01-26-2018, 12:52 PM | #21 |
Rock Stacker Join Date: Jun 2005 Location: Philadelphia
| Re: 3Racing Crawler Ex (EX Real)
For the record, the motor spacer is made of aluminum so it'll help with any heat disbursement Sent from my SAMSUNG-SM-G891A using Tapatalk |
01-26-2018, 12:58 PM | #22 |
Next part was attaching the spur gear to the main shaft and then mounting it to the gear cover. This time there was different size screws like the manual said I missed a couple of pics along the way, but it goes together pretty easy. You'll notice a ton of space between where the e-clip attached. It does go away ones everything is mounted together Sent from my SAMSUNG-SM-G891A using Tapatalk |
01-26-2018, 01:39 PM | #23 |
Test Sent from my SAMSUNG-SM-G891A using Tapatalk |
01-26-2018, 01:45 PM | #24 |
Pebble Pounder Join Date: Oct 2004 Location: Philadelphia
Some pics of Bag 2. This one seems to have to correct collection of screws The motor is going to be interesting, I'm not much of a sealed can kind of guy, so we'll see how long this lasts before a rebuildable 35t goes in Sent from my SAMSUNG-SM-G891A using Tapatalk Last edited by kaybo; 01-26-2018 at 01:48 PM. |
01-26-2018, 10:12 PM | #25 |
RCC Addict Join Date: Apr 2009 Location: LA
This is a very interesting design to solve pinion mesh issues. Has anyone seen this before? I wonder how it will work with varied pinion-gear design, casting, and CNC differences/tolerances. Also, with all those holes, it doesn't look like there's much meat between the inner and outer "rings"; time will tell if it's enough "meat" to keep from separating as the weight of the motor bounces on the rocks. |
01-26-2018, 10:23 PM | #26 | |
| Re: 3Racing Crawler Ex (EX Real) Quote:
Really don't need a lot of meat on the screw holes, just gotta remember not to over crank the screws to the motor can Tamiya uses that same setup on the m-chassis and the TT- chassis and the non-Evo TB-chassis, and they survived Sent from my SAMSUNG-SM-G891A using Tapatalk | |
01-27-2018, 08:56 AM | #27 |
Nice, now i want one of these kits for the price i am going ahead an getting one.
01-27-2018, 09:21 AM | #28 | |
I'll try to finish up the transmission tonight or tomorrow morning and post pics Sent from my SAMSUNG-SM-G891A using Tapatalk | |
01-27-2018, 10:57 AM | #29 |
I wanna be Dave Join Date: May 2010 Location: The east coast
Looks good so far. What I'm most interested in is how much steering angle it provides.
01-27-2018, 12:52 PM | #30 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: 3Racing Crawler Ex (EX Real) How much is the D90 from 3Racing? Perhaps it has the same specs as all of those ebay D90 hard bodies.
01-27-2018, 12:53 PM | #31 |
| Re: 3Racing Crawler Ex (EX Real) |
01-27-2018, 01:41 PM | #32 |
01-27-2018, 03:03 PM | #33 | |
| Re: 3Racing Crawler Ex (EX Real) Quote: Sent from my SAMSUNG-SM-G891A using Tapatalk | |
01-27-2018, 05:07 PM | #34 |
Rock Crawler Join Date: Jul 2011 Location: USA
Looks great so far! Please post up some axle pics when you have a chance |
01-27-2018, 06:10 PM | #35 |
Got a little more done tonight - just a little bit more of the 2-speed transmission done. Really neat and builds real easy, assuming you're not like me and don't read all the directions Shift fork is plastic, but the same super stiff stuff everything else is made from. I like that the fork actually snaps to the sliders, unlike my Tamiya hi-lift where it just sat. The metal gears are nice When assembly the case, make sure you put the 5x10 bearing in (unlike me the first time) or else youll get some gritty noise that'll drive you nuts like me I threw some 'extra ceramic grease on my gears, just because I could Sent from my SAMSUNG-SM-G891A using Tapatalk |
01-28-2018, 01:25 AM | #36 |
Rock Stacker Join Date: Aug 2013 Location: Kangaroo Island
these look like a pretty mad bit of gear for the money, i'll be following this build and probably making more bad financial decisions because of it.
01-28-2018, 01:57 PM | #37 |
So, today was interesting. Had to pull the transmission apart multiple times, first time was because I used the wrong pin in the wrong places, then the 2nd time because I forgot a bearing. The last time was the final - I didn't follow the pictures correctly and had everything mounted upside down, so then I had to fix everything. Other than my mistakes, it was an easy build as long as you following the directions and images correctly Sent from my SAMSUNG-SM-G891A using Tapatalk |
01-28-2018, 02:07 PM | #38 |
Next step was to attach 1/2 the drive shafts to the transmission. Metals ends attach to plastic 1/2 shafts. The nice thing 3Racing did was to have a sleeve that slides over the pic and pivot joint and they gets a beefy step screw to attach it to the output shaft. Sent from my SAMSUNG-SM-G891A using Tapatalk |
01-28-2018, 02:11 PM | #39 |
This part is where I noticed my big boo-boo. When I attached the motor, I had the plastic piece upside down, so it all had to be pulled apart until I found where I messed up. 3Racing should have marked the parts a little better, but hey, I could have read the instructions better - so we'll call it a wash Attaching the motor braces to the chassis was fun because of the plastic spacers, but once you get one on the one side done, the other will slide in. Then just repeat doe the other side Drivetrain and motor attached Sent from my SAMSUNG-SM-G891A using Tapatalk |
01-29-2018, 02:57 AM | #40 |
If you don't like the gold M2x6mm beadlock bolts, here are a couple of cheap replacement options. I like the round button heads because they don't snag as much, but you could even go countersunk if you have the tools to drill the rings, and don't mind the tedium. What I'm most interested in this rig is the steering angle it can do with the included CV front axles. I can't find specs, details, reviews, or even pics of it anywhere! :( |
3Racing Crawler Ex (EX Real) - Similar Threads | ||||
My first real crawler. | onebadtrooper | General Crawlers | 21 | 12-27-2005 11:34 PM |
Crawler 4 Real | 51504rock | Chit Chat | 3 | 11-19-2005 12:52 AM |
Project Suzuki Samuri tube crawler.replica of a real crawler | RCWizard | General Crawlers | 7 | 12-24-2004 06:53 PM |
