Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Bet you haven't seen this! 3wd c1
Old 10-19-2016, 07:31 PM   #1
Default Bet you haven't seen this! 3wd c1
If you know me, you know that I love being different with my builds. One evening I was contemplating my next build and came across this picture. It was the only one I could find like it.
I immediately decided that I must build this truck. In case you didn't. Price it only has 3 wheels.
This will be a scratch build and I have just barely started. I plan to update this thread as I progress and build this crazy piece of machinery.
I spent months contemplating how to creat a singular rear drive wheel and I am pretty sure I have the concept down. Now it is simply to build it.
Here is my proof of concept rear wheel. It will be refined, but the plan is to run a belt drive system on each side of the wheel all built on a rear swing arm.
avanord is offline   Reply With Quote
Old 10-20-2016, 09:39 AM   #2
Default Re: Bet you haven't seen this! 3wd c1
This ought to be interesting, looking forward to the finished product.
travis c. is offline   Reply With Quote
Old 10-20-2016, 10:32 AM   #3
Interesting. It kind of has a Volkswagen front end on it. I am trying to imagine the stability of such a set up. Any kind of load in the bed would be a little sketchy at speed. Curious to see how it pans out and performs. Leaf sprung would be too sweet!
mr.rick is offline   Reply With Quote
Old 10-20-2016, 12:24 PM   #4
It'll probably perform better than the Reliant Robin that Jeremy Clarkson tested on Top Gear(U.K.)..............Oh how I miss Clarkson's antics.
Old 10-20-2016, 05:43 PM   #5
Well I am not sure it will. E real stable. That could definitely be an issue. However I am not too worried about it. I have a plan to help compensate a bit for it.
Mr. Rick I thought about leaves but I think that the wrap in the leaves would make it hard to keep tension on the dive system.
Old 10-22-2016, 11:50 AM   #6
Oh but I have Microgoat anyone?
Stu's 3x3 Bug (and poetry challenge) VIDEO! LULZ! POETRY!
dirk379 is offline   Reply With Quote
Old 10-22-2016, 11:55 AM   #7
Originally Posted by dirk379 View Post
That is the only other 3wd build I have ever seen and this one is going to be completely different. But I bet most haven't seen that one. Haha.
Old 10-22-2016, 11:56 AM   #8
A new piece to the puzzle arrived yesterday. Haven't had any time to work with it yet, but now I am ready to actually begin building some parts.
Old 10-23-2016, 10:19 PM   #9
It's a Roustabout Trivan... weird little things.
2JSC is offline   Reply With Quote
Old 10-28-2016, 10:37 PM   #10
You sir just made my day. I had only been able to find the one pic and had no idea what it was other than I was going to build it.
Spent the evening in the cave building and designing. First time I have ever attempted any type of swing arm. Obviously it is just the rough start and the final arms will be a more scale design.
They are currently made of 1/4 in Delrin stock and being that o have access to limited tooling I think I will probably be making them from Delrin as it is easy to work with. I was able to make a nice bearing seat for the rear wheel to sit in.
A little more mock up of what I might do with this thing. There is going to be a great deal more work to be done as the revo diff is narrower than my rear wheel at the moment.
I plan to mount the diff at the top of the swing arm so that the entire belt drive remains in tact regardless of the suspension travel.
Old 01-03-2017, 08:47 PM   #11
It has been quite some time since I have posted in this build and that is because I am waiting on some parts to be made. Final drawings have been completed and now I am waiting on a friend to make them. I am pretty sure I have it figured out.
I think I will be using the scx10ii as a base for this project due to the already included transfer case and cms setup. With the technicality of the rear swing arm and the body build I don't need any extra tasks for now.
I am impatiently waiting for my parts and when they get here the build will begin.
Old 02-12-2017, 06:11 PM   #12
Well... things fell through with my. Dudu that was planning on getting the parts done for me. So it is back to mock up stage. I was able to install the rear swing arm on the scx10ii chassis. This led to me driving around a little bit in the basement. It was fun and I discovered a few things.
1. I will need to widen the rear of the frame by about 3/4 in or so.
2. The rear swing arm will not swing, but remain stationary because I need a straight driveline for the rear diff.
3. The front will be run in a droop setting so the whole truck sits lower to the ground.
Here are some pics.
Old 02-12-2017, 06:48 PM   #13
DVS
It's called a Trivan.
DVS is offline   Reply With Quote
Old 02-12-2017, 06:50 PM   #14
DVS
Opps ! Didn't see 2JSC post. sorry
Old 02-13-2017, 09:08 PM   #15
Thanks man. As you noticed it was posted up further. I have looked into the pics. Obviously I chose to go a different direction in the rear for more durability. This will be driven in comps in class 1 so it needs to hold up.
Did a little more work tonight. I was able to locate a piece of brass to tie together my transfer case and rear diff. This will allow me to set a ride height and then it's off to the races.
Old 02-13-2017, 09:38 PM   #16
The trivan that could! I hope this one gets finished
Old 02-15-2017, 10:01 AM   #17
It will Certainly be finished. I have been plugging away lately. I was waiting on someone to make me some parts, but it fell though so I will be fabbing my own stuff.
Old 02-16-2017, 12:03 PM   #18
Moderator
JatoTheRipper's Avatar
Haha very cool! Can't wait to see this finished.
Old 02-16-2017, 12:46 PM   #19
M J
This is a great project - I'm glad to see it's coming along nicely!
M J is offline   Reply With Quote
Old 02-16-2017, 08:32 PM   #20
Thanks guys. Progress is coming slower than I would like, but it is looking promising. I am waiting on a couple parts to be fabbed as I can't make them accurately enough on my drill press. Then I will be able to get moving again.
Bet you haven't seen this! 3wd c1 - Similar Threads
3wd? VancouverFJ40 Tamiya CR-01 13 02-17-2012 12:59 AM
I bet you didn't know.... montana.matt Chit Chat 62 06-28-2010 11:16 PM
3wd ESForeman450 Duratrax Cliff Climber 8 03-31-2009 06:55 AM
3WD Scorpion 00Silverado General Crawlers 3 09-22-2005 09:58 AM
