06-15-2016, 05:27 PM | #101 | |
| Re: Codyboy's "bulldog bronco" ascender Quote:
Thanks for sharing your how to again! Nice fab job with $4 in parts. | |
06-16-2016, 08:37 PM | #102 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
| Re: Codyboy's "bulldog bronco" ascender Quote: |
06-17-2016, 11:22 AM | #103 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Codyboy's "bulldog bronco" ascender Quote: Ernie, Last edited by CODYBOY; 06-30-2016 at 07:04 PM. |
06-17-2016, 01:09 PM | #104 |
Ernie, Good talking with you again and congrats on your vendor's star, looking forward to more of your nice products! |
06-17-2016, 02:55 PM | #105 |
Pebble Pounder Join Date: Oct 2015 Location: Atkinson, ME
You'll be selling these now? What kind of price range are we looking at? I am interested.
06-17-2016, 04:46 PM | #106 |
If I have enough interest I will. I'm not going to post any info in the vender section for now, I don't want this to get carried away ( I want to stay retired). These will be for front axle only for now. I will take a look at the rears later. I will pm you with price. Ernie, |
06-17-2016, 08:40 PM | #107 |
Ok, I want to mount my 1.9 tires on some Vanquish v2 or v3, can't remember which they are. So I need some odd size foams. I guess I will bore you with another How I do it (it might help someone)?? I'm starting with some repurposed closed cell foam (a $1.99 Goodwill paddle board). Using a 4.5" hole saw. That board was just right for the four foams. Now to cut out the centers with a 1.75" saw. Test fit to the 2.2 wheel. I'm using these wheels because 1. I'm cheep, they have been resting in my wheel box since before we knew what a XR10 was. 2. They are black with cool orange rings. 3. I can go to a larger brake drum weight if I want. 4. I like the way the 1.9s look on the 2.2s. Next, to a jig on the wood lathe to check for true and clean them up. Next step is the router table a relief and notch so they set nicely inside the grove in the wheels. That was why I used the 1.75" hole saw to cut out the center. Outer foams are cut on the band saw. 5/8" thick will fill the tires nicely. I cut them to length (12") and glue the ends together with contact cement. Here you can see the notch in the foam and the grove in the wheel, this keeps the foam from sliding from side to side. Finished product, they fit and look pretty good. All for now, thanks for looking. Ernie, |
06-18-2016, 12:59 PM | #108 |
Very nice work on the foams! That's why I like external clamping beadlocks without internal rings, easier to mount and help hold foam in place.
06-20-2016, 06:52 PM | #109 |
| Re: Codyboy's "bulldog bronco" ascender |
06-20-2016, 07:08 PM | #110 |
Quarry Creeper Join Date: Dec 2012 Location: Remember, wherever you go. There you are.
Nice job! you've done it again man, color scheme looks killer.
06-20-2016, 11:51 PM | #111 |
Paint and body looks great! Hope you have better durability with those VP wheels than my buddies did, look great but a good tumble often rips the center out of the wheel.
06-21-2016, 12:39 AM | #112 |
Quarry Creeper Join Date: Aug 2006 Location: Pilgrim,Ky
Looking good!
06-21-2016, 09:51 AM | #113 | |
| Re: Codyboy's "bulldog bronco" ascender Thanks Poprivet, I like the paint colors, but seeing it on the chassis now I'm not sure I like the body, chassis, and tire/wheel combo look together! Is it that the body looks to tall. You have a good eye, what do you think it is? Quote:
Thanks avengernut, input? | |
06-21-2016, 10:25 AM | #114 |
Body too tall or cage top too low. Silver or gunmetal grey wheels would look better than black imo. EDIT: I like the body paint job. Last edited by Natedog; 06-21-2016 at 12:18 PM. |
06-21-2016, 11:08 AM | #115 |
Umn,maybe try a different wheel an tire combo? Sent from my SM-G900R6 using Tapatalk |
06-21-2016, 11:59 AM | #116 |
06-21-2016, 12:30 PM | #117 | |||
Ernie, | |||
06-21-2016, 12:35 PM | #118 |
06-21-2016, 06:40 PM | #119 |
Ok, I was able to lower the body 1/2", and changed out to different wheels a tires. I like the looks a lot better. Before and after. Thanks for looking. Last edited by CODYBOY; 06-21-2016 at 06:45 PM. |
06-21-2016, 06:56 PM | #120 |
The roof did look a little low, but i thought it made it look chopped, and chopped is always cool . That being said... it does look better with the body lowered. I liked the first wheels, but they need a red beadlock to tie in with the pinstripe. Just my opinion. Last edited by Poprivet; 06-21-2016 at 09:31 PM. |
Codyboy's "bulldog bronco" ascender - Similar Threads | ||||
Bulldog/Mattzilla "Mountain Buggy" | Bulldog | 2.2 Scale Rigs | 88 | 03-30-2016 07:59 AM |
"Rhino" 1/9 Nissan Patrol 4x4 Y60 1997 build with Vaterra Ascender K5 | clarketian | 1.9 Scale Rigs | 25 | 03-15-2016 05:36 AM |
"My Bulldog Berg build" | bigron | EnRoute Berg | 61 | 02-05-2014 07:59 PM |
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde | boolean21 | Scale Videos! | 0 | 10-01-2013 09:39 AM |
