Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Composite Chassis
Old 08-22-2007, 09:03 PM   #101
Here is the process for plaster.
Composite parts made easy
An uncut body would work good, set the body on foam board tape the edges down on the body so plaster dosen't leak under it. Build walls around it with foam board and slowly fill it up so the pressure of the plaster doesn't squish the sides in. Plaster will cure just fine at room temp.
Mike
Mike Poulson is offline   Reply With Quote
Old 08-22-2007, 11:57 PM   #102
Nice build. Very innovative in more than one way. Thanks for the inspiration.
SACCO is offline   Reply With Quote
Old 09-18-2007, 08:05 PM   #103
RAM2500's Avatar
Originally Posted by WaWa View Post
plaster o paris is what I ment... where are you getting the gypsum plaster? Home Depot? I think that if I leave the body whole (don't cut anything off it) and just stick it in a box (upside down of course and filling the box with plaster around and then just CF the parts I want... trim the rest off... right?) I wouldn't have to many issues with it deforming since they are fairly sturdy in the original mold... maybe I could use dowls to brace the sides?? The only problem I could see having is the plaster mold curing at the right temp... guess I could make a cure box out of something and using light bulbs... Hmmm you've got the wheels turning...
thanks
WaWa
Do you think that expanding foam spray between the body and the box would brace it enough? I would try the kind used around window and door frames that doesn't expand as much so that it doesn't deform the body. Just a thought.:-D
Mike, that rig turned out great by the way!!!!!
RAM2500 is offline   Reply With Quote
Old 09-18-2007, 11:58 PM   #104
Thanks
Not sure I understand using foam between the body and box. That should be where the plaster is poured.
