12-05-2014, 03:42 PM | #1 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| CODYBOYS ASCENDER "Modifications" Next thing to do is get the new shocks a little lower in the rear. So now I will see if some of you sharp eyed builders can pick out the next mod I did. I don't think any one else has done this one yet!!! Last edited by CODYBOY; 04-27-2016 at 10:17 AM. |
12-05-2014, 06:17 PM | #2 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
| Re: CODYBOYS ASCENDER "Modifications"
You changed the rear uppers mounting place!
12-05-2014, 09:07 PM | #3 |
| Re: CODYBOYS ASCENDER "Modifications" |
12-06-2014, 01:29 AM | #4 |
You reversed the tranny tray to bolt it on the stock battery tray mounting points!
12-06-2014, 02:04 AM | #5 |
Rock Stacker Join Date: Mar 2011 Location: The Netherlands
Your rear link setup looks different! Lower links have an nice curve and the upper links have a new mounting place !
12-06-2014, 03:59 AM | #6 |
Newbie Join Date: Nov 2014 Location: Finland
I just made the same modification to the upper links.. thanks for the tip! if the transmission is on stock location and you have 2 speed gear box, the upper link gets really close to the shift linkage, but some grinding there helped. Now im going to test it, hopefully it helps with the climbing and torgue twist. |
12-06-2014, 08:57 AM | #7 |
Good job guys!!! If your not going to use the stock battery position this is a great way to get those rear lower links up a little. It also clocks the rear axle to get a better pinion angle. I replace the front and rear lower links with bent titanium. I bought a used 2 speed tranny on EBAY for $50, and replaced all the gears with metal. I still need to find a place for the shifting servo. Here is the body I'm using, think I will list the stock one on Ebay. Last edited by CODYBOY; 12-06-2014 at 08:54 PM. |
12-15-2014, 06:41 PM | #8 |
Got the front motor plate reshaped and mounted. Mounted the transfer case and installed MIP drive shafts. I'm still not sure what shocks I will run on this, I want to get the COG down by running about 40% droop on the shocks. Got most of that done last week, and spent the weekend mounting the interior and weathering the body. Next will be a cage,rock sliders, and front & rear bumpers. Last edited by CODYBOY; 12-15-2014 at 07:07 PM. |
12-16-2014, 01:31 PM | #9 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
it's coming along nicely bud
12-18-2014, 06:30 PM | #10 |
12-18-2014, 09:41 PM | #11 |
Pebble Pounder Join Date: Nov 2012 Location: madera
Nice
12-19-2014, 09:28 AM | #12 |
12-19-2014, 09:10 PM | #13 |
Newbie Join Date: Dec 2014 Location: Saukville
How do you like this kit compared to the others? SCX10 and the TF2
12-19-2014, 09:32 PM | #14 |
I have been RCing since the early "80" and have probably put together 50 kits. Out of all those this is one of the better ones to I have built. As a scaler the quality is top notch. Yes, there have been some issues but for a new product it is well thought out.
12-19-2014, 09:44 PM | #15 |
I worked on the cage today, and this is what I have so far. Pulled it out to clean it up a little. I wanted to put a bit of a different spin on the design, what do you guys think???? Back in the body, and on the chassis. I need to build the spare tire carrier next. Not sure if I want to do a swing out or swing down!??? Any input on what would look best?? Last edited by CODYBOY; 12-20-2014 at 09:07 AM. |
12-20-2014, 09:09 AM | #16 |
Pebble Pounder Join Date: Apr 2013 Location: Germany
That cage is a piece of art! Great work!
12-20-2014, 05:43 PM | #17 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
nice build! looks great!
12-20-2014, 05:54 PM | #18 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
Looks rusty, crusty nice!
12-22-2014, 08:45 PM | #19 |
12-22-2014, 08:57 PM | #20 |
CODYBOYS ASCENDER "Modifications" - Similar Threads | ||||
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde | boolean21 | Scale Videos! | 0 | 10-01-2013 09:39 AM |
"Victim" or "V2" a "Country Boy Customs" class 3 | Mighty1 | 2.2 Scale Rigs | 10 | 05-06-2011 10:56 PM |
