03-14-2016, 12:13 AM | #21 |
Newbie Join Date: Mar 2016 Location: Yuma, Az.
| Re: Herbie the "THUG BUG" Baja style
Looking good so far! Here are a couple... The body after paint.... Directly from the White House to you.... |
03-14-2016, 09:43 AM | #22 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Herbie the "THUG BUG" Baja style |
03-14-2016, 09:46 AM | #23 |
03-18-2016, 01:41 PM | #24 |
It is a nice bug body!! I should have some more progress posted up tonight. I kind of thought everyone was getting tired of seeing post every night. |
03-18-2016, 03:41 PM | #25 |
RCC Addict Join Date: Jan 2009 Location: Bend
Every night sounds awesome to me. I'm subscribed and get auto updates through tapacrap. Get it on brotha! Not every day you see full-on tube chassis Twin Hammers based builds.
03-18-2016, 03:57 PM | #26 |
Rock Crawler Join Date: Oct 2009 Location: OUT THERE
Keepem comingThis bug is coming along nice wish my twin hammer looked like that. Nice work |
03-18-2016, 05:29 PM | #27 | ||
| Re: Herbie the "THUG BUG" Baja style Quote:
Games over, now back to RC Baja bugs. Took another day off to make a set of doors for a friend. Did some more work on the cage today. The front bumper, do you think I need a small stinger? Trying to figure out the front shocks. I don't really want to put holes in the body to make them fit! Some looks with the body on. I'm building this one so I can remove the body. With some 1.9 tires. The tires are not mounted. A look with 1.5 tires. Front bumper. Thanks for looking. Last edited by CODYBOY; 03-18-2016 at 11:05 PM. | ||
03-20-2016, 02:43 PM | #28 |
So earlier in the build I said I would show you the new MIP front mod with the B5M rear arms. Some lathe work on the MIP and Hammer shafts. All work completed on the lathe. Soldering completed. Drilled out the B5Ms to 5/16" and installed 3mm brass insert. Now I can use the stock 3mm pin screw. Next two photos show how much beefier the B5M arms are compared the B4.2 arms after they are modified. Ready to assemble. And a couple travel shots. I can get more compressed travel, I just need to remove a little material on the inside of the arm. Thanks for looking, if you have any comments feel free to share them with all of us. Last edited by CODYBOY; 03-20-2016 at 02:58 PM. |
03-21-2016, 09:31 AM | #29 |
Rock Stacker Join Date: Mar 2014 Location: Blackcreek
Sir where did you get your brass inserts from?
03-21-2016, 10:10 AM | #30 |
Rock Stacker Join Date: Sep 2015 Location: Brunswick Hills
Wow ....I'm really starting to love that cage without the body hiding all your great artistry ! Looks more U4 "naked".
03-21-2016, 10:41 AM | #31 | |||||||
| Re: Herbie the "THUG BUG" Baja style Mcmaster-Carr
That was part of the reason I removed the top. Who knows what it will look like when I'm done? Part of the fun of not copying a 1:1 | |||||||
03-21-2016, 11:00 AM | #32 |
Quarry Creeper Join Date: Dec 2012 Location: Remember, wherever you go. There you are.
Great job man. I may have to gets me a twin hammers one day. And I agree with SMW, a little "naked" is always good. Cage looks sick! |
03-21-2016, 03:18 PM | #33 |
Thanks for the reply, also how is the brazed joints holding up? I'm holding out for a friend to tig it but I'm impatiant
03-21-2016, 03:28 PM | #34 |
I only have the lil' tj to judge by, and it doesn't see much abuse (I baby it a little). I'd put a brazed joint up against a tig joint any day of the week. Much stronger than I thought they'd be.
03-21-2016, 06:44 PM | #35 |
2x what Poprivet said about brazing. I think the industry calls it brazing, but the wire we use has a high % of silver (Safety Silv 56) and flows much easier than a brazing rod. If you make sure to clean and shape your joints, they are very strong. |
03-21-2016, 11:11 PM | #36 |
03-22-2016, 01:42 AM | #37 |
Newbie Join Date: Aug 2015 Location: Novara
Just a question about the MIP front mod, do You also gain a better steering radius with it or just better excursion from the suspension? I'm thinking of doing the same but using VP wraith high steering CVDs. Thanks in advance, Claudio Last edited by Kleebatch; 03-22-2016 at 01:53 AM. |
03-22-2016, 09:04 AM | #38 |
The steering is still the same, if you look at the photos of the before and after lathe work and brazing you can see that I'm still using the Hammer front axle. If you would, please share any new ideas you have on improving the steering and articulation of this truck. Ernie, |
03-22-2016, 09:34 AM | #39 |
Quarry Creeper Join Date: Aug 2014 Location: Orange County
You can try something like Maxbonv just go to last page and look at how he used the vvds. The maxbonv KoH Twin Hammers Sent from my SM-G920T using Tapatalk |
03-22-2016, 09:47 AM | #40 |
VVDs offer no more steering angle than our current shafts. The real answer would be some shaved unis, which would require both custom caster blocks and knuckles. Unis are good for 70* with shaving, 10-15* of that would be lost as suspension travel, leaving 55-60* for steering.
Herbie the "THUG BUG" Baja style - Similar Threads | ||||
Rock BUG-E build... Aka the "lug bug". | Rock solid | 1.9 Scale Rigs | 44 | 04-04-2017 10:45 PM |
"Beetlejuice" Baja Bug | Dextroyer | Paint and Body | 2 | 03-08-2016 08:58 PM |
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde | boolean21 | Scale Videos! | 0 | 10-01-2013 09:39 AM |
