil Free Electric Air Compressor-0300813A - The Home Depot |
01-22-2017, 12:11 PM | #4 | |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
| Re: Portable air compressor Quote:
One of the problems with the really small compressors, 2 to 4 gal, is they are mostly designed for construction tool air use, very low volume consumption. Hold an air gun full open and they drop to nothing in about 8 seconds. | |
01-22-2017, 12:14 PM | #5 |
Quarry Creeper Join Date: Jan 2009 Location: Cerritos
Haven't really found a good system unless it was really expensive. The smaller pancake types of compressors are junk (for me), I picked one up years ago. used it twice- hated it so much I gave it to a friend. Took a long time to charge up, and would run out of air super fast. For this reason- I started looking into C02 systems. Costs money- but works much better for my application. |
01-22-2017, 03:27 PM | #6 |
Rock Crawler Join Date: Nov 2014 Location: Dells
I have one of these https://www.amazon.com/California-Ai...FX5WHT0PJD8A3D I can't say anything bad about it. It's fast It's quiet It's built surprisingly well It's not overrated like the hobofreight POSs Look up the videos to see just how quiet it really is. I have it sitting in my bedroom for airbushing most of the time |
01-22-2017, 03:50 PM | #7 |
I just checked out cow rc jet blaster and god dam! 90 bucks or 110 for the turbo!! looks cool and portable but I dunno that seems like a lot to me
01-22-2017, 04:34 PM | #8 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Portable air compressor They mention the company who manufactures it in the description. IIRC you can get it from them for ~$15-20 less but it has a different power switch.
01-22-2017, 06:04 PM | #9 |
Quarry Creeper Join Date: Dec 2012 Location: Pioneer, 95666
it takes a few cycles to get my R/C's cleaned off with it, but I use my Senco pc1010 1 gallon compressor. I've had it for about 10 or 12 years and the motor is finally getting worn (I also used it for finish carpentry daily for a number of years). I recentlyvpicked up a 12 volt compressor from the air ride system on a lincoln town car. I'm laying out a setup to use it with a 2.5 gallon tank and make it portable for airing up tires and blowing off my r/c at trail runs. one other thing to consider, is that if you can crimp down the nozzle on your blowgun, it will decrease the amount of airflow, but increase the pressure of the flow to a certain extent. If you decrease it too much though it will restrict both the airflow and the velocity. |
01-22-2017, 06:37 PM | #10 |
| Re: Portable air compressor |
01-22-2017, 06:47 PM | #11 |
Junk... Worst than the other 3g pancakes out there. This is about the cheapest hobo freight compressor I would get. Anything less and you might as well drive to the gas station and use their air hose. 8 gal. 2 HP 125 PSI Oil Lube Air Compressor I'm I fan of these. They are incredibly quiet. https://www.amazon.com/California-Ai...T0PJD8A3D&th=1 |
01-23-2017, 09:17 AM | #12 |
Love my cow blaster.
02-28-2017, 03:18 PM | #13 |
Official Scale Nazi Join Date: Sep 2004 Location: Monticello, IL
It doesn't fit in the "cheap" category but I can't speak highly enough of this Rolair JC10 I picked up a year ago. Ultra-quiet and meets my needs using it for a Brad nailer, car tires, and air gun. Rolair JC10 Super Quiet 1HP Oil Less 2.5 Gallon Air Compressor | The Tool Nut |
02-28-2017, 06:29 PM | #14 | |
That uses a California Air compressor. $200 is about as cheap as you want to go for a compressor, any less and you start to have issues. | |
03-01-2017, 09:00 AM | #15 |
RCC Addict Join Date: Aug 2013 Location: Missoula
I have one of these to drag around. Fills super fast, empties fast with a blow gun though. Small volume is what it is, lasts a lot longer if you dial the output down. It is loud, like startling when it fires off. $109 at Lowes with a little accessory pouch that gets you everything you need. I have a big compressor in the shop, but almost always just carry the little one around to where I need it. Fini Air Compressor |
03-01-2017, 08:17 PM | #16 |
Donkey Punch Champion! Join Date: Oct 2006 Location: Minneapolis
Just a couple bucks over the target price, but it works. ARB Twin High Performance 12 Volt Portable Air Compressor (CKMTP12) |
04-06-2017, 02:41 PM | #17 |
Newbie Join Date: Aug 2016 Location: Wiscasset
I use one of these for racing rc on dirt tracks https://www.amazon.com/Metro-Vacuum-...ywords=datavac One of my friends has the turbo version which is significantly more powerful https://www.amazon.com/Data-Vac-ED-5...ywords=datavac |
04-06-2017, 04:23 PM | #18 |
For my at home use, I have one of these in my garage... Probably around 10 years old and still operates fine. but I believe this model is whats currently available/sold at HF... 21 gal. 2.5 HP 125 PSI Cast Iron Vertical Air Compressor A 220v compressor is way better... But not everyone has that voltage fed to their garage. Not worthy of the cost to do... if yer a renter. -------------------------- For my portable needs, I'll tote around my 15 lb CO2 bottle... The high flow/adj. regulator is a must have for CO2 use. The aluminum tank makes it lighter. -------------------- For portable emergency back up/tire fill, I carry this OB as well... https://www.amazon.com/Master-Flow-M.../dp/B000L9AD2U ^ but would require a separate tank for doing blow off. |
04-06-2017, 04:56 PM | #19 |
This is my portable air compressor. It's aluminum and light as hell, but still good enough to push my airbrush. They are $299 now, but I got mine on sale for $99! https://www.homedepot.ca/en/home/p.s...000826928.html |
Portable air compressor - Similar Threads | ||||
Air Compressor Question. | FLB | Tools, and Procedures | 21 | 01-12-2020 10:01 PM |
Air Compressor Suggestions? | Colby | Tools, and Procedures | 16 | 06-15-2013 08:54 AM |
air compressor for airbrush | brandontodd33 | Paint and Body | 2 | 06-02-2009 12:21 PM |
Need a special air compressor | monstertruck | Paint and Body | 13 | 08-16-2008 02:22 AM |
What air compressor? | robvbro81 | Paint and Body | 20 | 09-28-2007 02:24 PM |
