Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: Harley's Vaterra Ascender Build
Old 09-11-2014, 04:07 PM   #21
MODERATOR™
EeePee's Avatar
Default Re: Harley's Vaterra Ascender Build
You made up the term force path. Took me 28 times to visualize the arc the steering link scribes while the rest of the axle does its things, but alright. Seems they made a longer than usual panhard bar and a shorter than usual steering link. Curious what would happen if the steering link went to the knuckle.
VP hubs seen to have some room around the hex.
EeePee is offline   Reply With Quote
Old 09-11-2014, 04:21 PM   #22
This is a kit I am really intrigued with. Very nice to see it piece by piece like this. Thanks!
MountainStorm is offline   Reply With Quote
Old 09-11-2014, 04:24 PM   #23
Moderator
badhoopty's Avatar
a longer drag link mounted to the top of the knuckle arm looks like it would reduce bumpsteer a bit and also lessen the drag link angle.
badhoopty is offline   Reply With Quote
Old 09-11-2014, 06:38 PM   #24
Suck it up!
Duuuuuuuude's Avatar
Impressive stuff here for sure. I might have to thin the herd to make room for one...
Duuuuuuuude is offline   Reply With Quote
Old 09-11-2014, 06:54 PM   #25
Exactly what I was thinking
Honchoforever1 is offline   Reply With Quote
Old 09-11-2014, 07:29 PM   #26
Thanks for getting this up so quickly. I'll definitely be following closely (and would have been sorely disappointed if you did anything box stock even for 5 mins). One question I've had about this rig since seeing the initial announcement is the rigidity of the frame given the adjustable rails. On the spectrum between stock SCX10 (very twisty) and Gelande (like granite), how is the torsional rigidity on the Ascender frame?
new2rocks is offline   Reply With Quote
Old 09-11-2014, 11:43 PM   #27
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
The frame rails are very stout in comparison to an SCX chassis. The wall thickness of the steel as well as the overall height of the rails makes it pretty solid. I would say that it also makes the chassis much heavier than a SCX. I never felt like my SCX10 needed to be significantly more rigid however I do know what you mean on the twisting. I have bent multiple SCX chassis over the years, driving like a dumbass mainly, I don't think this chassis will be as easy to bend.
Harley is offline   Reply With Quote
Old 09-11-2014, 11:45 PM   #28
20K Club
Harley's Avatar
That was my initial thought as well. Clearance of the chassis is the issue though, and most likely the reason that they didn't go this route out of the box. If you are OK with reduced suspension travel, this will be a possibility for you.
Old 09-12-2014, 01:36 AM   #29
Looks good Josh!! cant wait to see this thing in action and see what Harley "touches" you put on it! When its completed, are you going to do a side-by-side comparison with an SCX10 video? Also, how does the adjustable frame work with the wheel wells?
LapuaKrawler is offline   Reply With Quote
Old 09-12-2014, 04:34 AM   #30
I would love to see an early release vehicle get a good shakedown in pure stock form for once, to include tires and wheels. We know that most RTR tires and wheels are garbage but why not give them a few runs to see how they break in and give some helpful feedback on them?
gillbily23 is offline   Reply With Quote
Old 09-12-2014, 08:13 AM   #31
20K Club
Harley's Avatar
I'll do a side by side video as soon as I can. I have so many videos to finish right now...
Old 09-12-2014, 09:00 AM   #32
Great thread so far. Maybe this is a newb question, but I am just getting some experience with changing the foams. I am planning on running the stock tires to start with RC4WD Mickey Thompson wheels, but should I also upgrade the foams?
I know there are different sizes of 1.9 foams. What size foams will work for the stock tires?
Black n Blue is offline   Reply With Quote
Old 09-12-2014, 09:30 AM   #33
20K Club
Harley's Avatar
The compound on these isn't bad. But as far as running them, there's two thing about that. First, I don't like Swampers of any sort visually. Two, the stock wheels are glue on, and in general I just don't glue tires unless there is some huge performance reason.
So I went the easy route and got something I like the looks of. If I don't like the way something looks, I really don't have much motivation to work on it.
Old 09-12-2014, 09:32 AM   #34
20K Club
Harley's Avatar
If you want a softer more rock friendly setup, then get the Crawler Innovations Lil Novas. The stock tires are 4.5" tall. Otherwise the closed cell foams are great for a little more speed and such, but I'm not sure if that's where this rig is best fit just yet. I have to play with it some more.
Old 09-12-2014, 10:10 AM   #35
Originally Posted by Harley View Post
Moving right along.
The angle of the drag link is a little steep, and the link is also shorter than the panhard mount. So there is some bump steer, but it is not excessive. I have a video of this that will be included in the in-depth video breakdown of the kit.
looks like a drag link to knuckle might improve that?
I think I'm gonna need one of these.
nice build.
-500
500swmag is offline   Reply With Quote
Old 09-12-2014, 10:34 AM   #36
20K Club
Harley's Avatar
Last night I finished up the build and got the body trimmed out. A few comparison shots for you guys.
Old 09-12-2014, 10:59 AM   #37
Looks awsome!!!!! Any idea on a paint sceme?
Im sure something bad arse
gearhead79 is offline   Reply With Quote
Old 09-12-2014, 02:28 PM   #38
Subscribed even though its a damn chevy!
Cant wait to whoop this rigs ass!
Mighty1 is offline   Reply With Quote
Old 09-12-2014, 03:50 PM   #39
20K Club
Harley's Avatar
King of the Goats in coming up! Get ready man!
Old 09-12-2014, 03:57 PM   #40
So can this run as a class 2 rig , the side by side pic really show how much bigger it is.
old man 52 is offline   Reply With Quote
Harley's Vaterra Ascender Build - Similar Threads
New scaler - Vaterra Ascender aircooled Vaterra Ascender 286 11-02-2014 02:55 PM
Harley's Workshop Build Harley General Crawlers 728 07-15-2014 09:26 AM
Harley's RubberBelly Racing Build Harley Axial SCX-10 290 02-05-2014 11:01 PM
Harley's GC3 Mini Build Harley Losi Mini-Rock Crawler 316 08-27-2010 04:45 PM
Harley's Venom Build Harley Venom Creeper 13 01-28-2009 11:39 PM
