03-10-2015, 11:39 AM | #161 |
| Re: DCW Made to Order Delrin Wheels
Reversible/dual offset 1.9s for Killa_cotton. |
03-10-2015, 11:42 AM | #162 |
You can now find DCW on Facebook! Visit, like, and keep an eye out for up and coming projects that you might not find here! DCW Crawlers on facebook |
03-12-2015, 07:15 PM | #163 |
RCC Addict Join Date: Dec 2009 Location: Laceys Spring, Alabama
| Re: DCW Made to Order Delrin Wheels |
03-24-2015, 07:42 AM | #164 |
RCC Addict Join Date: May 2009 Location: Weston
How can we convince you to do a 3.8 run for the Yeti XL? |
03-24-2015, 07:55 AM | #165 |
03-24-2015, 08:07 AM | #166 |
I fugured that was the case. Maybe someday.
04-03-2015, 11:23 PM | #167 |
A little somethin' somethin' for Cabron... |
04-04-2015, 12:16 PM | #168 |
Pebble Pounder Join Date: Feb 2014 Location: Sweden
Cred for great response and info from the duuuuude today! The result? An order for these wheels 1. Size -- 2.2 2. Color -- Black 3. Style -- "Kidney beans" 4. Width -- 1.1" 5. Backspacing/offset -- As much as possible. 0.85" 6. What hubs you will be using -- VP slw 7. Beadlocks or glue-on -- Beadlocks 8. If beadlocks, what rings you will be using -- Standard Axial pattern Can't wait to see how awsome this will be! Will post pics once I get them. |
04-04-2015, 09:11 PM | #169 |
Prizes for Scale Nats ready for boxing up. |
04-06-2015, 10:27 AM | #170 |
1.9's for Jebster. |
05-03-2015, 09:25 AM | #171 |
Pebble Pounder Join Date: May 2013 Location: Miami
Can you do them with the regular single nut hub
05-03-2015, 09:26 AM | #172 |
Not at this time, sorry.
05-21-2015, 01:58 PM | #173 |
Rock Stacker Join Date: Feb 2011 Location: Eisenerz Erzberg
Hello! I am luke from Austria and want too order some wheels from you! Here is exactly what i want 1. Size - 1.9 2. Color - black 3. Style - 10 hole 4. Width - 1 " 5. Backspacing/offset - whole backspacing 6. What hubs you will be using - slw 7. Beadlocks or glue-on - glue on 8. If beadlocks, what rings you will be using- no beadlocks Pleas tell me a prive with shipping to Austria Thank you Luke Last edited by trialpsycho; 05-21-2015 at 02:05 PM. |
05-22-2015, 01:07 PM | #174 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
Could you build some wheels for these tires? Dick Cepek 1.9 Giant Puller Pulling Tires Have a Bruder Mack Truck and thinking of building a 6x6 with those as the rear tires (instead of duals) and then these as the front tires: Mud Plugger 1.9 Scale Tires So would need 6 wheels, 4 fat ones for the puller tires and then 2 narrow for the front tires. I am unsure how I want to set the axles up currently. Looking at likely running SCX axles for the 2 rear axles and then an XR width SCX axle for the front axle to get the outside of tire measurements the same. This something we could work on coming up with a design for? Its going to be a 6x6 so some form of big rig wheel design would be best. Wes |
05-22-2015, 01:27 PM | #175 |
A while back I did some heavy truck/semi wheels for Szczerba, and they were a super pita, but I'm sure we can work something out.
05-22-2015, 01:35 PM | #176 |
05-23-2015, 03:56 PM | #177 |
Shoot me a PM with your thoughts on how to make them and I'll get some thoughts together early this week and we can see what we come up with. Wanting something super simple. Either a basic 10-12 hole design or something like these: Wes Last edited by WesTX; 05-23-2015 at 04:14 PM. |
05-23-2015, 07:39 PM | #178 |
Oh, and I would like to do beadlocks if possible. Thinking of using AX8117 axial rings if possible. Edit - scratch the above ideas. Thinking solid wheels with these rings to get the above sort of kidney bean look. Wes Last edited by WesTX; 05-24-2015 at 11:13 AM. |
05-24-2015, 11:03 AM | #179 |
Attention CBE/YetiX customers! The "standard" YetiX wheel will come with a preset width, backspacing, and detail options, you specify the design. Cost per set, shipped via Priority within the US is $85. If you prefer a lower cost, less detailed version, they will run $70 shipped. Last edited by Duuuuuuuude; 05-24-2015 at 03:30 PM. |
05-24-2015, 11:14 AM | #180 |
Pebble Pounder Join Date: Apr 2013 Location: in the shop
| Re: DCW Made to Order Delrin Wheels 2.6 wheel on the YETI-X |
DCW Made to Order Delrin Wheels - Similar Threads | ||||
Steering/Suspension Aluminum, Titanium, Delrin links. Custom made | Erik D_lux | Chassis and Suspension | 72 | 07-31-2020 05:28 PM |
Ultralite Delrin D-Mount from DCW | Duuuuuuuude | Chassis and Suspension | 239 | 08-05-2014 09:49 PM |
Testing Interest: Made to order wheels | Duuuuuuuude | Tires and Wheels | 52 | 05-19-2014 08:42 PM |
