Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: What did you do to/with your Ascender today
Old 06-11-2018, 07:45 PM   #381
Default Re: What did you do to/with your Ascender today
Got my "Little Lebowski Urban Achievers" K-10 and Project "Clearance Rack" an RTR friend because the K-5's are on the way out....
I may have a problem....
druz is offline   Reply With Quote
Old 06-13-2018, 11:22 AM   #382
Finish building these rock sliders and doing the shock collar mod.
BrokeBob is offline   Reply With Quote
Old 06-13-2018, 03:23 PM   #383
Finished putting my axles together. Added some castor wile I was at it.
touch racing is offline   Reply With Quote
Old 06-14-2018, 11:48 AM   #384
CODYBOY's Avatar
Hmm, I know a guy that makes axles similar to those! nice work.
Make sure you pin the brass to the housings with 3mm screws, or they will eventually start to spin. Especially the fronts.
Ernie
CODYBOY is offline   Reply With Quote
Old 06-29-2018, 03:54 PM   #385
FLAT BOINGERS!
Jato can I be in the mafia now? lol
Shinchu is offline   Reply With Quote
Old 07-09-2018, 07:17 AM   #386
Wrapping up the power wagon. Still some detail work but I'm happy to be able to drive it now.
Sent from my SM-N950U using Tapatalk
OldNTired is offline   Reply With Quote
Old 07-11-2018, 08:48 PM   #387
Repainting my body with more durable paint after Proline BTF destroyed the last job . A lot more weathering and rusting than the last paint job.
Sent from my Pixel using Tapatalk
Damatheus is offline   Reply With Quote
Old 07-13-2018, 09:30 PM   #388
Baby got some new shoes today.... (not sure which baby, but I do what I can.....)
Old 07-14-2018, 08:14 PM   #389
Putting in a hobbywing brushless 17.5 motor and V3.1 esc. Was going to put them in an associated sc6.1 but got bored and wanted something different. Can’t wait to try it out. Might go up a tooth on the pinion. Also got some new pro line km3’s and ssd links but they won’t be here until Monday.
BAJAREY2017 is offline   Reply With Quote
Old 07-17-2018, 10:24 AM   #390
wyd
Those are great looking wheels. I just ordered those exact same rims on Monday and expect them to be here Wed. I went with the RC4WD 1.9 Goodyear MT/R
wyd is offline   Reply With Quote
Old 07-17-2018, 10:57 AM   #391
SHINEY!!!! and way too big lol but the added capability! might shoot some vid later today when i get home.
Old 07-22-2018, 04:38 PM   #392
Got tired of toasting Savox 0231 servos in the girl's truck. Last one lasted less than six hours trailing.
Same problem with all three...truck would stop dead during operation as if the low volt battery protection kicked in. Letting it sit for just three or four minutes, it would operate fine again for a few minutes, then go dead again.
I'll say up front I've been running it with a CC Sidewinder 3 ESC without a BEC, but I shouldn't have needed one. The first 0231 servo lasted three years of hard trailing around the country. I have a lot of rigs and rotate them based on how I feel that morning, but even though she has the Ascender and an SCX10 Power Wagon she always runs the Ascender.
I shotgunned the electronics today, replacing the Sidewinder with a Hobbywing 1080 and installing a DS3218 servo. Was a good time to remove and flush the still original Axial motor, check the spur, clean everything up and do a bumper-to-bumper health checkup.
Operation is much smoother with the Hobbywing, as expected. Nice fringe benefit to get rid of the annoying buzz that was ever present in the Savoxes.
Bye-bye, Savox...bye-bye.
2mtech is offline   Reply With Quote
Old 07-23-2018, 07:22 AM   #393
I wonder if the current crop of 0231's are of lesser quality. I had the exact same problem with mine as you described. It would "freeze" and then work after a few minutes. However, mine also had a hard time turning left and couldn't steer worth a crap sitting still. And this was with a 1080, for reference. I put the DS3218 in mine and it has been great so far. It doesn't even get warm, where the Savox would get pretty hot after mild use.
skinnyj is offline   Reply With Quote
Old 07-23-2018, 08:42 AM   #394
good call buddy. i am running the same exact ESC and servo on my rig now. remember my post about ripping apart the steering links on my truck? yeah, that was with the might of a 3218 on a mere 6.4 volts from the internal 1080 bec. i cant fathom what these things could do if they could take more voltage.
Old 07-23-2018, 10:40 AM   #395
Interesting to be sure. I realized after reading your post that I forgot to mention the servos were getting awfully hot to the touch, so I experienced that as well.
See "Bye-bye Savox"
Yeah, I'm hoping the girl's not just going to tear things up now...she's still on original stock steering parts but somehow I get the feeling that may change soon... I also realized I had her DX4C throttle travel set to 100%, so I bumped it to 150% where mine is...may have been a poor choice.
Old 07-23-2018, 10:48 AM   #396
See "Bye-bye Savox"
I have been having bad luck with my savox servos also. I put one in my f100 when I first got it and it lasted 2 runs. I have another one in my daughters rig and it just seems to be lacking power and ever since I put that servo in it has cut a solid 45minutes off the run time.
Sent from my ZTE A2017U using Tapatalk
mgputer is offline   Reply With Quote
Old 07-23-2018, 11:08 AM   #397
If I could've remembered when exactly, or where, I bought this last one I may have considered looking into some kind of warranty return. I usually disregard warranties on this kind of stuff as by the time you jump through all their flaming hoops it makes $35 kind of irrelevant.
I'll settle for talking with my wallet and using a better made product moving forward.
Old 07-23-2018, 12:03 PM   #398
I recall reading in another thread that Savox tends to build their servos to run "hot" (high current?) to meet their specs. It would explain the excess heat and possible run-time issues.
Old 07-23-2018, 12:50 PM   #399
I think that's probably it. I think that's why they buzz all the time. I believe the encoder wheel is partitioned poorly so it is constantly working or the armature constantly is stuck between commutator tabs? I'm just guessing but I think it's something like that. I am not sure but I used to have nothing but good luck with them and now I don't feel like the quality is there anymore.
Old 07-23-2018, 01:18 PM   #400
I may have thought that if in the first two years of constant experience with them I ever had the heat issue. The first one that failed in particular had never exhibited excessive heat until it started locking up the rig so I don't think it's inherent to the component.
What did you do to/with your Ascender today - Similar Threads
i got a vaterra ascender rtr today 4x4pornstar Indiana 8 12-20-2015 11:29 AM
My Ascender Built, One Bad ascender CustomCrawlRCMike Vaterra Ascender 3 07-03-2015 03:45 PM
