01-18-2015, 10:55 AM | #101 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
| Re: DCW Made to Order Delrin Wheels
These are gunna be sweet! Sent from my iPhone using Tapatalk |
01-18-2015, 08:52 PM | #102 |
For Rxracer |
01-21-2015, 11:15 PM | #103 | |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: DCW Made to Order Delrin Wheels Quote:
Thought I'd post up a couple shots of the wheels Duuuuude made me for day #9 Christmas giveaway. DCW 2.2's with Swamper TSL XL's and LockedUp Hardware. Voodoo U4's just didn't look right. Perfect fit for the 1/6 Gladiator. Thanks again, Love them. I highly recommend these wheels, It's nice to have something made to your own specs. | |
01-23-2015, 07:09 PM | #104 |
Sneak peak Sent from my iPhone using Tapatalk |
01-24-2015, 02:14 PM | #105 |
Some 1.9's for a local. |
01-26-2015, 10:18 AM | #106 |
Just to be "that guy". I need you to make me these as shown in shiny silver with copper inserts, no detail to be left out, and for the price of am "off the shelf" flavor 8 hole. Ok, seriously now... Glad to see you doing these Duuuuuuuude! You have a PM about a real and doable set that I NEED *cough*want really bad*cough* |
02-02-2015, 10:53 PM | #107 |
Pebble Pounder Join Date: Dec 2013 Location: Derby Line
How much for - dia 2.2 " - 1.25" wide, - 10 hole style, - reversable ( to have 2 different offset with the inner radius shape on both side) - stock Axial beadlock 2.2 6 holes bold pattern - Mayhem Engineering hub fit ( 6 bolt and centering hole) - black colored delrin How much does that cost shipped? Thanks, you make really nice lightweight wheels!!! |
02-03-2015, 08:39 PM | #108 |
Rock Crawler Join Date: Aug 2006 Location: Pinedale, WY
Are 40 series or 3.8" wheels possible for order?
02-03-2015, 08:39 PM | #109 |
Not at this time, sorry.
02-03-2015, 10:25 PM | #110 |
Kidney beans sure are popular. 2.2's for DickyT. Beadlock on the front, glue on for max knuckle clearance in the back. 2.2's for Jmoritz |
02-04-2015, 09:52 AM | #111 |
Those look fantastic Duuuuuuuude! I am looking forward to them arriving and getting them on the Yeti. Much thanks sir!
02-04-2015, 10:02 AM | #112 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
Have you ever done a beadlock dually wheel set? This is something I would be interested in.
02-04-2015, 10:10 AM | #113 | |
I hope to have a personal project coming up that will have duals out back, but they may end up being really wide single piece wheels that are grooved for two tires. | |
02-04-2015, 10:17 AM | #114 |
No, I meant a regular dually style, such as an F350. I would like to build a dually, but I don't want to glue the tires to the wheels, I would prefer a beadlock system. Could you machine out a "spacer" that allows both rear beadlock wheels to bolt together?
02-04-2015, 10:52 AM | #115 |
These are what I made for Szczerba. I semi-sized them off of a Ford F450. With that kind of offset, you need the wheel to be skinny or there are some interference issues, even with a monster sized hub. I've got them back to rework them so the fronts will clear the steering arms on the knuckles. Could I do beadlocks in that style? Absolutely. |
02-04-2015, 10:57 AM | #116 |
I was thinking of using the Axial 1.9 Falken Wildpeaks because they are not a "fat" tire. Do you have more photos of those wheels put together? With this design? (or something similar) Last edited by bilinvic; 02-04-2015 at 11:04 AM. |
02-04-2015, 11:32 AM | #117 |
I don't do that design any more. Too time consuming without charging $$$$ for them. Only other pic I have. |
02-04-2015, 11:41 AM | #118 |
I like them, but with beadlocks. I assume a SLW hub is used? Which beadlock rings do you recommend with your wheels.....sorry for all the ?????'s.
02-04-2015, 11:44 AM | #119 |
Whatever hub you want. If I don't have the specs, you can send it to me so that A) I can have the measurements for future use, and B) I can ensure they fit together properly. Rings can come from anywhere. LockedUP has a pretty good selection if you like aluminum, MThead has a good selection if you like delrin. Both use Axial bolt patterns. |
02-04-2015, 11:51 AM | #120 |
PM sent
DCW Made to Order Delrin Wheels - Similar Threads | ||||
Steering/Suspension Aluminum, Titanium, Delrin links. Custom made | Erik D_lux | Chassis and Suspension | 72 | 07-31-2020 05:28 PM |
Ultralite Delrin D-Mount from DCW | Duuuuuuuude | Chassis and Suspension | 239 | 08-05-2014 09:49 PM |
Testing Interest: Made to order wheels | Duuuuuuuude | Tires and Wheels | 52 | 05-19-2014 08:42 PM |
