Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Full size shift servo mounting.
Old 01-23-2019, 06:36 AM   #1
Default Full size shift servo mounting.
I have just swapped out the micro shift servo replacing it with a cheap waterproof full size servo. It works fine but the whole plastic part that the ESC sits on flexes when I shift gears. The servo is a 15kg type but I'm still using the stock "servo saver" from the original micro servo. The original servo actually mounts to the transmission. Does anybody have any ideas on mounting this more solidly?
Sent from my LG-H870DS using Tapatalk
bbrigg is offline   Reply With Quote
Old 01-23-2019, 07:29 PM   #2
Default Re: Full size shift servo mounting.
I'm following this thread because I'd love to know more about this Sub micro servos are hard to find and more expensive than full size servos, so if this can be done reliably, I'll probably go this route when it's time to replace those.
Sent from my SM-N950W using Tapatalk
BashNSlash is offline   Reply With Quote
Old 01-25-2019, 03:00 PM   #3
Hi folks. I used the servo mounting tabs from axial. If you have a nosy at the pics in the link in my signature they are in there somewhere. Easy to do and lasted a long time.
o0wiz0o is offline   Reply With Quote
Full size shift servo mounting. - Similar Threads
Full size shift servo hitting roll cage. zanthrax Vaterra Twin Hammers 7 01-05-2016 02:58 AM
Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!! Chaotic Crawlers Vaterra Twin Hammers 6 03-06-2013 10:05 PM
LOSI Carbon Fiber servo / lipo mount - any PICS with full size servo? mascman Losi Mini-Rock Crawler 10 12-16-2009 08:35 AM
DNA Dig Custom Servo Mounts, Full Size or Micro Servo Kraqa Axial AX-10 Scorpion 12 09-11-2009 10:17 AM
