04-26-2016, 10:39 PM | #181 |
Rock Stacker Join Date: Mar 2016 Location: Australia
| Re: Vaterra HD Pinion Gears & HD Driveshafts Info
Another question, is there major differences between the Blazer and Bronco, other than a different body, shorter wheelbase and servo mount? Will the MIP driveshafts fit both? Sent from my SM-N910G using Tapatalk |
04-27-2016, 10:37 AM | #182 |
No difference between the two other than what you just mentioned. MIP driveshaft set for Ascender Blazer: MIP X-Duty C-Drive Kit, Vaterra K-5 Blazer Ascender #14295 I don't see a set specifically for the Bronco, but something could prolly be pieced together, email MIP and see: Contact our Customer Service department: Email: support@miponline.com |
04-27-2016, 11:18 AM | #183 |
Quarry Creeper Join Date: Mar 2015 Location: Castle Rock, Colorado
Here's a good price for the MIP driveshafts. I love mine. http://www.horizonhobby.com/product/...der-p-mip14295 Sent from my iPad using Tapatalk |
04-27-2016, 06:29 PM | #184 | |
Rock Crawler Join Date: Jan 2016 Location: US
| Re: Vaterra HD Pinion Gears & HD Driveshafts Info Quote:
LIFE IS GOOD | |
04-27-2016, 06:33 PM | #185 | |
LIFE IS GOOD | |
04-28-2016, 04:34 AM | #186 |
Quarry Creeper Join Date: Feb 2016 Location: Australia
Hi. Are these HD drive shafts worth it for Tue twin hammers or go after market? Sent from my SM-N910G using Tapatalk |
04-28-2016, 06:32 AM | #187 |
| Re: Vaterra HD Pinion Gears & HD Driveshafts Info They are pretty damn strong, major upgrade over the stock shaft while still being light and cheap. I would try them first and see how they hold up, then go to a steel shaft if you need something stronger.
04-28-2016, 06:44 AM | #188 | |
So far I'm pulling wheelies on concrete (I'm geared for speed ) so maybe I should take a look. For the price they seem great! Sent from my SM-N910G using Tapatalk | |
04-28-2016, 09:46 AM | #189 | |
X2, I haven't broken one yet, buy I'm sure with ROC412 or something it's a matter of time, but they are much stronger than Axials. | |
04-28-2016, 09:48 AM | #190 |
Yes thats what i ment and i just broke a pin in front axle LIFE IS GOOD |
04-28-2016, 09:58 AM | #191 | |
I had to shorten my rear shaft while switching to the Bronco wheelbase. My Craftsman cutters could barely make a dent in the Vaterra shafts, the same cutters go through Axial shafts with ease (cut down another Axial shaft last night so I know they aren't dull yet). Broke out the Dremel to cut down the Vaterra plastic driveshaft. | |
04-28-2016, 10:12 AM | #192 | |
| Re: Vaterra HD Pinion Gears & HD Driveshafts Info Thanks for confirmation. I pm'ed Gunnar about pins for these, but haven't done it yet, I need to get him the pin sizes and buy couple setss....looks like it's time for you to talk to Gunnar. Quote:
04-28-2016, 10:16 AM | #193 |
I ordered some GPM front shafts to try but yeah it was my fault little trigger happy also I broke a front shaft on the beater but that was because it was out of sync LIFE IS GOOD |
04-28-2016, 11:10 AM | #194 |
Nice, looking forward to a durability comparison between Vaterra and GPM CVDs. Did you break the small pin on the beater too?
04-28-2016, 05:33 PM | #195 |
| Re: Vaterra HD Pinion Gears & HD Driveshafts Info |
05-05-2016, 05:04 PM | #196 |
RCC Addict Join Date: Sep 2015 Location: Australia
A little off topic but it looks like the new Losi Baja Rey scale desert truck has the ascender HD tail shaft in the rear, at least the plastic shafts. That thing looks awesome! Thinking it will be my first desert truck. I just watched it do damn near 50 mph passes on 3s while pulling a wheelie on losi Facebook. They must have faith in the ascender HD tail shaft too. |
05-05-2016, 05:23 PM | #197 |
Agreed, that is the only desert truck I've seen that looks promising.
Vaterra HD Pinion Gears & HD Driveshafts Info - Similar Threads | ||||
Pinion & Spur Gears for SCX 10 | garyedson | Newbie General | 3 | 02-10-2013 02:30 PM |
Losi worm & pinion gears | no2hud | Team Losi Comp Crawler | 8 | 03-18-2010 12:37 PM |
