10-29-2014, 12:37 PM | #61 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: Ty's Vaterra Ascender
I don't have any of those bolts, I might have to look into those.
10-30-2014, 10:19 AM | #62 |
I got my MIP shaft kit for the FJ40 today. Now, I did have some issues with the kit 278mm WB instructions and the front shaft was too long (didn't give full compression without bottoming out) which I fixed by cutting it down. Since I swapped the front and rear links to better clock my axle housings, the cut shaft was then moved to the rear. Now with the MIP shafts, I have this same issue as before, but it can be remedied by running the shortest output (MIP #14926) on both sides of the transmission. I haven't done this yet, but I have verified it will work but putting the one short output I have on both ends and trying it. You can see the shaft is already close to bottoming out and it does under compression. I can only get about half of the rear travel I had with the short output installed. Still flexes ok, but I'll be changing that output as soon as I can. Shortest output shown here. |
10-30-2014, 10:54 AM | #63 |
RCC Addict Join Date: Nov 2010 Location: England
Thats good info thanks. I'm looking at getting MIPs in the near future. I run the 302 wheelbase at the moment, but might have to bring the front back to 290 to suit the Land Rover body I have. hope the standard MIP's will work with that. I will have to order from the USA, so want to get the right parts. It can be up to a 3 week wait if I don't.
10-30-2014, 11:01 AM | #64 | |
| Re: Ty's Vaterra Ascender Quote:
10-31-2014, 03:44 PM | #65 |
Got the RC4WD order, spare steelie is backordered. I think the Jammer hooks will look awesome on here! |
10-31-2014, 05:54 PM | #66 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
Hell yah! Looks sweet!
11-04-2014, 10:12 AM | #67 |
I got my output from MIP yesterday, corrected the driveline issue I was having and my LED kit showed up! Just waiting on the window masks and decal sheet to show their faces so I can start in on this body. |
11-04-2014, 04:03 PM | #68 |
Newbie Join Date: Oct 2014 Location: farmington
Ty what light kit is that you have? Can you post the link?
11-04-2014, 08:03 PM | #69 |
| Re: Ty's Vaterra Ascender |
11-05-2014, 02:38 PM | #70 |
11-10-2014, 12:16 PM | #71 |
Finally received the window masks and decal sheet, hopefully I'll get to painting this tonight! Also received a RULR set from JC Auto Design to help with the torque twist. Updates later!
11-13-2014, 01:56 PM | #72 |
Working on the paint today, here's a little teaser of the color I mixed up. more to come later! Hoping to have it painted and decal'd tonight. |
11-14-2014, 12:10 PM | #73 |
Spent a good 2 1/2 hours on the body last night cutting out all the window trim and other decals. Painting the grill and mirrors today, then starting in on the LEDs. After that I need to come up with some sort of interior! Love the way the color turned out. Took me a long time to mix. Last edited by Ty@Tekin; 01-27-2016 at 12:18 PM. |
11-14-2014, 03:59 PM | #74 |
Since the grill, mirrors and front signal housings are still in the paint shop, I couldn't wait to at least go drive around in the snow. Last edited by Ty@Tekin; 01-27-2016 at 12:19 PM. |
11-14-2014, 08:08 PM | #75 |
Looks great! Got some nice detail in that body. Can't wait to see more!
11-16-2014, 10:21 AM | #76 | |
Unfortunately it looks as if a pin has broken in the left front cv, and possible the rear pinion also. Still, it was running fine for a couple of hours. | |
11-16-2014, 08:53 PM | #77 |
Newbie Join Date: Jan 2005 Location: Frisco, Texas
What color paint did you use, I dig it!
11-17-2014, 09:02 AM | #78 |
11-17-2014, 04:04 PM | #79 |
Started on the interior today, chopped up a Dinky RC set to fit and I will be making a deck for the rear area behind the body posts. Velcro'd to the doors, sits pretty nice and just barely clears the transmission. Had to heat up the rear a bit and shape it around the shock hoops so it would sit flat. Also mounted the spare, decided I'm not adding any more weight than I have to with a rear carrier setup. Last edited by Ty@Tekin; 01-27-2016 at 12:22 PM. |
11-17-2014, 04:34 PM | #80 |
Some more playing in the snow. The 4WD works great! Still waiting on the grill, lights and mirrors. Damn painter is slow.... It's getting dark and I don't have the lighting wired up yet, time to head back home! It's a little chilly out right now too with no heater. Last edited by Ty@Tekin; 01-27-2016 at 12:22 PM. |
Ty's FJ40 Ascender - Similar Threads | ||||
Ty's Metal Works | TURTLE | Chassis and Suspension | 44 | 12-23-2015 01:07 AM |
Ty's Axial YETI | Ty@Tekin | Axial Yeti | 121 | 09-18-2015 12:25 PM |
Ty's Event Photos | TURTLE | Scale Nationals | 27 | 07-20-2014 08:10 AM |
Ty's Tow Ropes | TURTLE | Scale parts | 21 | 06-30-2014 01:49 PM |
Ty's Tow Ropes | TURTLE | Scale Accessories | 13 | 04-09-2014 02:42 PM |
