![]() | #1 |
Newbie Join Date: Dec 2019 Location: Blainville
Is there a solution to have more low end torque and more top speed on the TRX4 with a brush system? If so, how? |
![]() | #2 |
Tiny Truck Hoarder ![]() Join Date: Jun 2017 Location: Humboldt county
2 speed? My Defender with 2 speed and brushed motor had plenty of low end torque and in 2nd gear plenty of wheelspeed. Also a good motor like one from Holmes hobbies might offer an improvement over stock. Their use of stronger magnets offer more torque and power and in their Pro motors being hand wound and balanced might offer a tiny bit more wheelspeed. Or you could even gear one of these up a bit and still have as much or more torque than stock (just keep an eye on temps). side note: gear up a stock motor and you loose torque, but if you go with a HH motor since it packs more torque and power with its stronger magnets even when geared up it should in theory still have more torque than a stock sealed can motor. Last edited by HumboldtEF; 01-02-2020 at 06:06 PM. |
![]() | #3 |
I wanna be Dave ![]() Join Date: Aug 2004 Location: central VT
Well it'll go about 11mph on the stock electronics on 3s in 2nd gear. I'd say that's decent for a scale truck. You can gear the pinion up one tooth to a 12 to get a little more speed. If you crave much more speed you really should go brushless. However, the stock motor is rated for 4s power in the original E-revo it debuted in. So if you ran, for example, a Holmes BRXL esc you could squeeze some speed out of the stock motor with 4s. |
![]() | #4 | |
| ![]() Quote:
I'm looking at the 550 trail master 12t and 21t and also the new crawl master sport 12t. I'm realy interested in the crawl master 12t, it seem to be able to go really slow and smooth without sacrificing the top speed at all. | |
![]() | #5 |
Moderator ![]() Join Date: Sep 2008 Location: PA
If you want gobs of torque and speed you should go brushless. If you insist on staying brushed then checkout the two speed transmission. |
![]() | #6 | |
Newbie Join Date: Sep 2018 Location: Italy
| ![]() Quote:
![]() | #7 | |
| ![]() Quote:
According to HH specs, it’s 27000rpm at 12v and the titan 21t is around 21000rpm at 12v. Also significantly more torque with the torque master. | |
![]() | #8 | |
Rock Crawler ![]() Join Date: Jun 2015 Location: In the Sticks in the Ozarks
| ![]() Quote:
![]() ![]() ![]() Anyway, if you haven't pulled the trigger, I'd highly recommend a Holmes motor ..... especially the Torque Master Expert. IF you get one, be sure to reverse the timing... or have them do it ... for the TRX-4. ![]() | |
![]() | #9 |
RCC Addict ![]() Join Date: Aug 2017 Location: Fredericksburg, VA
I'm a huge fan of the HH Crawlmaster Pro 550 12t motor. It is a 5 segment armature and is smooooooth as silk and still as fast as I want to go on 3s. This motor works great with both a CC Sidewinder 4 or HW1080 ESC.
![]() | #10 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
Hobbywing axe 2300kv, crawls like nothing else and also has a drag brake that grips like spiderman on an incline. Can also pop a wheelie if need be under full throttle. All controllable via Bluetooth app on your phone.
Id like a bit more top end speed | nine inch rear | Vaterra Ascender | 5 | 11-07-2018 09:41 AM |
Xerun 17.5 low top end | mytrd94 | Electronics | 16 | 10-10-2016 09:40 PM |
High torque, low speed driveline? | RS10XT david | Redcat Crawlers | 6 | 12-19-2015 08:53 AM |
High torque / Low speed recommendations for the following idea ? | melon | Electronics | 0 | 05-13-2011 02:52 AM |
