02-19-2008, 03:03 PM | #101 |
I never get tired of pics of that rig sheldon, awesome! |
02-19-2008, 05:51 PM | #102 |
RCC Addict Join Date: Mar 2006 Location: Xxx
Considering my polsen axled tuber rig thingy has yet to be driven and weighed , how much does your fatty weigh in at? Is she really a chubby comper ? |
02-19-2008, 07:20 PM | #103 |
Pebble Pounder Join Date: Jun 2007 Location: somewhere
Awesome rig! If & when I stray from my wk I'm gonna go with an axle set-up like this. Nice...
02-19-2008, 07:48 PM | #104 |
What foam setup are you using with the badlands?
02-19-2008, 09:21 PM | #105 | ||
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Thanks Ben. Quote:
Stock, narrowed to the width of the rim. | ||
02-20-2008, 06:55 AM | #106 |
What part of the cvds were you breaking?
02-20-2008, 02:45 PM | #107 |
The pin & drive cup.
02-20-2008, 05:56 PM | #108 |
02-20-2008, 07:09 PM | #109 |
Is that welded? It might. I just think the power of the 5t cobalt on a 3s lipo is too much.
02-20-2008, 08:18 PM | #110 |
02-20-2008, 09:57 PM | #111 |
What kind of motor & battery you running? I might give that a try. |
02-21-2008, 04:22 AM | #112 |
ΜΟΛΩΝ ΛΑΒΕ Join Date: Dec 2006 Location: In tha Bush of Louisiana
02-21-2008, 06:53 PM | #113 |
02-29-2008, 03:14 PM | #114 |
Got a new idea for the dig system. It'll be more like cut brakes now. 2 servos on the rear strut, Jato shafts instead of the maxx. Castle nut lock-out/slider. I have the idea all worked out in my head, just got to make it work now. Hopefully I'll still ge able to use my DX3R, if not I'll have to switch to my DX6. I'd really prefer to stay with the 3R. I'll also be TIGing the pins inside the CVD's like Nigel did. I really like the 5t puller & want to use it. |
02-29-2008, 03:15 PM | #115 |
02-29-2008, 08:01 PM | #116 |
03-12-2008, 05:07 AM | #117 |
Put some work in on AFC. Seems like the cut brakes are a no go for now. The couplers I made were too long even @ 1.5". So instead I replaced the R2 with an axial trans. Got that mounted. Then I used one of the sliders for a more traditional dig. I made the slider/coupler out of a TLT knuckle & a 3/8 castle nut. I drilled both of them out almost all the way threw. Left a small lip inside both to capture the female shaft. Next I hacked some brackets out of AL to tie the knuckle & castle nut together. It looks alittle ghetto but right now I need it to work 1st, look good 2nd. The axle side male shaft has a hole drilled for a roll pin, this will lock in the castle nut. I mounted Hitech 225 servo on the rear axle & used 2 links to connect the servo horn to the knuckle. I need to find a small 6-32 allthread to insert in the 2 male shafts. I tested it with 4-40 & it seems to work fine, but wobbles. 4WD to 2WD to dig. Now I need to find a new spot for the battery. I'll try & get pics tomorrow. Last edited by DISTURBIN' tha PEACE; 03-12-2008 at 05:19 AM. |
03-12-2008, 04:44 PM | #118 |
Pics............ |
03-12-2008, 04:46 PM | #119 |
Oh yeah, also got the CVD's TIGed up.
03-12-2008, 06:15 PM | #120 |
Quarry Creeper Join Date: Apr 2007 Location: Kapahulu Safeway
DTP, Watch out for the metal traxxas yokes slipping off the axial transmission's outdrives. Even with locktite, I've been having problems. Looks good! |
