02-01-2018, 10:42 PM | #61 | |
Pebble Pounder Join Date: Oct 2004 Location: Philadelphia
| Re: 3Racing Crawler Ex (EX Real) Quote:
Sent from my SAMSUNG-SM-G891A using Tapatalk | |
02-01-2018, 10:50 PM | #62 |
Well the axles proved to be the single hardest step to do. The pivot ball part was a piece of cake - the rest not so much. This is the step I gotta give 3Racing some crap about. None of the 'A'/'B' parts are marked. So you really need to study the drawings and then look at the parts pages at the back of the manual. Anyways....... They have you build it upside down, and it goes together easy enough, except for the shock mounts. These have to be the single most annoying part I've ever attached to a classes. The changing of the castor degree is pretty nifty - little markings on the pieces represent 2 degrees. Hopefully the pics show them Be aware that the pivot ball piece is built wrong in all the single pics. It's since been fix Sent from my SAMSUNG-SM-G891A using Tapatalk |
02-02-2018, 05:53 AM | #63 |
RCC Addict Join Date: Apr 2009 Location: LA
Sorry the assembly isn't going as well as you'd like. :( Let's hope driving it will make up for any emotional damage you sustain! |
02-02-2018, 05:55 AM | #64 |
| Re: 3Racing Crawler Ex (EX Real) Looks like about 40 degrees one way and 45 the other. Are there any steering stops that could be clearanced, or would the universals not rotate fully at a higher angle?
02-02-2018, 06:01 AM | #65 | |
The did the work to make sure it all clears everything Sent from my SAMSUNG-SM-G891A using Tapatalk | |
02-02-2018, 06:03 AM | #66 | |
The other part is I'm used to part numbers/letters on the trees and they don't do that. Not a biggie, I've built worse kits (a yokomo rally car comes to mind) Sent from my SAMSUNG-SM-G891A using Tapatalk | |
02-02-2018, 06:36 AM | #67 |
That is one complicated axle. I like the steering clearance though. Did you take a picture of the ring and pinion under the pumpkin cover before you closed it up?
02-02-2018, 06:56 AM | #68 | |
I'll snap a pic of the rear one she I build it Sent from my SAMSUNG-SM-G891A using Tapatalk | |
02-02-2018, 07:41 AM | #69 |
| Re: 3Racing Crawler Ex (EX Real) |
02-02-2018, 07:44 AM | #70 |
02-02-2018, 10:55 AM | #71 |
Now we're making some progress. Links completed The disk brakes serve a dual purpose, the look cool behind a wheel and the also cover/protect the balls - pretty slick on 3Racing's part Sent from my SAMSUNG-SM-G891A using Tapatalk |
02-02-2018, 10:57 AM | #72 |
Front axle now in place and all bolted together. This went together super easy, for what it's worth Sent from my SAMSUNG-SM-G891A using Tapatalk |
02-02-2018, 10:59 AM | #73 |
And at some point I'll pull the brakes and the rotors off and I'll have arts & crafts day and do some painting/detailing. I'll probably figure out a way to weather/age the chassis Sent from my SAMSUNG-SM-G891A using Tapatalk |
02-02-2018, 11:15 AM | #74 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
nice! and yes those brakes need paint. i think they assume people will do that. only bummer about those is you are stuck with those hexes, unless you belt sand them for less offset. yeah I'm one of those weirdos who like the tires inside the fenders lol nice progress, I'm still watching! |
02-02-2018, 12:05 PM | #75 | |
i think if i do anything, modification-wise, with these, it'll be to remove the hexes and use the rotor and shoes - they are really cool and i'm a big fan of clamping wheel hexes | |
02-03-2018, 09:40 PM | #76 |
Jato asked what the inside of the diff looked like and I put the front together without pics. So I took some Sent from my SAMSUNG-SM-G891A using Tapatalk |
02-03-2018, 09:47 PM | #77 |
So to finish off the rear axle was a piece of cake maybe I'm learning Main diff builds the same as the front. Joint #2 is the same as the front. Loads the CVD in (nice touch 3Racing, by the way) 2 bearings support the end of the CVD and the straight end adapters with bearings. Sent from my SAMSUNG-SM-G891A using Tapatalk |
02-03-2018, 09:48 PM | #78 |
More links to build and then it's time to hang this axle off the chassis Sent from my SAMSUNG-SM-G891A using Tapatalk |
02-04-2018, 04:10 AM | #79 |
Rock Stacker Join Date: Aug 2013 Location: Kangaroo Island
goddammit i caved, one of these badboys is headed my way in the next few weeks.
02-04-2018, 06:20 AM | #80 |
Rock Crawler Join Date: Jul 2011 Location: USA
The diff gears look very strong, and very similar to scx10.2 gears. I wonder if they are the same/compatible? Is the width of the axles the same as scx10.2 axles?
3Racing Crawler Ex (EX Real) - Similar Threads | ||||
My first real crawler. | onebadtrooper | General Crawlers | 21 | 12-27-2005 11:34 PM |
Crawler 4 Real | 51504rock | Chit Chat | 3 | 11-19-2005 12:52 AM |
Project Suzuki Samuri tube crawler.replica of a real crawler | RCWizard | General Crawlers | 7 | 12-24-2004 06:53 PM |
