09-26-2018, 08:59 AM | #21 |
| Re: 27th...what's coming? Unless they made a new version for this truck, the Race Claw tires are only 4.1 inches tall. The wheel wells are probably reasonably sized, it's the rest of the body that is too small. I'm sure they wanted to keep it on an existing Ascender wheelbase but a properly sized Suburban needs to be on a 14+ inch wheelbase chassis.
09-26-2018, 09:02 AM | #22 | |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
| Re: 27th...what's coming? Quote:
Sent from my SM-G930V using Tapatalk | |
09-26-2018, 09:03 AM | #23 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
I would hope that a kit version would include some upgrades like metal trans gears and links, like Axial does with the Bomber. It doesn't get any better the more you look at it either... Last edited by 2mtech; 09-26-2018 at 09:05 AM. |
09-26-2018, 10:19 AM | #24 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
I was hoping for something better than a bad fitting body with lights. Who the hell is using these huge tires?!?!? I was hoping for a suburban that was more closely resembling the K5 body, and a 14”+ frame rail extensions/link extensions for the rear! Not more of the same old same old. Also an axle that would also allowed me to clock the axle tubes/pumpkins, cause longer links on the top just don’t cut it, since the axle link tabs are static! and when I try to clock the axle for a better driveshaft angle, then the shocks aren’t where I’d like them to be. I’d’ve also liked to see an servo on axle bracket, CMS is fine for scalers, but I’m not nuts about scale, and a servo on axle would work better turning in both directions. Last edited by Alexander_0_1; 09-26-2018 at 10:25 AM. |
09-26-2018, 10:27 AM | #25 |
Blah blah blah. All I can see is one too many doors/ handles on the driver's side.
09-26-2018, 10:32 AM | #26 |
^^^ lmao
09-26-2018, 10:41 AM | #27 |
Newbie Join Date: Jul 2008 Location: toronto
extra-ordnary...plain with-out a twist.
09-26-2018, 11:57 AM | #28 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Re: 27th...what's coming? Last edited by Frank211; 09-26-2018 at 12:00 PM. |
09-26-2018, 12:03 PM | #29 |
| Re: 27th...what's coming? |
09-26-2018, 09:41 PM | #30 |
Ah, ya bunch of negative Nellys! Fer cryin' out loud they coulda killed the Ascender dead... Another version using some new parts fer cheap is great for those who ain't bought one yet. ...and those parts will be available separately for those who want to mod stuff. I want the grille to throw on my as-yet-unpainted replacement K10 body, so I won't have to hack one up to do lights. Then (as my pal Miatardo said in a text to me earlier this evenin') maybe use the new body to make a slammed on-road limo... Wheels might be dyeable, or give 'em a subtle paint wash to bring out the lug nut details and spray 'em with matte clear. As mentioned earlier, throw narrow axles under one (those new Boom Racing ones?) or get CODYBOY to whip up a set. Plastic gears and links are no big deal, swap 'em out right off the bat. (Can ya tell I like it?) Hell, use this as a template, a dragster Suburban! Call it the "S'Bourbon" and have it sponsored by Jim Beam! |
09-27-2018, 03:19 AM | #31 |
RCC Addict Join Date: Sep 2015 Location: Australia
so the new Ascender body is one of these? edit- I just realised these are 2 doors-fail! |
09-27-2018, 03:52 AM | #32 |
Rock Stacker Join Date: Apr 2018 Location: GR, MI
That model of suburban had 1 door on the drivers side and 2 doors on the passenger side. Fun fact the early ones had wood flooring in the back cargo area.
09-27-2018, 09:00 AM | #33 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
What does that look like next to the blazer? I'm worried that burb is more like 1:12 scale. If it actually is a true 1:10 the wheelbase should be close to 340mm? *runs off to look for that awesome hardbody burb build...* |
09-27-2018, 09:13 AM | #34 |
Pebble Pounder Join Date: Feb 2016 Location: Manchester, NH
I understand the plastic parts to bring it in at their price point, but I am not digging that body.
09-27-2018, 09:34 AM | #35 |
09-27-2018, 09:43 AM | #36 |
09-27-2018, 10:29 AM | #37 | |||||
Correct, no Ascender 2.0 as has now been revealed. Yes, plus a few other changes. Yes! Quote:
Correct, unfortunately must log in to BF to see the video. Yes, the parts are all interchangeable. Quote:
Correct and yes helps lower the price for those looking to get into crawling. Plastic gears are better plastic than Axial and links are reinforced with a hardened steel rod inside. Quote:
Yes. Quote: Yes, thanks for the link! Last edited by Natedog; 11-08-2018 at 02:14 PM. | |||||
09-27-2018, 10:48 AM | #38 |
Maybe with tall 1.55's the body would look somewhat more proportional...and something a little more not white. Now it's kinda like looking at one of those impossible 3D drawings...the more you look at it the more your mind starts to hurt... |
09-27-2018, 11:28 AM | #39 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
I actually really like the body. All of my crawlers have wonky proportions. It becomes so obvious when they sit next to each other on the shelf
09-27-2018, 01:55 PM | #40 |
| Re: 27th...what's coming? https://www.youtube.com/watch?v=79kcXEgduiQ EDIT: I just noticed this thing is bumper-less, the front doesnt seem to be attached to the chassis and the rear definitely isn't attached Also new tires!, not sure if anyone has mentioned them yet. They look okay, not licensed but they look scale-ish maybe a BFG knock off Mud Terrains or the Flat Irons Last edited by HumboldtEF; 09-27-2018 at 02:42 PM. |
27th...what's coming? - Similar Threads | ||||
G6 at Ewans Sep 27th | byflex11 | Michigan | 36 | 09-29-2014 06:40 PM |
NorthShore Sunday the 27th | psycho rc | Tennessee | 9 | 10-27-2013 08:21 PM |
Sanford Sat 27th | mach1revo | Florida | 1 | 11-28-2010 08:09 AM |
Kaspers 27th Birthday!!! | Stinkyy | Wisconsin | 9 | 07-11-2010 09:18 PM |
Dec. 27th | limited77 | South Carolina | 5 | 12-26-2009 07:08 PM |
