06-23-2017, 04:19 PM | #21 |
| Re: Stock electronics on 3s?
Higher efficiency at higher voltage. Electrical Efficiency - What are amps, watts, volts and ohms? | HowStuffWorks |
06-25-2017, 08:56 PM | #22 |
Quarry Creeper Join Date: Jan 2016 Location: Boulder
I optimistically hoped to see some good results when running mine on 3S. I ran it yesterday when it was 75 degrees and sunny with the stock 11 pinion. Today it was cloudy and 60 degrees and I used a 10 tooth pinion. My motor temperatures stayed the same both days, @110 degrees. However, my ESC temperatures run just under 150 degrees with 35 minutes of technical driving and mid 120s with 2nd gear, open diff blasts on the dirt road. 3S may work well for other guys, but it seems like it's asking for trouble to me. 2S is where I'll be.
06-26-2017, 10:29 AM | #23 |
I've been crawling and bashing for hours anywhere from 80-110F and yes it get's hot at times, but I peeled the sticker off motor (while it was hot comes off easier) because it's like wrapping a little blanket around the motor. Helps some, but motor still gets hot. ESC gets hot too, but not to bad considering the ambient outside temps. If it burns up, call Traxxas. Edit: Clip on heatsink with or without fan will help too. Last edited by Natedog; 06-26-2017 at 10:56 AM. |
06-27-2017, 06:10 PM | #24 |
Newbie Join Date: Feb 2017 Location: Huntington Beach
| Re: Stock electronics on 3s? I believe people who are running 3S and constantly binding the rig is whats causing the ESC to go out. They rate it at 3S but that's flat land and speed running it. I would run 2S for crawling and not have to worry about it burning up. TRX with 2S is a perfect balance of torque and speed. IMO.
06-28-2017, 12:49 PM | #25 | |
Quarry Creeper Join Date: Feb 2017 Location: frothy river
| Re: Stock electronics on 3s? Quote:
I did an uphill crawl half a mile in low gear on trail, climbing over rocks and stuff but nothing hard and nothing I couldn't get over in one or two tries and my temps were very reasonable on 3s. Its the technical stuff you need to watch you are totally right dude. I still havn't seen temps high enough yet that should fry the esc. I'm assuming it can go all the way to 200F+ before having an issue? although 160-170 would be the limit for me, even that's fairly hot imo. I think its just that I'm not trying rocks/obstacles that are as hard as the more experienced guys here are going to and I'm not driving long enough to see the temps get hot enough because if his went up to 160 on a relatively cool day then .. yea. Last edited by Mountainsofbeer; 06-28-2017 at 12:59 PM. | |
07-02-2017, 04:55 AM | #26 |
Quarry Creeper Join Date: Jul 2015 Location: Moncton
I just got my TRX 4 yesterday from a local hobby shop in Hyannis while on our week vacation, plenty of time to put it through its paces at the campground. I'm going to try both 2s and 3s through it and will see on my end how warm it gets.
07-02-2017, 05:54 AM | #27 | |
I did another run on 3s yesterday, got the ESC to peak in the 140s but still nothing to worry about. I'm getting these higher temps during technical crawling and slow slow driving and creeping over obstacles. When I did a normal "trail drive", even uphill, on 3s the temps were very reasonable. Overall try and just enjoy the new RC and not stress about temps; maybe just check at the end or drive or during a break in the middle. Don't crawl around slowly over stuff in high gear the whole time and you'll be alright. The run times on both 2 and 3s are crazy long its great I don't think I've hit lipo cutoff yet but I've gotten close! Last edited by Mountainsofbeer; 07-02-2017 at 05:56 AM. | |
07-02-2017, 12:07 PM | #28 |
Newbie Join Date: Mar 2017 Location: South Florida
Do you guys think the rig will benefit from either a 35T Axial motor or lower pinion gear??? Maybe both perhaps if I want to do more technical crawling? |
07-02-2017, 10:32 PM | #29 | |
If you have a 9t laying around try that out first. If you decide to go for a motor keep in mind this uses a 550 sized motor, it seems to me that most Axial motors are 540 but I could be wrong. | |
07-02-2017, 11:07 PM | #30 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
I wouldn't try running a 540 can in this fairly heavy rig. You'd be asking for the magic smoke to be let out. Isn't it slow enough in the low ratio as is? I guess that is one bonus of the Axial range, you can easily gear them WAY down and that's without even reaching for a 2 speed. You could have crazy low gearing on the Axials with a 2 speed. |
07-03-2017, 03:27 AM | #31 |
Quarry Creeper Join Date: Oct 2008 Location: Finland
I've driven much heavier scalers with 540 motors and have had no problems. I wouldn't put the axial 35t in this because the kV value is about the same as the titan 21t but it has way less torque. I have only about 6 hours driving on my TRX4 but in my opinion the power delivery is very smooth and makes it easy to crawl. Crawling with open diffs and having to keep in mind the placing of all four wheels is so much fun. I run this on 3S LiPO batteries and I think there is a bit of a lack in wheelspeed in first gear. Second on the other hand is a bit high for crawling but is fun bashing. Might change the ESC to a BRXL and try this on 4S. |
07-03-2017, 04:20 AM | #32 |
Thanks for the input everyone. I have yet to play with my TRX as I'm out of town right now. I will give it a go with the stock electronics and a 3S battery this upcoming weekend. Has there been issues switching out the servo and adding a BEC? I have a Savox 1230sg and a Castle 2.0 BEC in my Bomber. I was thinking of switching that over to the TRX from the start. Thoughts? |
07-03-2017, 10:30 AM | #33 | |||
07-03-2017, 06:37 PM | #34 |
The Titan 21T 550 is a 27-28T 540 can equiv rather than 35T. A 540 35T would be slower and run far hotter with the standard gearing.
07-03-2017, 09:07 PM | #35 |
Newbie Join Date: May 2015 Location: Muskegon,MI
I added a Castle BEC and set it for 6.0vdc and am running a better servo for steering (Ebay metal gear, waterproof and 277oz./in for under $17!) and have had no problems so far with the other electronics. I think at 6.0vdc everything should be safe.
07-04-2017, 04:53 PM | #36 |
Newbie Join Date: Oct 2016 Location: US
Not hating on the rig. When it runs it runs great. Nice setup. However, on another note, I have only out about 3 hours on the rug so far. Already lost the servo, the ESC was blistering hot, and it does not function in 70/30 More. Receiver fails to operate in this mode and goes crazy. Sent from my SM-N920V using Tapatalk |
07-09-2017, 08:26 PM | #37 | |
Rock Stacker Join Date: Mar 2015 Location: OTOW, Ocala, FL
Here is the manual excerpt: RADIO SYSTEM BASIC ADJUSTMENTS Throttle Neutral Adjustment The throttle neutral adjustment is located on the transmitter face and controls the forward/reverse travel of the throttle trigger. Change the adjustment by pressing the button and sliding it to the desired position. There are two settings available: 50/50: Allows equal travel for both acceleration and reverse. 70/30: Allows more throttle travel (70%) and less reverse travel (30%). Note: We strongly recommend to leave this control in its factory location until you become familiar with all the adjustments and capabilities of your model. To change the throttle neutral adjust position, turn the transmitter off before adjusting the neutral position. You will need to reprogram your electronic speed control to recognize the 70/30 setting. The default 50/50 setting is recommended. Turn to XL-5 HV Setup Programming on page 18 for instructions. | |
07-09-2017, 09:24 PM | #38 | |
Sent from my SM-N920V using Tapatalk | |
07-10-2017, 06:19 PM | #39 | |
word 4 word from manual. And yes it does say default for Sport mode and then again in Trail mode even though we all know its actual default mode is Trail mode. 1. Connect fully charged batteries to the model and turn on your transmitter 2. With the model off, press and hold the EZ-Set button until the LED turns solid green, then solid red, and then begins blinking red. It will blink once, then twice, then three times, then repeat. (Another error in the manual since it clearly blinks up to five times as stated below) One blink= Sport Mode is the default setting. It allows full forward and reverse throttle Two blinks= Race Mode removes reverse throttle in case your track does not allow it Three blinks= Training Mode will slow the model down by 50% for young blah blah blah my 6yr. old nephew did just fine in the default mode don't use this mode haha Four blinks= Trail Mode is similar to Sport mode but added drag brake when the throttle is at neutral. This is the defaut (actual spelling error in manual) setting for the TRX-4 and provides a good balance of smooth driving and additional drag brake for descending hills Five blinks= Crawl Mode allows 100% brake (hill hold) with immediate reverse when the throttle is at neutral. This setting is best suited for technical courses where very precise movements are required. 3. Release the EZ-Set button after the number of blinks for the mode you with to select. Note: If you missed the mode you wanted keep the EZ-Set buttom pressed down and the blink cycle will repeat. 4. The LED will blink and then turn solid green (Low-Voltage Detection ACTIVE) or red (Low Voltage Detection DISABLED) The model is now ready to drive in the mode you have selected | |
07-11-2017, 05:54 AM | #40 | |
Stock electronics on 3s? - Similar Threads | ||||
3s on stock electronics? | rockpunisher | Electronics | 4 | 04-14-2016 05:34 AM |
3s on stock electronics? | kikcaffine | Vaterra Twin Hammers | 5 | 03-09-2013 08:12 AM |
3s on stock electronics??? | Sheepdawg23wm | Vaterra Twin Hammers | 6 | 02-13-2013 05:54 PM |
Stock electronics? | abbott90 | Losi Mini-Rock Crawler | 0 | 03-16-2009 10:16 PM |
9.6 and stock electronics? | b2bomber | General Crawlers | 8 | 09-26-2006 09:41 AM |
