06-24-2019, 10:58 AM | #101 |
| Re: TRX4 small C-hubs with Ackerman
I'm really liking the additional clearance of these new C-hubs. Probably going to order a couple more sets for some of my other TRX4s. Last edited by Inspector86; 12-23-2019 at 09:24 PM. |
06-24-2019, 11:47 AM | #102 |
Newbie Join Date: Jul 2016 Location: Germany
| Re: TRX4 small C-hubs with Ackerman |
06-27-2019, 06:47 PM | #103 |
| Re: TRX4 small C-hubs with Ackerman Don't know what a "Steering Pull Rod" is, do you mean a Drag Link or Tie Rod? Last edited by Inspector86; 06-27-2019 at 06:52 PM. |
06-27-2019, 07:14 PM | #104 |
06-27-2019, 08:04 PM | #105 |
Rock Crawler Join Date: Jun 2015 Location: In the Sticks in the Ozarks
Mine seemed to improve the turn radius some before I got the longer "Ackerman" drag-link, then it improved a little more when I got one. I am still using the stock servo link, mounted into the stock hole in the knuckle, though. Not sure if that's a gain or loss, or neither ..... or both. I definitely like the set-up. I've got 10 or 12 hours of crawl time on mine now and everything is still rock solid and smooth. They're "all that and a bag of chips". jim |
06-29-2019, 11:30 AM | #106 |
Rock Crawler Join Date: Dec 2009 Location: Suffolk
Mine are on the way. You guys convinced me!
06-29-2019, 12:37 PM | #107 |
07-03-2019, 03:14 AM | #108 |
Pebble Pounder Join Date: Sep 2015 Location: Australia
Does anyone have the weight of these compared to stock?
07-04-2019, 11:16 AM | #109 |
120g from the manufacturer. I would imagine that is each side. Unsure what stock ones weigh.
07-14-2019, 05:14 AM | #110 |
Got mine installed and couple things: 1. What are the little aluminum spacers for? 2. I had to go back to stock wheels and tires for now because the steering arm hits my tires on the RC4wd rally wheels. 3. The stock bolts that go in the portal cover are too long and bottom out in the new inner portal covers. I had to source some slightly shorter ones from my drawer O' bolts. 4. When I mounted the shocks to the C-hubs instead of the link mount I had to adjust my panhard bar length to re-center the axle. I used a 55 mm (75mm eye to eye) Traxxas Turnbuckle TRX2445. It just clears under full axle compression. It should meet all you adjustable panhard bar needs. |
07-14-2019, 02:39 PM | #111 |
07-14-2019, 03:00 PM | #112 | |
| Re: TRX4 small C-hubs with Ackerman Quote:
The shocks seem to clear ok to me without a spacer. They are close though. | |
07-14-2019, 03:58 PM | #113 |
| Re: TRX4 small C-hubs with Ackerman ah ok, and bring it an advantage the panhard bar length to re-center the axle ?? I used an aluminum spacer that fits perfectly
07-14-2019, 04:13 PM | #114 |
I like it very well and everything fit without problems Last edited by Klaus_S; 07-14-2019 at 04:47 PM. |
07-14-2019, 05:14 PM | #115 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
07-15-2019, 06:05 AM | #116 |
They sure look nice
07-15-2019, 08:50 AM | #117 |
07-16-2019, 02:09 AM | #118 |
07-16-2019, 07:51 AM | #119 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
has anybody found a stateside or "closer" producer of these parts?
07-31-2019, 06:36 AM | #120 |
TRX4 small C-hubs with Ackerman - Similar Threads | ||||
Trx4 kit or trx4 sport | mebeknob | Newbie General | 10 | 09-26-2018 10:38 PM |
