12-30-2008, 05:44 PM | #121 |
This is coming together nicely |
12-31-2008, 01:14 PM | #122 |
RCC Addict Join Date: Aug 2005 Location: Akron
Thanks Andy! Bruiser leafs aren't holding up to the punishment. I kinked one of them and it's having a hard time holding the truck up. I can't seem to get anyone to make delrin bruiser leafs so I have 3 designs I'm having cut now. Hopefully they'll be done soon. |
12-31-2008, 04:03 PM | #123 |
Quarry Creeper Join Date: Mar 2004 Location: n.e. ohio
Hey Nick, just dearch some hi-lifts. And keep me in mind on the derlin ones!
12-31-2008, 05:20 PM | #124 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
dooood. if you just flatten out an f350 leaf theyre the same. grind down a regular 3mm bolt for the center pin and bolt it together.
12-31-2008, 05:25 PM | #125 |
Ehhh delrin leafs would be cool. Actually the delrin leafs are just proto type pieces to play with so I can get an idea of how they work. I have another idea for making leafs that should be pretty darn cool.
01-05-2009, 10:00 PM | #126 |
You never know when you'll need air on the trail. Thanks to Bartos Chassis for putting this tank together for me. It turned out great! Had to mount it somewhere. This was where it was mounted on the 1:1 so it was appropriate. I might repaint it like a power tank since I screwed up some of the decal on it.... |
01-05-2009, 10:38 PM | #127 |
RCC Addict Join Date: May 2006 Location: Roseville
Damn Nick, that looks so awesome!
01-14-2009, 12:25 PM | #128 |
Rock Crawler Join Date: Sep 2005 Location: IDK
01-14-2009, 08:28 PM | #129 |
Quarry Creeper Join Date: Jan 2008 Location: Cyprus
o..m..g.. That is amazing! |
01-21-2009, 09:24 AM | #130 |
No exciting updates... Finally tore into the front axle to see what failed. Had a good idea and found it quickly. Can't complain. This old front axle has taken some abuse! I got it replaced and up and running so I can do some crawling after work today. Got a small 3S 1300mah lipo in so I could tuck that up under the hood. I also changed out the knuckles to RCP crawler's Super-Max aluminum knuckles. I had to take just a tad bit of material off the top and bottom to get them to work smoothly. Hopefully it climbs better. If not, then I need to shed some weight from the bed somehow. |
01-21-2009, 08:54 PM | #131 |
sweet man, what made you snap the shaft? ive done that once before in the crew cab and bound the hell out of it with the regular trail docs. in between these two rocks at full lock.
01-21-2009, 11:34 PM | #132 |
Pebble Pounder Join Date: Jan 2009 Location: Puyallup WA
i like it..
01-22-2009, 07:09 AM | #133 | |
Even worse, I went to drive it last night, had it on the rocks for maybe a minute and messed something up in the same area. Not sure if the whole head came off the axle like before or if it's just the pins that run through it. I think it's becuase of the new knuckles. They seemed to be just a tad bit wider than the other knuckles I had so the stub might sit away from the end of the axle just a tad bit more. If that's the case then when I turned one end of the pin would come out of the drive cup and that ain't good. I'll try to find out what happened. Not much free time in the next couple days. | |
03-02-2009, 09:21 PM | #134 |
Been a while. Truck was broke and out of commission for a bit. Wanting to get the truck done for a new series we're going to try in the summer which means I need more storage area and a better performing truck. This meant making an optional bed for comps Not to sure what to do about articulation. It'll easily rub right now. Not sure if I should try and run bump stops or what. I don't want to do wheel wells. |
03-02-2009, 11:29 PM | #135 |
So...I wasn't the only one thinking about runnin top truck with my 1.9 yota?
03-03-2009, 12:44 AM | #136 |
New series, what might that be?
03-03-2009, 05:56 AM | #137 | |
Details will be posted before long! We're still working a few things out. | |
03-03-2009, 04:47 PM | #138 |
03-03-2009, 09:03 PM | #139 |
Narrowed it up to clear the tires and added some details. Was just curious what the winch would look like. |
03-05-2009, 09:16 PM | #140 |
Moving along slowly. Got the rear winch figured out at least |
