![]() | #1 |
Pebble Pounder Join Date: May 2011 Location: Santa Cruz, Ca.
So now that I have the proline Comanche body, I noticed the body WB is 313mm and the ascender stock is 314mm. I wouldn't think this would be a noticeable difference but it's enough to not look quite right. It seems like I've heard guys on the forum talk about making minor adjustments to slightly change WB but can't find the info from searching. Do I just try and shorten the links? If I take out a spacer wouldn't that be too much and have to adjust the frame then too? Thinking may just have to make a shorter spacer. Anyone done this?
![]() | #2 |
I'd use benchtop disc or belt sander and shave a millimeter or whaterver off the spacer and then screw it all back together. Mark your line before you start sanding and take a little off at a time, but personally finding it hard that one mm is that much. Pic?
![]() | #3 |
Pebble Pounder Join Date: Oct 2009 Location: Tacoma
1 mm I don't think it would even be noticeable.
![]() | #4 |
I agree splatt, didnt think would show. Natedog - Guess I need to re-buy a star...havent posted a pic in a long time and looks like I can't till I purchase a star again, no problem. But for now here are some links I hope work to show how much the front is off when the rear is centered. http://i772.photobucket.com/albums/y...psz5t45nfi.jpg http://i772.photobucket.com/albums/y...psg9oswvu0.jpg http://i772.photobucket.com/albums/y...psxbizzipw.jpg |
![]() | #5 |
Slightly off, but looks fine to me. Your vertical dashed line is not perpendicular to the table, so it looks like it's off more than it is. Shorten the links a millimeter or two. ![]() |
![]() | #6 |
Pebble Pounder Join Date: Jan 2015 Location: Calgary
Nate dog is right it doesn't look to bad. If you can't shorten your links you can always make custom links with 8/32 threaded rod and 1/8 steel tube
![]() | #7 |
Quarry Creeper Join Date: Mar 2009 Location: martins ferry
Don't need a star to post pics you're using photobucket just copy and paste the img code ![]() ![]() ![]() If it was me I would shorten it a couple by pulling out the spacer in the front link and replace it. If you could get your hands on a couple of the spacers Axial uses for the front mount battery tray you could cut them to any length you needed. |
![]() | #8 |
Thanks for the pic tip 2000...I thought about shaving down the spacer in front but may want to put blazer body back on at some point, so finding alternate spacer and cutting sounds good to me. Thanks for the help guys.
Shorten wheelbase beyond 11.3 | xCoolHandLukex | Axial SCX-10 | 15 | 11-07-2012 09:07 PM |
How do you shorten the wheelbase on a honcho? | RENEGADE< | Axial SCX-10 | 5 | 11-30-2011 08:02 PM |
To shorten or not to shorten?? | MnRockCrawler | General Crawlers | 6 | 02-03-2011 10:13 PM |
Best way to shorten Wheelbase to 12.5 | skkeeter | Newbie General | 5 | 08-04-2010 10:46 AM |
Shorten my honcho's wheelbase for the new Proline Cherokee Body?? | yellowpasta2000 | Axial SCX-10 | 13 | 05-08-2010 03:17 PM |
