Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: DeWalt Motor - Dispelling the Myth, but Fixing the Problem
Old 11-01-2012, 07:33 PM   #1
Default DeWalt Motor - Dispelling the Myth, but Fixing the Problem
I've read right here on this forum (and others..) that the 14.4v DeWalt motor has a bearing supported armature. Well, it doesn't.
I dug into mine after getting tired of a screetching sound I could only eliminate by spraying a little WD-40 into the back of my motor. A little later, it would start screetching again though. Thinking it was just a bad motor, I was surprised when a couple weekends ago, my brother's DeWalt powered Summit was making the same sound. It was time to find the problem.
After removingthe brushes and prying off the end cap, I was surprised to see that the back of the armature is supported by a bronze bushing, not a bearing. And yup, it had a sloppy fit on the armature. Luckily, it measures 8mm x 5mm x 5mm. So I replaced it with two 8mm x 5mm x 2.5mm bearings, and problem solved. The motor is now silent, and turns very smoothly. If you don't have a local hobby store with bearings, you can order Traxxas part # TRA5114 and get a package of two bearings that will work.
Hopefully this helps anyone with the same screetching DeWalt motor problem.
monsterz is offline   Reply With Quote
Old 11-02-2012, 07:45 PM   #2
Default Re: DeWalt Motor - Dispelling the Myth, but Fixing the Problem
I wondered
stickys is offline   Reply With Quote
Old 11-04-2012, 03:29 AM   #3
Sticky this one some where
OllllO Fanatic is offline   Reply With Quote
Old 11-04-2012, 01:32 PM   #4
Ya know, WD40 is not a lubricant................
Mgoetz is offline   Reply With Quote
Old 11-04-2012, 02:34 PM   #5
MAN! I can take those bushings and cut em down a little and use them for my XR10.
KBrog is offline   Reply With Quote
Old 11-04-2012, 06:03 PM   #6
WD-40 works ok for getting rusted bolts and nuts off of vehicles, but there are definitely far better products, and I would not call it a lubricant, makes things squeaky, like car doors. Its more of a clean crap out of a joint or hinge spray. Better to use a silicone spray or grease for lubricant.
Old 11-04-2012, 07:07 PM   #7
I know WD-40 is not a permanent lubricant. However, no lubricant will solve the issues associated with a sloppy bushing. I even tried packing the end with synthetic grease, and it didn't solve the problem any longer than WD-40 did.
Old 11-18-2012, 06:29 AM   #8
Ive been using silicone spray from CowRC on all my RCs for a while now and it works awesomely on bearings and bushings!
whiplash is offline   Reply With Quote
Old 12-11-2012, 12:48 PM   #9
wd-40 is not a lubricant at all, it's a water displacement (hince wd...) agent. it is used to dry metals without rusting them, or helping to remove small amounts of rust. but it will actually cause more harm than good trying to use it as a lubricant.
thundaar is offline   Reply With Quote
Old 12-11-2012, 05:17 PM   #10
Not sure how this turned into a wd-40 debate, but it most certainly is a lubricant. Why do you think it works for breaking loose rusty bolts? I do agree that it's a poor choice for a long term lubricant, however. You might check out their website...
Old 12-11-2012, 05:19 PM   #11
It's funny this thread came up today, as I was just talking to my brother and how his DeWalt lunched the bearing on the output side of the motor. So it most definately does have a bearing supported armature on the output side.
Old 12-31-2012, 05:41 PM   #12
VERY good thread, thank you for this tip. I have a Dewalt 14.4 in mine and although it isn't skreeeeching yet (I use oil) it will be on my upgrade list of things to do. Once again thank you
bro460 is offline   Reply With Quote
Old 12-31-2012, 05:54 PM   #13
Location: Turn the mayflower around.. it will never work
Ive said this many times before...... the motor is just a larger version of every other silver can motor..... no bearings
good find on the bearing.... still a cheap motor.
brasso and quality lube soaked into bushing is what we always have used on vintage trans am motors.
JokersWild is offline   Reply With Quote
Old 02-02-2013, 08:27 PM   #14
How long do the DeWalt motors last before destroying the bushing?
SnarkyMcSnarkson is offline   Reply With Quote
Old 02-05-2013, 08:10 PM   #15
It will depend on useage and how much battery you're putting through it. I think it has similar durability to the stock motor, but it does seem to have slightly better performance.
Old 03-27-2013, 12:29 PM   #16
How did you open the can to get the bearings in ?
chbronco is offline   Reply With Quote
Old 03-30-2013, 07:58 AM   #17
Pull the brushes out, then slowly pry it off with a screwdriver. It's just pressed on.
DeWalt Motor - Dispelling the Myth, but Fixing the Problem - Similar Threads
what esc for a 14.4v dewalt motor tj on 37s Electronics 8 08-13-2013 10:28 PM
dewalt motor and sidewinder??? Grimreeper Traxxas Crawlers 5 02-27-2012 09:29 PM
Anyone running a DeWalt motor? BigSki Electronics 14 10-27-2011 06:14 PM
Noob fixing a problem on his new Crawler King Modean74 Newbie General 0 11-20-2009 11:55 PM
fixing the txt-1 twist problem bigdangerous Tamiya Txt-1 and Juggernaut 7 10-06-2004 01:45 AM
HTML code is Off
