Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: New SSD Portal Delete Kits
Old 01-31-2018, 04:27 PM   #21
I joined the Band!
Default Re: New SSD Portal Delete Kits
Will we see brass options?
spaceman5280 is offline   Reply With Quote
Old 01-31-2018, 09:30 PM   #22
Front knuckles have threated holes like scx10 to bolt on brass weights
Taper is offline   Reply With Quote
Old 02-01-2018, 02:41 AM   #23
Don't even bother SSD
Great stuff as always. Can't wait to see what else you will release down the road.
GrimmTheTourist is offline   Reply With Quote
Old 02-01-2018, 06:08 AM   #24
Moderator
JatoTheRipper's Avatar
Originally Posted by JohnnyAnguish View Post
It seems like the new Bronco body is going to be a big hit, so these portal delete kits will make folks looking for a more scale look pretty happy.
If the portal axles bother a scale snob then the fact that it's a linked chassis instead of leaf springs in the back and radius arms in the front like the real truck will be a deal breaker.
Old 02-02-2018, 10:15 PM   #25
Cool, unique option for sure. But damn that becomes an expensive chassis compared to the competition! The quality is certainly there, but regardless it’s pricey.
Either way, great job SSD!
LSXGMC is offline   Reply With Quote
Old 02-04-2018, 12:25 PM   #26
Originally Posted by SSD View Post
Front:
Rear:
CNC machined aluminum rear lockouts
CNC machined aluminum C hubs & knuckles
Hardened steel stub axles
8 Degree King Pin Inclanation (KPI)
Track width is reduced by 12mm (6mm each side)
Reduces the ride height by 13mm
Lowers center of gravity (CoG)
Improves stability
More details here:
Front Axle Portal Delete Kit for TRX-4
Rear Axle Portal Delete Kit for TRX-4
Always loved your works , great idea! Good job Ssd
seychelles is offline   Reply With Quote
Old 02-05-2018, 04:40 PM   #27
Originally Posted by penguin1 View Post
I'm confused. Isn't the reason the TRX4 is so popular is for the portal axles and the other unique systems like 2 speed trans and lockable diffs? If I didn't want those on my Traxxas vehicle why not just purchase a SCX10II.
I couldn't agree more. The whole point was portals and 2 speeds etc which made the trx so competitive . Crazy.
crazee horse is offline   Reply With Quote
Old 02-06-2018, 04:01 AM   #28
SSD
Sorry I forgot nobody ever changes parts on their trucks after they buy them.
SSD is offline   Reply With Quote
Old 02-06-2018, 11:02 AM   #29
I mean, sure, no one is stopping anyone from making the swap, but with everyone and their grandma releasing a scale crawler recently, Buying a TRX-4 only to turn around and remove it's portals and 2-speed gearing seems like an awfully expensive and roundabout way to build a truck. I think I speak for a lot of folks reading this thread, when I say it's just interesting you chose to release these ahead of other potential products.
Also, any reports of torque twist with these? my understanding is the portal gearing was designed to help reduce a lot of that, so curious to see how it's affected now.
AggressorBLUE is offline   Reply With Quote
Old 02-06-2018, 11:50 AM   #30
In my opinion,any new axle options are a good thing as long as parts availability ( traxxas) and dependability/ durability are there. It expands the options for custom axle swaps and custom builds. Nice job SSD.
THUNDER PRO is offline   Reply With Quote
Old 03-26-2018, 07:46 PM   #31
Anyone have these? I’ve been kicking around getting a TRX4 but would rather just have standard (less complex) axles. Was researching to see if SXC10.2 or Ascender axles would work when I found this thread.
number9 is offline   Reply With Quote
Old 08-03-2018, 07:51 AM   #32
Anyone who has bought the portal delete kit and want to sell the portal setup then feel free to pm me
1tuff40 is offline   Reply With Quote
Old 08-03-2018, 11:36 PM   #33
You can also buy a trx4 defender , then a delete portal kit, another kit for a single speed and lock spool difs, a sport body. Finally ,sell everything and buy a Tactical.
trucktrial is offline   Reply With Quote
Old 08-04-2018, 06:02 AM   #34
Yashua
CREEPERBOB's Avatar
Way cool item Katan .
CREEPERBOB is offline   Reply With Quote
New SSD Portal Delete Kits - Similar Threads
New SSD Brass Portal Weights SSD Traxxas TRX-4 21 12-26-2020 02:27 PM
SSD Super Sale! Up to $25 off select SSD RC Upgrade RPP Hobby RPP Hobby 0 11-22-2017 08:41 AM
